oneAPI Registration, Download, Licensing and Installation
Support for Getting Started questions related to download, Installation and licensing for Intel oneAPI Toolkits and software development tools.
1292 Discussions
Re: KNOWN ISSUE with Intel oneAPI Toolkits versions 2022.1 and 2022.1.2 and standalone components
AONym
New Contributor II
Closing and relaunching installer gives the same message. What to do?
JesusG_Intel
Hello AONym,
We have reviewed your request and understand your frustration at this less-than-ideal situation.
The workaround we provided of uninstalling all components and reinstalling with the new, fixed oneAPI installer is indeed the safest, quickest, most efficient method of fixing everything.
Deleting files, folders, and changing registry settings is much more error prone, risky, and time consuming. You are more likely to render Visual Studio unusable than fixing it. You may end up in a situation where you messed something up then cannot uninstall and re-install Visual Studio at all.
To avoid you having to factory reset your PC, which is the worst case, we strongly recommend performing our workaround:
  1. Deinstall all Visual Studio instances.
  2. Deinstall oneAPI BaseKit 2022.1.2.
  3. Reinstall Visual Studio 2022 version 17.1.x.
  4. Install BaseKit 2022.1.3
Let us know if your installation does not work after following the above steps.
If there were a better, easier, faster way to solve this issue we would have gladly provided it.
Sincerely,
Jesus G.
Intel Customer Support
AONym
New Contributor II
This thread should remain open until Intel fixes the installer so it works correctly (for all editions of VS). Users should not be forced to uninstall and reinstall VS for every oneAPI update.
Soumya_M_Intel
Hi AONym,
Thanks for your update on the thread. However, as mentioned before, please understand NO new installer of the toolkit would be able to fix the issue since it is NOT occurring due to the Intel® oneAPI Base Toolkit 2022.1.3 installer but due to the already installed & integrated Intel® oneAPI Base Toolkit instances with Visual Studio 2022.
This is an uninstallation issue with the previous version of the toolkit which is currently installed on the system. Please understand any new fix that is released would require the currently installed version to be uninstalled first. However, to clarify simply - Visual Studio 2022 is blocking the toolkit & its components from being completely uninstalled.
So via the previously mentioned steps, you could revert your system to a state where no instances of both Visual Studio or Intel® oneAPI Base Toolkit are installed and allow a fresh installation.
Soumya
AONym
New Contributor II
Your explanation that " Visual Studio 2022 is blocking the toolkit & its components from being completely uninstalled" doesn't make sense.
When the Intel installer is running, VS2022 is not, and so cannot block anything. Since the Intel installer has admin privileges, it can change any files or registry entries (within limits) it wants.
So what part of oneAPI toolkit cannot be completely uninstalled? And couldn't that be done manually for this one case by deleting some files?
Soumya_M_Intel
Hi AONym,
Thanks for getting back to us on the thread. We understand your situation. However, kindly note, Visual Studio 17.1.0 was released on 15th February 2022 while the Intel® oneAPI Base Toolkit 2022.1.2 was released on 25th January 2022. The IDE versions that were released after the toolkit release could not be tested or validated beforehand. However, the known issue has been fixed on the next release i.e. Intel® oneAPI Base Toolkit 2022.1.3.
Please know, our development team has checked and suggested the workaround that we had provided for the issue that you are facing. You may visit the below link for reference.
Link: https://www.intel.com/content/www/us/en/developer/articles/release-notes/intel-oneapi-toolkit-release-notes.html
Soumya
AONym
New Contributor II
Because your proposed workaround of uninstalling all VS versions  involves so much work (in the re-installing), I do not consider this an acceptable workaround. Why not tell us which files to delete or rename, and which registry settings to delete or modify, to make your oneAPI Base Toolkit 2022.1.3. installer work?
I think Intel's customers have a right to expect that you will test your integration of oneAPI with VS against each update of VS, using the preview versions if necessary. I would also expect Intel to coordinate some of the integrations with Microsoft support.
So, in summary, I would ask again that Intel produce a package or installer to repair this mess, without touching the existing VS installations.
Soumya_M_Intel
Hi AONym,
Kindly wait for 2-3 business days, Let me pass this on to our development team in case they have anything to say on this, However, even if not, we will keep you posted.
Soumya
JesusG_Intel
Hello AONym,
Sincerely,
Jesus G.
Soumya_M_Intel
Hello AONym,
Please let us know if there are any further queries or concerns. Kindly let us know if the installation does not work after following the steps provided by our higher team. We look forward to your update. Have a nice day ahead.
Soumya
Soumya_M_Intel
Hello AONym,
We understand that you might be looking into the issue. However, this is to update you that we have not heard from you on our previous responses. Please reply within the next 24 business hours to keep this thread active. Have a nice day ahead.
Soumya
