oneAPI Registration, Download, Licensing and Installation
Support for Getting Started questions for Intel oneAPI Toolkits, Intel Parallel Studio XE and Intel System Studio
Request Permission to use Sudo
mochongli
i want to use sudo and apt to install any packgage and runtime i need to use in my project but i can't use it and then i can't develop anything because i not have sudo, apt and superuser privileged
sudo:
Dear User,
this server does not allow you to run "sudo".
If you need to install a dependency, please put it in your home directory.
* For autotools, you can do it with "./configure --prefix=~/my-path"
* For Python packages, use "pip install <package_name> --user" or create a Conda environment.
Sincerely,
Admins
ArpanB_Intel
Hi, this is due to you not having root privileges. Sudo access allows a user to execute all permitted commands as root or as any other user. Once the sudo access is given to a specific user in sudoers file, that user can execute the commands as root by executing it using the prefix sudo
The /etc/sudoers file controls who can run what commands as what users on what machines and can also control special things such as whether you need a password for particular commands. You should never edit this file with a normal text editor but always use the #visudo command instead.
Please contact your system admin to request access for the root privileges.
ArpanB_Intel
Hi, unfortunately we were unable to hear back from you.
If you have any further queries, please post a new question as this thread will no longer be monitored by Intel®.
