oneAPI Registration, Download, Licensing and Installation
Support for Getting Started questions related to download, Installation and licensing for Intel oneAPI Toolkits and software development tools.
Return Code: 1003
davesworking
I have tried both Windows 10 and Windows 11 installing the Base Toolkit.
The silent install shows this at the end of the log:
WARNING : Return Code is overwrited by Setup.exe return code. [ret code] = 1000 + [setup.exe ret code]
Return Code: 1003
davesworking
hi,
I was able to get around this by removing the --log parameter. (I didn't try using --log with any folder but the TEMP folder)
Offline installer
MSBuild version 17.6.3+07e294721 for .NET Framework
17.6.3.22601
Dave
RahulC_Intel
Hi David, could you please share the below details for further investigation:
  • Is the installer an online or an offline package?
  • Version of Microsoft Visual Studio installed along with it's build version
  • Other versions of Intel® Parallel Studio XE or Intel® oneAPI already installed on the system
  • Installation Log files.
    • The default path for a log file for a oneAPI installation is: C:\Program Files (x86)\Intel\oneAPI\logs
    • The default path for a log file for a Parallel Studio XE installation is: %temp%\pset_tmp_PSXE<version>_<username>
davesworking
hi,
Offline installer
17.6.3.22601
Dave
RahulC_Intel
David, thank you for your confirmation. We are glad that the issue has been resolved.
If you have any further queries, please post a new question as this thread will no longer be monitored by Intel®.
