I managed to setup it up and get it working correctly but it is all a bit trial and error when setting up the include/lib paths. I wonder if there is a standard way to do this to help anyone on the same task. I googled it and couldn't find any detailed steps.
This is what I did:
1. Install OneDAL from https://www.intel.com/content/www/us/en/developer/tools/oneapi/onedal-download.html
2. Visual Studio 2022 will show an OneDAL option in the Intel Library for oneAPI in project configuration properties. There are 3 options: Default Linking Method/Multi-threaded Static Library/Multi-threaded DLL. I have used the default one. Not sure about the other two.
3. Setup the include paths.
4. Setup the lib paths. Do I need to setup the TBB lib path???
5. Setup the lib files. I don't know if these are more than needed? Are they related to the option I chose in step 2?
For Debug: I set
onedald.lib
onedal_cored.lib
onedal_dpcd.lib
onedal_sycld.lib
onedal_threadd.lib
tbb12_debug.lib
tbbbind_2_0_debug.lib
tbbbind_2_5_debug.lib
tbbbind_debug.lib
tbbmalloc_debug.lib
tbbmalloc_proxy_debug.lib
tbb_debug.lib
For release: I set
onedal.lib
onedal_core.lib
onedal_dpc.lib
onedal_sycl.lib
onedal_thread.lib
tbb.lib
tbb12.lib
tbbbind.lib
tbbbind_2_0.lib
tbbbind_2_5.lib
tbbmalloc.lib
tbbmalloc_proxy.lib
Hi John, could you confirm whether you encountered any errors or warnings during the installation?
We would like to know.
One error I had is "missing tbb12.dll" when I didn't include the tbb lib path.
John, please click here: https://www.intel.com/content/www/us/en/docs/onedal/get-started-guide/2021-6/overview.html, for complete guidance on setting up the Intel® oneAPI Data Analytics Library installation.
John, unfortunately we were unable to hear back from you.
If you have any further queries, please post a new question as this thread will no longer be monitored by Intel®.
