I want to use Intel Arc A770 16G LE for training on Windows. I found Intel® Extension for PyTorch and compiled and configured it according to the following link
. But it didn't work, there were many errors, it seems that there is a lack of environment support, the environment required by the document is Intel® oneAPI Base Toolkit, complete installation, python 3.11.10, Visual Studio 2022 C++ V143
Hardware Information:
CPU: AMD 5600G
GPU: Intel Arc A770 16G LE ( 32.0.101.5972)
OS:
Edition Windows 11 Pro
Version 23H2
Installed on 11/24/2023
OS build 22631.4169
Experience Windows Feature Experience Pack 1000.22700.1034.0
Some errors are displayed:
[4315/5981] Building CXX object third_party\ideep\mkl-...ph_backend_dnnl.dir\patterns\single_op_pattern.cpp.obj C:\Program Files (x86)\Intel\oneAPI\ipex_bundle\pytorch\third_party\ideep\mkl-dnn\src\graph/backend/dnnl/constant_cache.hpp(1): warning C4819: ? file contains characters that cannot be represented in the previous generation (950). File saved in Unicode to prevent data loss C:\Program Files (x86)\Intel\oneAPI\ipex_bundle\pytorch\third_party\ideep\mkl-dnn\src\graph/interface/partition_impl.hpp(1): warning C4819: File contains characters that cannot be represented in the previous generation (950). File saved in Unicode to prevent data loss C:\Program Files (x86)\Intel\oneAPI\ipex_bundle\pytorch\third_party\ideep\mkl-dnn\src\graph/backend/dnnl/kernels/binary.hpp(1): warning C4819: File contains characters that cannot be represented in the previous generation (950). ??? File saved in Unicode to prevent data loss ninja: Build stopped: Subcommand failed. Found existing installation: mkl-static 2024.2.1 Uninstalling mkl-static-2024.2.1:
Thank you for posting in the Intel community. Please note that I have moved your topic to the relevant forum.
Stef
Hi Jianbo, please check the minimum system requirements to install Intel® Extension for PyTorch which are as follows:
- Intel® Arc™ A-Series GPUs
- Intel® Core™ Ultra Processors with Intel® Arc™ Graphics (MTL-H)
Kindly check the link you have shared with us and also check the below link for more information on Intel® oneAPI Base Toolkit System Requirements:
Hi Jianbo, thank you for your response! We’re glad to hear that your previous issue has been resolved.
We would like to inform you that we are routing your recent query to the dedicated team for further assistance. If you have any additional questions regarding downloading and installation, please post a new query, as this thread will no longer be monitored by Intel®.
