While trying to install parallel_studio_xe_2020_update4_composer_edition_for_cpp_online using CLI I get the message:
"Unable to connect to Intel(R) Software Development Products Registration Center
(https://registrationcenter.intel.com). Check your proxy settings and correct
them if needed."
also running: `wget https://registrationcenter.intel.com` returns:
"--2023-04-13 16:51:46-- https://registrationcenter.intel.com/
Resolving registrationcenter.intel.com (registrationcenter.intel.com)... 13.91.95.74
Connecting to registrationcenter.intel.com (registrationcenter.intel.com)|13.91.95.74|:443... connected.
HTTP request sent, awaiting response... 301 Moved Permanently
Location: https://corpredirect.intel.com/Redirector/404Redirector.aspx?404;https://registrationcenter.intel.com/ [following]
--2023-04-13 16:51:46-- https://corpredirect.intel.com/Redirector/404Redirector.aspx?404;https://registrationcenter.intel.com/
Resolving corpredirect.intel.com (corpredirect.intel.com)... 104.79.199.115, 2a00:a040:0:182::1ea2, 2a00:a040:0:186::1ea2
Connecting to corpredirect.intel.com (corpredirect.intel.com)|104.79.199.115|:443... " and then stuck.
How could i accsess https://registrationcenter.intel.com? how could i fix that problem and install?
Gal Ben Artzi
Hi Gal, are you using VPN? We would also suggest you to check your firewall settings.
We would like to know.
Gal, unfortunately we were unable to hear back from you.
If you have any further queries, please post a new question as this thread will no longer be monitored by Intel®.
