Dear Fortran Community,
I was unable to install the latest Fortran compiler , Version 25.0.4. I first tried the offline install (Fortran only) and go the following error message:
An error has been encountered during the installation process. Detailed installation log files are located under ... . Please submit this error and the log files using one of the following support options:
- Report your issue on the Intel Community Forum
- If you have Priority Support, Submit a Service request at Online Service Center
Download failed: Failed to establish Internet connection. Check your connection settings.
Installation of component has failed. Component id: Intel.oneapi.win.compilers-common-runtime, name: Intel* oneAPI Compiler 2025.0.4, version: 2025.0.4+1521. Error: Sequence execution failed.
Seeing that the reported problem was with the Internet connection, I decided to try the online installer, with the same results. After doing a repair install on 24.2.0, I was able to revert to the previous version, Intel Fortran 25.0.1.
How can I install the current Version 25.0.4, or the upcoming Version 25.1?
The relevant portion of the log file seems to be:
02/05/2025 19:29:06:032 : 22824 : MESSAGE : The following products are installed by the moment:
Id: intel.oneapi.win.basekit.product, name: Intel® oneAPI Base Toolkit, version: 2023, installation directory: C:\Program Files (x86)\Intel\oneAPI
Id: intel.oneapi.win.hpckit.product, name: Intel® oneAPI HPC Toolkit, version: 2023, installation directory: C:\Program Files (x86)\Intel\oneAPI
Id: intel.oneapi.win.hpckit.product, name: Intel® HPC Toolkit, version: 2024, installation directory: C:\Program Files (x86)\Intel\oneAPI
Id: intel.oneapi.win.hpckit.product, name: Intel® HPC Toolkit, version: 2024.2, installation directory: C:\Program Files (x86)\Intel\oneAPI
End of installed products list.
02/05/2025 19:29:06:033 : 22824 : MESSAGE : Data presenter is initialized successfully.
02/05/2025 19:29:06:033 : 22824 : MESSAGE : Connecting to data presenter signals...
02/05/2025 19:29:06:033 : 22824 : MESSAGE : Qml presenter is created.
02/05/2025 19:29:06:034 : 22824 : MESSAGE : BootstrapperInstallerCommandLineParser: Update mode forwarded parameters: ''
02/05/2025 19:29:06:661 : 22824 : MESSAGE : Getting Get Started link for 'Intel® Fortran Compiler'
02/05/2025 19:29:06:661 : 22824 : WARNING : <GetLocalGetStartedLink> can't set 'InstallDir' due to empty variable
02/05/2025 19:29:06:661 : 22824 : MESSAGE : <MetaVariablesManager> Resolving all names, Input text is ''
02/05/2025 19:29:06:661 : 22824 : MESSAGE : <MetaVariablesManager> Resolving all names, Output text is ''
02/05/2025 19:29:06:661 : 22824 : DEBUG : Resolving local getting started link '' result ''
02/05/2025 19:29:06:662 : 22824 : MESSAGE : Remote link 'https://www.intel.com/content/www/us/en/docs/fortran-compiler/get-started-guide/current/overview.html' is valid. Trying to establish the connection.
02/05/2025 19:29:06:686 : 22824 : MESSAGE : DownloadManager: check internet connections status [Proxy requires authentication] code [105] url [https://www.intel.com/content/www/us/en/docs/fortran-compiler/get-started-guide/current/overview.html]
02/05/2025 19:29:06:686 : 22824 : MESSAGE : DownloadManager connection error[Proxy requires authentication]
02/05/2025 19:29:06:686 : 22824 : ERROR : Download failed.
Failed to establish internet connection. Check your connection settings.
02/05/2025 19:29:06:686 : 22824 : MESSAGE : DownloadManager check connection: [ERROR]
02/05/2025 19:29:06:686 : 22824 : MESSAGE : DownloadManager: Reset retry download timer
02/05/2025 19:29:06:686 : 22824 : MESSAGE : Connection to 'https://www.intel.com/content/www/us/en/docs/fortran-compiler/get-started-guide/current/overview.html' cannot be established.
02/05/2025 19:29:06:686 : 22824 : MESSAGE : Local link '' is NOT valid.
02/05/2025 19:29:06:686 : 22824 : MESSAGE : Remote link 'https://www.intel.com/content/www/us/en/docs/fortran-compiler/get-started-guide/current/overview.html' is valid. Returning the remote link.
02/05/2025 19:29:06:687 : 22824 : MESSAGE : Getting Get Started link for 'Intel® Fortran Compiler'
02/05/2025 19:29:06:687 : 22824 : WARNING : <GetLocalGetStartedLink> can't set 'InstallDir' due to empty variable
02/05/2025 19:29:06:687 : 22824 : MESSAGE : <MetaVariablesManager> Resolving all names, Input text is ''
02/05/2025 19:29:06:687 : 22824 : MESSAGE : <MetaVariablesManager> Resolving all names, Output text is ''
02/05/2025 19:29:06:687 : 22824 : DEBUG : Resolving local getting started link '' result ''
02/05/2025 19:29:06:687 : 22824 : MESSAGE : Remote link 'https://www.intel.com/content/www/us/en/docs/fortran-compiler/get-started-guide/current/overview.html' is valid. Trying to establish the connection.
02/05/2025 19:29:06:692 : 22824 : MESSAGE : DownloadManager: check internet connections status [Proxy requires authentication] code [105] url [https://www.intel.com/content/www/us/en/docs/fortran-compiler/get-started-guide/current/overview.html]
02/05/2025 19:29:06:692 : 22824 : MESSAGE : DownloadManager connection error[Proxy requires authentication]
02/05/2025 19:29:06:692 : 22824 : ERROR : Download failed.
02/05/2025 19:29:06:692 : 22824 : MESSAGE : DownloadManager check connection: [ERROR]
02/05/2025 19:29:06:692 : 22824 : MESSAGE : DownloadManager: Reset retry download timer
02/05/2025 19:29:06:692 : 22824 : MESSAGE : Connection to 'https://www.intel.com/content/www/us/en/docs/fortran-compiler/get-started-guide/current/overview.html' cannot be established.
02/05/2025 19:29:06:692 : 22824 : MESSAGE : Local link '' is NOT valid.
02/05/2025 19:29:06:692 : 22824 : MESSAGE : Remote link 'https://www.intel.com/content/www/us/en/docs/fortran-compiler/get-started-guide/current/overview.html' is valid. Returning the remote link.
Hi James, could you please share the below details with us so that we will assist you in a better way.
- Operating system and its build version on which you are installing the product.
- Exact version of Visual Studio.
- Screenshot of an error code.
Hi James, we have sent you a private message. Kindly check your inbox.
Hi James, unfortunately, we were unable to hear back from you.
If you have any further queries, please post a new question, as this thread will no longer be monitored by Intel®.
