oneAPI Registration, Download, Licensing and Installation
Support for Getting Started questions related to download, Installation and licensing for Intel oneAPI Toolkits and software development tools.
Unable to install offline
TJ567898765
I've downloaded intel-fortran-compiler-2025.0.0.712_offline.exe and transferred it to a machine which is not connected to the internet.  However this doesn't complete with the following error message:
11/13/2024 11:33:30:114 : 30776 : MESSAGE : Starting execution of operation 'intel.oneapi.win.oneapicommon.licensing,v=2025.0.0+707'.
11/13/2024 11:33:35:579 : 30776 : ERROR : Installation of component has failed.
Component id: intel.oneapi.win.oneapi-common.licensing, name: oneAPI Common, version: 2025.0.0+707.
During the execution of the application 'C:\WINDOWS\system32\WindowsPowerShell\v1.0\powershell.exe' with
arguments '-NoLogo -NoProfile -NonInteractive -ExecutionPolicy AllSigned -File
C:\ProgramData\Intel\InstallerCache\DownloadCache\intel.oneapi.win.oneapicommon.licensing,v=2025.0.0+707\latest_symlink_post_install.ps1 -installDir C:\Program Files
(x86)\Intel\oneAPI -linkTargetVersion 2025.0 -latestLinkDir licensing' errors were received:
File C:\ProgramData\Intel\InstallerCache\DownloadCache\intel.oneapi.win.oneapicommon.licensing,v=2025.0.0+707\latest_s
ymlink_post_install.ps1 cannot be loaded. A certificate chain could not be built to a trusted root authority.
+ CategoryInfo : SecurityError: (:) [], ParentContainsErrorRecordException
+ FullyQualifiedErrorId : UnauthorizedAccess
C:\ProgramData\Intel\InstallerCache\DownloadCache\intel.oneapi.win.oneapicommon.licensing,v=2025.0.0+707\toolkit_linker_pre_remove.ps1 -installDir C:\Program Files
File C:\ProgramData\Intel\InstallerCache\DownloadCache\intel.oneapi.win.oneapicommon.licensing,v=2025.0.0+707\toolkit_
linker_pre_remove.ps1 cannot be loaded. A certificate chain could not be built to a trusted root authority.
C:\ProgramData\Intel\InstallerCache\DownloadCache\intel.oneapi.win.oneapicommon.licensing,v=2025.0.0+707\latest_symlink_pre_remove.ps1 -installDir C:\Program Files
ymlink_pre_remove.ps1 cannot be loaded. A certificate chain could not be built to a trusted root authority.
C:\ProgramData\Intel\InstallerCache\DownloadCache\intel.oneapi.win.oneapicommon.licensing,v=2025.0.0+707\toolkit_linker_post_install.ps1 -installDir C:\Program Files
linker_post_install.ps1 cannot be loaded. A certificate chain could not be built to a trusted root authority.
Error: Sequence execution failed.
11/13/2024 11:33:35:579 : 30776 : MESSAGE : Operation 'intel.oneapi.win.oneapicommon.licensing,v=2025.0.0+707' execution is finished with status Fail.
Has anyone managed to get this to install correctly ?
Vipin_S_Intel
Hi Thomas, Could you please share the below details with us?
  • Version of Microsoft Visual Studio installed along with it's build version.
  • Operating System along with its build version on which you are installing the product.
  • Other versions of Intel® Parallel Studio XE or Intel® oneAPI already installed on the system.
To assist you further, we would require these details.
TJ567898765
Hi Vipin,
Thank you for your response, I've attempted the install on multiple computers as follows:
Computer A: (Never Connected to Internet)
Windows 10 Build 19043
VS Professional 17.10.0
No other versions of Parallel Studio or oneAPI
Failed with above error message
Computer B: (Never Connected to Internet)
Windows 10 Build 19045
VS Professional 17.8.5
Computer C:
VS Professional 17.11.4
  1. First installed the offline installer whilst connected to the internet - Successful
  2. Then uninstalled Fortran Compiler
  3. Disconnected from the internet
  4. Installed from the same offline installer - Successful
RahulC_Intel
Hi Thomas, kindly follow the below troubleshooting steps to resolve the issue.
Do let us know, if the issue still persists and share the log file along with the screenshot of the error message.
TJ567898765
Hi @RahulC_Intel
Thank you for your reply.
I've followed your suggested steps uninstalling all visual studios and then installing only 2022 17.9.2 however the issue is still the same please see below and attached logs.
Please do let me know the next steps.
Vipin_S_Intel
Hi Thomas, we have sent you a private message. Kindly check your community inbox.
Vipin_S_Intel
Vipin_S_Intel
