oneAPI Registration, Download, Licensing and Installation
Support for Getting Started questions related to download, Installation and licensing for Intel oneAPI Toolkits and software development tools.
1387 Discussions
Using dnf to install oneapi tooling on a Fedora 38 machine
etiennemlb
On a fresh Fedora38 box (using dnf) it does not seem possible to install some oneapi packages.
After following the intel instructions (https://www.intel.com/content/www/us/en/docs/vtune-profiler/installation-guide/2023-0/package-managers.html) and running say:
$ sudo dnf install intel-oneapi-tbb-devel ...
will result in the following error:
Problem opening package intel-oneapi-common-licensing-2021.2.0-2021.2.0-195.noarch.rpm
Problem opening package intel-oneapi-oidn-1.3.0-1.3.0-167.x86_64.rpm
Problem opening package intel-oneapi-tbb-2021.2.0-2021.2.0-357.x86_64.rpm
Problem opening package intel-oneapi-tbb-common-2021.2.0-2021.2.0-357.noarch.rpm
Problem opening package intel-oneapi-tbb-common-devel-2021.2.0-2021.2.0-357.noarch.rpm
Problem opening package intel-oneapi-tbb-devel-2021.2.0-2021.2.0-357.x86_64.rpm
The downloaded packages were saved in cache until the next successful transaction.
You can remove cached packages by executing 'dnf clean packages'.
Error: GPG check FAILED
It has now been reported for multiple months, in multiple post, but still, Intel did not fix the issue as of 2023/08/11 AFAIK.
Please, @ArpanB_Intel try not to answer with:
ubuntu:22.04 - apt - OK
ubuntu:20.04 - apt - OK
debian:9 - apt - OK
debian:10 - apt - OK
debian:11 - apt - OK
redhat/ubi8 - dnf - OK
redhat/ubi9 - dnf - OK
rockylinux:8 - dnf - OK
rockylinux:9 - dnf - OK
fedora:36 - dnf - OK
fedora:37 - dnf - OK
amazonlinux:2 - yum - OK
amazonlinux:2022 - dnf - OK
registry.suse.com/suse/sle15:15.3 - zypper - OK
registry.suse.com/suse/sle15:15.4 - zypper - OK
According to: https://www.intel.com/content/www/us/en/developer/articles/system-requirements/vtune-profiler-system-requirements.html
It seems that not even Fedora 37 is correctly supported.
Is there any true progress being made on this issue ? Or, at least a workaround.
Other posts mentioning the issue:
GPG-PUB-KEY-INTEL-SW-PRODUCTS.PUB expired?: https://community.intel.com/t5/oneAPI-Registration-Download/GPG-PUB-KEY-INTEL-SW-PRODUCTS-PUB-expired/m-p/1479122
Expired signing key for Intel oneAPI???:https://community.intel.com/t5/oneAPI-Registration-Download/Expired-signing-key-for-Intel-oneAPI/m-p/1481424
expired certificate for software installation:https://community.intel.com/t5/oneAPI-Registration-Download/expired-certificate-for-software-installation/m-p/1479425
Intel Key Expired?:https://community.intel.com/t5/oneAPI-Registration-Download/Intel-Key-Expired/m-p/1503293
RahulC_Intel
Please note that FEDORA 38 is now supported with the latest version of our toolkit except for some issues with Intel® VTune™ Profiler and Intel® C++ Compiler which does not support it.
Have a nice day!
RahulC_Intel
Etienne, unfortunately we were unable to hear back from you.
If you have any further query, please post a new question as this thread will no longer be monitored by Intel®.
