oneAPI Registration, Download, Licensing and Installation
Support for Getting Started questions related to download, Installation and licensing for Intel oneAPI Toolkits and software development tools.
1495 Discussions
VStudio 2017 Integrate with Fortran, please help
labview
Hi there,
I am using Visual Studio 2017, and integrate with the Intel Fortran Compiler 2021v2022.2.0.9553. After the installation, I unable to locate Fortran details in Visual Studio -> About. Hence, I have an issue when loading app with Fortran. Please advice
See attached below
Microsoft Visual Studio Professional 2017
Version 15.9.58
VisualStudio.15.Release/15.9.58+34118.181
Microsoft .NET Framework
Version 4.8.04084
Installed Version: Professional
Visual C++ 2017 00370-20002-14958-AA615
Microsoft Visual C++ 2017
ASP.NET and Web Tools 2017 15.9.04012.0
C# Tools 2.10.0-beta2-63501-03+b9fb1610c87cccc8ceb74a770dba261a58e39c4a
C# components used in the IDE. Depending on your project type and settings, a different version of the compiler may be used.
Common Azure Tools 1.10
Provides common services for use by Azure Mobile Services and Microsoft Azure Tools.
Dotfuscator Community Edition 5.36.0.7050-e77ce80a6
PreEmptive Protection - Dotfuscator CE
JavaScript Language Service 2.0
Microsoft JVM Debugger 1.0
Provides support for connecting the Visual Studio debugger to JDWP compatible Java Virtual Machines
Microsoft MI-Based Debugger 1.0
Provides support for connecting Visual Studio to MI compatible debuggers
Microsoft Visual C++ Wizards 1.0
Microsoft Visual Studio VC Package 1.0
MLGen Package Extension 1.0
MLGen Package Visual Studio Extension Detailed Info
NuGet Package Manager 4.6.0
NuGet Package Manager in Visual Studio. For more information about NuGet, visit http://docs.nuget.org/.
ProjectServicesPackage Extension 1.0
ProjectServicesPackage Visual Studio Extension Detailed Info
ResourcePackage Extension 1.0
ResourcePackage Visual Studio Extension Detailed Info
SQLite & SQL Server Compact Toolbox 4.8
SQLite & SQL Server Compact Toolbox adds scripting, import, export, rename, query execution and much more to SQL Server Compact & SQLite Data Connections.
Test Adapter for Boost.Test 1.0
Enables Visual Studio's testing tools with unit tests written for Boost.Test. The use terms and Third Party Notices are available in the extension installation directory.
Test Adapter for Google Test 1.0
Enables Visual Studio's testing tools with unit tests written for Google Test. The use terms and Third Party Notices are available in the extension installation directory.
Visual Basic Tools 2.10.0-beta2-63501-03+b9fb1610c87cccc8ceb74a770dba261a58e39c4a
Visual Basic components used in the IDE. Depending on your project type and settings, a different version of the compiler may be used.
Visual Studio Code Debug Adapter Host Package 1.0
Interop layer for hosting Visual Studio Code debug adapters in Visual Studio
Visual Studio Tools for CMake 1.0
Many Thanks
Walter.
Labels (2)
mecej4
There is no evidence in what you have posted in the Visual Studio: About pop-up display to indicate that you have successfully installed the OneAPI compiler toolset -- not a single "Intel" in all those lines. There is a separate Intel forum dedicated to OneAPI installation issues .
Ron_Green
@labview I moved this issue to the Forum for Installation problems.  I do not see that oneAPI installed.
El_Zorro_Oro
Hi Walter,
I also had issues with VS 2017 and was advised by Lockheed Martin, my employer, to upgrade to 2019.
I upgraded my personal computer to 2019 as well.
I have had no issues with 2019 and support of 2019 is planned up to April of 2029, so migration to 2022 is a long way off.
MS Visual Studio 2019 is available here:   https://visualstudio.microsoft.com/vs/older-downloads/
Some info from:  https://learn.microsoft.com/en-us/visualstudio/releases/2019/release-notes
The Community 2019 is free, from what I understand, but I purchased the Professional version on my home computer to be compatible with my version at work.
BTW, I am really very happy with the OneAPI Fortran compiler, is based on the venerable DEC VAX FORTRAN and has compatibly with older versions of Fortran back to F77. I compile and run NASTRAN(R), 400,000 lines of code with little problems, with the right settings.
