Hello community,
Im trying to install Delft3D,I tried to install Delft3D software, but the software requires intel oneAPI2021 to install for windows. I see a related question on Where can I find older versions (2021.2) of Intel OneAPI Base and HPC that @Soumya_M_Intel answered, but it didn't works.
Where can I download the Intel OneAPI Base and Intel OneAPI HPC version 2021? Can someone post links for download.
Andi Dwi
Hi Andi, please note that Intel® has decided that Intel oneAPI Toolkits Versions: 2023.2.1 and earlier are not supported anymore. We urge users to upgrade to the latest version of Intel® developer tools. The unsupported versions do not include the latest functional and security updates. These versions are targeted to be removed after a period.
For more information refer to the below link:
https://www.intel.com/content/www/us/en/developer/articles/release-notes/oneapi-supported-product-versions.htm, and scroll down to the Unsupported Product Versions.
Intel® oneAPI users with active Intel Priority Support can access older versions via a secure portal you gain access to as part of your support subscription. Kindly refer below link for more details:
FAQ's Priority Support Link: https://www.intel.com/content/www/us/en/developer/get-help/faq-priority-support.html
Thanks for your suggestions.
Unfortunately, it is required to install these older versions. So, I can not go with these new versions. When I try to install oneapi basekit, the installation doesn't start, just showing the background of installations as shown in the attached image and then disappeared.
Hi Andi, could you please share the below details for further investigation:
- OS build on which you are installing the software
- Is the installer an online or an offline package?
- Intel® oneAPI release version
- Version of Microsoft Visual Studio installed along with it's build version
- Other versions of Intel® Parallel Studio XE or Intel® oneAPI already installed on the system
- Installation Log files.
- The default path for a log file for a oneAPI installation is: C:\Program Files (x86)\Intel\oneAPI\logs
- Windows 10
- Offline package
- Intel w_BaseKit_p_2021.3.0.3221_offline
- Microsoft Visual Studio 2019 Version 16.11.32
- None
- There is nothing in the default path, because when I try to install oneapi basekit, the installation doesn't start, just showing the background of installations and then disappeared.
Hi Andi, we have sent you a private message. Kindly check your inbox.
Hi Andi, unfortunately we were unable to hear back from you.
If you have any further query, please post a new question as this thread will no longer be monitored by Intel®.
