Hello team,
I'm using the following version of the oneAPI tools (windows):
base kit - 2021.2.0.2871
HPC kit - 2021.2.0.2901
using which I can compile and able to run my program successfully. Now I require the 32-bit base kit for compiling a 32-bit binary of my program.
I have tried the latest version of all three (base, HPC and 32-bit base) but that did not work well.
Could you point me to the 32-bit basekit version corresponding to the above basekit version.
Thank you
Manojkumar Annamalai
Hello Team,
Found that the libraries for 32-bit version is also available in the same installed location rather than as a separate installation. The problem is solved and I 'm able compile the 32-bit version of the program.
Hello Team,
Manojkumar, thank you for sharing the solution with us. We are glad that the issue has been resolved.
If you have any further queries, please post a new question as this thread will no longer be monitored by Intel®.
