I am trying to use pip to install the Intel oneAPI compilers on my windows 10 system via:
pip install intel-openmp==2021.3.0
pip install dpcpp_cpp_rt
pip install fortran_rt
and get the following error:
Installing collected packages: intel-openmp, impi-rt, common-cmplr-lic-rt, common-cmplr-lib-rt, fortran-rt
Attempting uninstall: intel-openmp
Found existing installation: intel-openmp 2021.3.0
Uninstalling intel-openmp-2021.3.0:
Successfully uninstalled intel-openmp-2021.3.0
Successfully installed common-cmplr-lib-rt-2021.2.0 common-cmplr-lic-rt-2021.2.0 fortran-rt-2021.2.0 impi-rt-2021.3.0 intel-openmp-2021.2.0
ERROR: pip's dependency resolver does not currently take into account all the packages that are installed. This behaviour is the source of the following dependency conflicts.
dpcpp-cpp-rt 2021.3.0 requires intel-openmp==2021.3.0, but you have intel-openmp 2021.2.0 which is incompatible.
Hi Zukaitis__Anthony,
Please try installing the required components using the below package names.
intel_openmp
intel_opencl_rt
intel_fortran_rt
intel_cmplr_lic_rt
intel_cmplr_lib_rt
dpcpp_cpp_rt
They have been tested and are installing correctly with pip.
If there are any connection errors, we would recommend trying again after disabling the system's VPN or other network restrictions that might have been enabled.
Soumya
Thanks for posting your concern on the forum. We are currently checking on it with our internal team. Please wait for 2-3 business days. We will get back to you as soon as possible.
Soumya
Apologies in the delay in getting back to you, I have opened a bug with engineering on this an am waiting to hear back.
Chris
We are still working with our internal team on the concern. We appreciate your patience while we are checking on the issue. Please wait for 2-3 business days. We will get back to you as soon as possible.
Soumya
intel_openmp
intel_opencl_rt
intel_fortran_rt
intel_cmplr_lic_rt
intel_cmplr_lib_rt
dpcpp_cpp_rt
Soumya
Please let us know if there are any further concerns.
Soumya
I assume that your issue is resolved. However, if you need any additional information, please post a new question as this thread will no longer be monitored by Intel®.
Have a nice day ahead.
Soumya
