oneAPI Registration, Download, Licensing and Installation
Support for Getting Started questions related to download, Installation and licensing for Intel oneAPI Toolkits and software development tools.
1643 Discussions
Windows Docker Image w_BaseKit_p_2024.2.0.635_offline.exe & w_HPCKit_p_2024.2.0.633_offline.exe
Hἑλκίον
Hello everyone!
I have same issue when creating a "trying" to create Docker Image similar to the
Re: Re:Installing IntelOneApi 2023 or 2023 on Windows Docker Container - Intel Community
The commands below are run in a Dockerfile:
cmd /C curl -SL --output C:\tools\w_BaseKit_p_2024.2.0.635_offline.exe https://registrationcenter-download.intel.com/akdlm/IRC_NAS/e83a8e64-04fc-45df-85c6-c2208d03bdb5/w_BaseKit_p_2024.2.0.635_offline.exe; \
cmd /C curl -SL --output C:\tools\w_HPCKit_p_2024.2.0.633_offline.exe https://registrationcenter-download.intel.com/akdlm/IRC_NAS/0d500705-397e-41b3-8b2b-2a3da1753fc2/w_HPCKit_p_2024.2.0.633_offline.exe; \
Start-Process -Wait -FilePath C:\tools\w_BaseKit_p_2024.2.0.635_offline.exe -ArgumentList '--silent', '-remove-extracted-files yes', '-a', '--silent', '--action=install', '--install-dir=C:/tools/intel', '--eula accept', '--components=intel.oneapi.win.dpcpp-compiler'; \
Start-Process -Wait -FilePath C:\tools\w_HPCKit_p_2024.2.0.633_offline.exe -ArgumentList '--silent', '-remove-extracted-files yes', '-a', '--silent', '--action=install', '--install-dir=C:/tools/intel', '--eula accept', '--components=intel.oneapi.win.ifort-compiler:intel.oneapi.win.cpp-compiler:intel.oneapi.win.mpi.devel'
The first Start-Process fails. It fails with return 1 (the logs shows that it adds a constant to it so it returns like 1001).
I am wondering if I need to install some other pre-requisites for that. Is not there a public sample out there that successfully install it on a Windows image? If so I appreciate you point me to it saving you time!:)
Kind regards
Hἑλκίον
I am using version of VS compiler Visual Studio 2019 Developer Command Prompt v16.11.38 is above the one supported as per https://www.intel.com/content/www/us/en/developer/articles/reference-implementation/intel-compilers-compatibility-with-microsoft-visual-studio-and-xcode.html
I have run Start-Process -Wait -FilePath C:\tools\w_BaseKit_p_2024.2.0.635_offline.exe -ArgumentList '--silent', '--log helcio.log', '-a', '--silent', '--list-components' on container and on my laptop and compared results as per attached image. The advantage of testing this command is that it seems not to require UAC (the box that asks for auth to install Software).
It fails with
01.08.2024 13:12:23 : 16840 : Finish
01.08.2024 13:12:23 : 16840 : WARNING : Return Code is overwrited by Setup.exe return code. [ret code] = 1000 + [setup.exe ret code]
01.08.2024 13:12:23 : 16840 : Return Code: 1001
The application that fails is C:\Users\ContainerAdministrator\Downloads\w_BaseKit_p_2024.2.0.635_offline (1)\bootstrapper.exe
Hἑλκίον
Ok I can confirm that using base image full server:ltsc2022-amd64. It won't work with server core.
Vipin_S_Intel
Hi Helcio, we have sent you a private message. Kindly check your community inbox.
Vipin_S_Intel
Hi Helcio, unfortunately, we were unable to hear back from you.
If you have any further queries, please post a new question, as this thread will no longer be monitored by Intel®.
