oneAPI Registration, Download, Licensing and Installation
Support for Getting Started questions related to download, Installation and licensing for Intel oneAPI Toolkits and software development tools.
1552 Discussions
Windows Installation hangs trying to use NTFS volume mount point
publiusrgj
    I have a clean install of Windows 11 Pro I was setting up, and installed Visual Studio and then was going to install the last Oneapi 2023 Intel C++ and Fortran compiler packages.
   I was trying to install over a path that included a NTFS volume mount point. The installer just hung, consuming a good bit of CPU and it had to be killed.  I tried some of the previous versions of these I had, oneapi 2022 versions and they all displayed the same behavior.
    Give it a normal path, and it installs without a hitch. There are differences between volume mount points, directory junctions, and softlinks,  the details of which I'm not up on, but this was a volume mount point type, an NTFS partition mounted on a directory on a drive mounted to a drive letter.
       Anyway, there is something the installer doesn't like about this.  Thanks.
Vipin_S_Intel
Hi Richard, Intel® has decided that Intel® oneAPI Toolkits Versions: 2023.1.0 and earlier are not supported anymore. We urge users to upgrade to the latest version of Intel® developer tools. The unsupported versions do not include the latest functional and security updates. These versions are targeted to be removed after a period. Users with active priority support can only access older product versions.
For more information refer to the link: https://www.intel.com/content/www/us/en/developer/articles/release-notes/oneapi-supported-product-versions.htm, and scroll down to the Unsupported Product Version.
Intel® oneAPI users with active Intel Priority Support can access older versions via a secure portal you gain access to as part of your support subscription.
FAQ's Priority Support Link: https://www.intel.com/content/www/us/en/developer/get-help/faq-priority-support.html
Vipin_S_Intel
Hi Richard, we have sent you a private message. Kindly check your community inbox.
Vipin_S_Intel
Hi Richard, unfortunately we were unable to hear back from you.
If you have any further query, please post a new question as this thread will no longer be monitored by Intel®.
