oneAPI Registration, Download, Licensing and Installation
Support for Getting Started questions for Intel oneAPI Toolkits, Intel Parallel Studio XE and Intel System Studio
apt install 32bit toolkit
qingfeng
when I use apt to install toolkit(32bit ,for example:intel-basekit-32bit ), there is a problem "Unable to locate package intel-basekit-32bit". apt can not find the intel-basekit-32bit toolkit.
I followed the instructions exactly, and the previous steps were correct.
Soumya_M_Intel
Hi qingfeng,
Thanks for posting your concern on the forum. Please try the below command.
  • sudo apt install intel-basekit-32bit
If the issue persists, try the below given.
  • sudo yum install intel-basekit-32bit
However, if the issue still persists, kindly get back to us with a copy of the input and output logs. It will allow us to check on the issue better.
Soumya
qingfeng
Hi Soumya,
    I use the command  "apt install intel-basekit-32bit " , but  there is a problem "Unable to locate package intel-basekit-32bit".
    However I use the command "apt install intel-basekit" , it is success.
    So I wonder intel-basekit-32bit this package is not in the link of sourcelist. And so it is .
Soumya_M_Intel
Hi qingfeng,
Thanks for getting back to us on the thread. Please try out the commands as a root user. Do let us know if the issue persists. Looking forward to your update.
Soumya
qingfeng
Hi Soumya
In fact, I try out the commands exactly as a root user . You can see the following screenshot .
qingfeng.
Soumya_M_Intel
Hi qingfeng,
Thanks for the screenshot. We are currently checking on the concern with our resources. Please wait for 2-3 business days. We will get back to you soon.
Soumya
Soumya_M_Intel
Hi qingfeng,
Thanks for your patience. We have tried to replicate the issue. However, it did not occur on our end. Please try out the below commands in the given order.
su
cd /tmp
wget https://apt.repos.intel.com/intel-gpg-keys/GPG-PUB-KEY-INTEL-SW-PRODUCTS.PUB
sudo apt-key add GPG-PUB-KEY-INTEL-SW-PRODUCTS.PUB
rm GPG-PUB-KEY-INTEL-SW-PRODUCTS.PUB
echo "deb https://apt.repos.intel.com/oneapi all main" | sudo tee /etc/apt/sources.list.d/oneAPI.list
Have a nice day ahead.
Soumya
Soumya_M_Intel
Hi qingfeng,
Please let us know if there are any further concerns.
Soumya
Soumya_M_Intel
Hi qingfeng,
We understand that you might be looking into the issue. However, this is to update you that we have not heard from you on our previous responses. Please reply within the next 24 business hours to keep this thread active.
Soumya
