Trying to install the basekit on a Docker image for use with some other packages. I've already put work into this Docker so I'd like to keep it
cat /proc/version
Linux version 4.19.121-linuxkit (root@buildkitsandbox) (gcc version 9.2.0 (Alpine 9.2.0))
When I run `apt install intel-basekit` I get the following error:
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
intel-basekit : Depends: intel-oneapi-onevpl-devel (>= 2021.1.1-66) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
So I tried installing the dependency intel-oneapi.-onevpl-devel and I get a similar error:
intel-oneapi-onevpl-devel-2021.1.1 : Depends: cmake (>= 3.10) but 3.5.1-1ubuntu3 is to be installed
I have cmake 3.19 installed and I tried cleaning my apt with `apt-get clean && apt-get update`, `apt-get upgrade` (no errors). I'm not sure where to go from here
If you are using Docker for your project then it is recommended to pull the oneAPI docker images.
They have an already pre-configured environment. Please follow the below link for more details.
https://github.com/intel/oneapi-containers
Do let us know if you have any other issues.
Warm Regards,
Abhishek
Hm I'd still like to avoid scraping the image I'm working on. Is there another way to pull the basekit?
We are moving this thread to the concerned team.
Warm Regards,
Abhishek
Hi Aisling,
I saw that my colleague already recommended the preconfigured oneAPI container. If you still want to build your own container you may start with the online installer option: https://software.intel.com/content/www/us/en/develop/tools/oneapi/base-toolkit/download.html#operatingsystem=Linux&#distributions=Web%20&%20Local%20(recommended)&#options=Online
This has the advantage that you can select/deselect the tools inside the distribution. If the onevpl (video processing lib.) caused trouble you can simply de-select this package.
Hope this helps,
Heinrich
For reference for anyone else, I ran into this same issue when trying to install the intel basekit package:
I thought I was running ubuntu 18.04, but actually was running 16.04. Upgrading to 18.04 resolved this installation issue for me.
