oneAPI Registration, Download, Licensing and Installation
Support for Getting Started questions related to download, Installation and licensing for Intel oneAPI Toolkits and software development tools.
cannot install HPC Toolkit
user5678
I am trying to install oneAPI HPC Toolkit and am not having any success.
The filename is w_HPCKit_p_2023.1.0.46357_offline.exe. (I also tried the non-offline version.)
I successfully installed w_BaseKit_p_2023.1.0.47256_offline.exe.
I have Visual Studio 2019 v16.11.26. I have Intel Parallel Studio (Fortran) installed.
Prior to Integrate IDE step, I get a warning "Intel Visual Fortran Compiler 19.1 Integration(s) in Microsoft Visual Studio is already installed". I click through that.
The install then runs but gets to "Intel oneAPI DPC++/C++ Compiler & Intel C++ Compiler Classic" during installation and then starts to rollback.
The install log has various warnings. I've copied the ones that contain the word "error" below; I can't attach the log file but can pull things if I know what to look for.
Any idea how to get this installed? Others here have had no issues, but they don't have the previous Fortran compiler.
LOG SET #1 (I removed the path info; I get this set of messages for various files:
06/05/2023 09:03:37:630 : 12280 : WARNING : <ManifestWrapper>: Can not load manifest '<<PATH>>/w_HPCKit_p_2023.1.0.46357_offline/packages/intel.oneapi.win.compiler.product,v=2023.1.0-46319/manifest.json', with error: 'Failed to load manifest file.
Cannot validate digital signature of JSON document <<PATH>>/w_HPCKit_p_2023.1.0.46357_offline/packages/intel.oneapi.win.compiler.product,v=2023.1.0-46319/manifest.json, signature is incorrect or signature file is missing.'
06/05/2023 09:03:37:630 : 12280 : MESSAGE : Skipping node for SizeFilter. Reason: Failed to load manifest file.
LOG SET #2 (including this because indicates an "error"; this is an offline install):
06/05/2023 09:03:38:198 : 14944 : MESSAGE : Remote link 'https://software.intel.com/content/www/us/en/develop/documentation/get-started-with-intel-oneapi-hpc-windows/top/before-you-begin.html?cid=oth&campid=iags_install&source=installer' is valid. Trying to establish the connection.
06/05/2023 09:03:38:610 : 14944 : MESSAGE : DownloadManager: check internet connections status [Unknown error] code [0] url [https://software.intel.com/content/www/us/en/develop/documentation/get-started-with-intel-oneapi-hpc-windows/top/before-you-begin.html?cid=oth&campid=iags_install&source=installer]
LOG SET #3:
06/05/2023 09:06:43:298 : 13456 : MESSAGE : Starting execution of operation 'intel.oneapi.win.compilers-common.ide.common_vs2019,v=2023.1.0-43533'.
06/05/2023 09:06:43:298 : 13456 : MESSAGE : Installation of 'intel.oneapi.win.compilers-common.ide.common_vs2019'.
... (skipping messages) ...
06/05/2023 09:06:43:298 : 13456 : MESSAGE : <MetaVariablesManager> Requested value for 'NEED_VS2019_INTEGRATION' (onlyLookup==False).
06/05/2023 09:06:43:298 : 13456 : MESSAGE : <MetaVariablesManager> Var 'NEED_VS2019_INTEGRATION' is not defined, moving to look in the parent environment
06/05/2023 09:06:43:298 : 13456 : MESSAGE : <MetaVariablesManager> Returning previously defined value '1'
06/05/2023 09:06:43:298 : 13456 : MESSAGE : Property 'NEED_VS2019_INTEGRATION' with value '1' is added to package manager command line arguments
06/05/2023 09:06:45:141 : 13456 : MESSAGE : Install process finished with status 0 and exit code 1.
06/05/2023 09:06:45:141 : 13456 : ERROR : Installation of component has failed.
Component id: intel.oneapi.win.compilers-common.ide.common_vs2019, name: IDE Common for Visual Studio 2019, version: 2023.1.0-43533.
Error: Sequence execution failed.
06/05/2023 09:06:45:141 : 13456 : MESSAGE : Operation 'intel.oneapi.win.compilers-common.ide.common_vs2019,v=2023.1.0-43533' execution is finished with status Fail.
06/05/2023 09:06:45:141 : 13456 : ERROR : <StandardSequenceExecutor>: 'intel.oneapi.win.compilers-common.ide.common_vs2019,v=2023.1.0-43533' execution is failed. Rolling back all previous operations.
ArpanB_Intel
Hi user5678, please share the below information with us:
- OS build on which you are installing the software
- Is the installer an online or an offline package?
- Version of Microsoft Visual Studio installed along with it's build version
- Other versions of Intel® Parallel Studio XE or Intel® oneAPI already installed on the system
- Screenshots of the error screen
- Installation Log files.
The default path for a log file for a oneAPI installation is: C:\Program Files (x86)\Intel\oneAPI\logs
The default path for a log file for a Parallel Studio XE installation is: %temp%\pset_tmp_PSXE<version>_<username>
We would like to know.
user5678
Hello.  Thanks for responding.
Here are responses to your questions:
  • The OS is Windows 10 v22H2.
  • I tried both the online and offline installer; same results.
  • Visual Studio 2019 v16.11.26.
  • Both Intel Parallel Studio XE 2015 and Intel Parallel Studio XE 2020 Update 1 are installed.
  • I have attached the error screen.
  • I cannot attach the log files, but I can pull entries.  Please see my original post for the ones that mentioned errors/non-0 exit codes.  Are there others that would be useful?
  • I did not find any %temp%\pset_tmp_PSXE* files or directories.
My Visual Studio now displays popups when I open my solution.  I've attached that too.
ArpanB_Intel
user5678, thank you for the update.
We will test the combination and share an update with you regarding this error as early as possible.
user5678
Hi.  I was wondering if there is any update?
I am getting close to try uninstalling, but I am unclear if that will require uninstalling Visual Studio.
ArpanB_Intel
Hi, please follow the below steps for uninstallation:
  • Close Intel® installers if any
  • Uninstall all Microsoft Visual Studio instances and Visual Studio Installer
  • Important: Check that C:\ProgramData\Microsoft\VisualStudio\Setup\x86\Microsoft.VisualStudio.Setup.Configuration.Native.dll does not exist anymore. If it was not removed with Microsoft Visual Studio for some reason, please unregister the DLL using
REGSVR32 /U C:\ProgramData\Microsoft\VisualStudio\Setup\x86\Microsoft.VisualStudio.Setup.Configuration.Native.dll
command in Command Prompt as Administrator, and then rename the file to Backup_Microsoft.VisualStudio.Setup.Configuration.Native.dll so the Intel® Installer can't load it.
ArpanB_Intel
Hi, unfortunately we were unable to hear back from you.
If you have any further queries, please post a new question as this thread will no longer be monitored by Intel®.
