and here the log:
08/06/2023 01:57:21:553 : 32 : MESSAGE : C:\Program Files (x86)\Intel\oneAPI\Installer\installer.exe is run with arguments: --log-dir C:/Users/User/AppData/Local/Temp/intel_oneapi_installer/2023.08.06.01.57.13.571 --product-id intel.oneapi.win.python3.product --product-ver 2023.2.0-49421 --package-path C:\Users\User\AppData\Local\Temp\w_pythoni39_oneapi_p_2023.2.0.49423_2023-08-06_01-57-13\packages
08/06/2023 01:57:21:553 : 32 : MESSAGE : Installer is started in GUI mode
08/06/2023 01:57:21:553 : 32 : MESSAGE : Installer executable location is C:\Program Files (x86)\Intel\oneAPI\Installer\installer.exe, version is 4.3.2.892
08/06/2023 01:57:21:553 : 32 : MESSAGE : Package manager executable location is C:\Program Files (x86)\Intel\PackageManager\1.0\packagemanager.exe, version is 4.3.2-892
08/06/2023 01:57:21:553 : 32 : MESSAGE : Product is set to intel.oneapi.win.python3.product,v=2023.2.0-49421. Mode is set to install.
08/06/2023 01:57:21:787 : 20220 : MESSAGE : PreRequisite for other install successfully checked
08/06/2023 01:57:21:792 : 20220 : MESSAGE : PreRequisite for other Intel install successfully checked
08/06/2023 01:57:21:794 : 20220 : MESSAGE : All checks for preRequisite for supported operation system are passed
08/06/2023 01:57:23:052 : 20220 : MESSAGE : PreRequisite for admin rights successfully checked
08/06/2023 01:57:23:053 : 20220 : MESSAGE : PreRequisite for temporary folder successfully checked
08/06/2023 01:57:23:053 : 20220 : MESSAGE : PreRequisite for host architecture successfully checked
08/06/2023 01:57:23:103 : 32 : MESSAGE : The following products are installed by the moment:
Id: intel.oneapi.win.basekit.product, name: Intel® oneAPI Base Toolkit, version: 2023.2, installation directory: C:\Program Files (x86)\Intel\oneAPI
End of installed products list.
08/06/2023 01:57:47:203 : 9932 : MESSAGE : PreRequisite for Instance Msi successfully checked
08/06/2023 01:57:54:245 : 9932 : MESSAGE : PreRequisite for free disk space passed
08/06/2023 01:57:54:245 : 9932 : MESSAGE : PreRequisite for permissions passed
08/06/2023 01:57:54:246 : 9932 : MESSAGE : PreRequisite for other install successfully checked
08/06/2023 01:57:54:246 : 9932 : MESSAGE : PreRequisite for other Intel install successfully checked
08/06/2023 01:57:54:271 : 32 : MESSAGE : ISIP consent status is 'No'
08/06/2023 01:57:54:272 : 32 : MESSAGE : Product installation directory is C:\Program Files (x86)\Intel\oneAPI
08/06/2023 01:57:54:272 : 32 : MESSAGE : Product download size required: 263169396 bytes
08/06/2023 01:57:54:272 : 32 : MESSAGE : Product installation size required: 11265009425 bytes
08/06/2023 01:57:54:272 : 32 : MESSAGE : Product will be (un)integrated with the following IDEs:
08/06/2023 01:57:54:272 : 32 : MESSAGE : Microsoft Visual Studio* 2022
08/06/2023 01:57:54:272 : 32 : MESSAGE : Microsoft C++ Build Tools* 2022
08/06/2023 01:57:54:272 : 32 : MESSAGE : End of IDE list.
08/06/2023 01:57:54:279 : 9932 : MESSAGE : Graph State Dump.
intel.oneapi.win.python3.product,v=2023.2.0-49421, Enabled, Selected, Not Installed
intel.oneapi.win.python3,v=2023.2.0-49421, Enabled, Selected, Not Installed
intel.oneapi.win.openmp,v=2023.2.0-49496, Enabled, Selected, Installed
intel.oneapi.win.condaindex,v=2023.2.0-49398, Enabled, Selected, Installed
intel.oneapi.win.oneapi-common.vars,v=2023.2.0-49463, Enabled, Selected, Installed
intel.oneapi.win.oneapi-common.licensing,v=2023.2.0-49463, Enabled, Selected, Installed
intel.oneapi.win.dal.daal4py,v=2023.2.0-49573, Enabled, Selected, Not Installed
intel.oneapi.win.dal.runtime,v=2023.2.0-49573, Enabled, Selected, Installed
intel.oneapi.win.tbb.runtime,v=2021.10.0-49542, Enabled, Selected, Installed
intel.oneapi.win.tbb.devel,v=2021.10.0-49542, Enabled, Selected, Installed
intel.oneapi.win.cpp-compiler.ide.vcperflib_vsix_vs2019,v=2023.2.0-49074, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.vcperflib_vsix_vs2022,v=2023.2.0-49074, Enabled, Selected, Installed
intel.oneapi.win.cpp-compiler.ide.vcperflib_bt_vs2019,v=2023.2.0-49074, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.vcperflib_bt_vs2022,v=2023.2.0-49074, Enabled, Selected, Installed
intel.oneapi.win.compilers-common.ide.regupdater,v=2023.2.0-49074, Enabled, Selected, Installed
intel.oneapi.win.dal.skleranex,v=2023.2.0-49573, Enabled, Selected, Not Installed
intel.oneapi.win.mpi.runtime,v=2021.10.0-49372, Enabled, Selected, Not Installed
intel.oneapi.win.mkl.runtime,v=2023.2.0-49496, Enabled, Selected, Installed
intel.oneapi.win.cpp-base-pro-common-runtime,v=2023.2.0-49496, Enabled, Selected, Installed
intel.oneapi.win.compilers-common-runtime,v=2023.2.0-49496, Enabled, Selected, Installed
intel.oneapi.win.ipp.runtime,v=2021.9.0-49453, Enabled, Selected, Installed
08/06/2023 01:57:54:281 : 9932 : MESSAGE : Operations dump.
Updating package state...
Preparing installation...
Protecting installation location...
Finalizing removal. It may take up to 5 minutes...
Install intel.oneapi.win.condaindex,v=2023.2.0-49398
Install intel.oneapi.win.oneapi-common.vars,v=2023.2.0-49463
Install intel.oneapi.win.oneapi-common.licensing,v=2023.2.0-49463
Install intel.oneapi.win.openmp,v=2023.2.0-49496
Install intel.oneapi.win.dal.daal4py,v=2023.2.0-49573
Install intel.oneapi.win.tbb.runtime,v=2021.10.0-49542
Install intel.oneapi.win.cpp-compiler.ide.vcperflib_vsix_vs2022,v=2023.2.0-49074
Install intel.oneapi.win.cpp-compiler.ide.vcperflib_bt_vs2022,v=2023.2.0-49074
Install intel.oneapi.win.compilers-common.ide.regupdater,v=2023.2.0-49074
Install intel.oneapi.win.tbb.devel,v=2021.10.0-49542
Install intel.oneapi.win.dal.runtime,v=2023.2.0-49573
Install intel.oneapi.win.dal.skleranex,v=2023.2.0-49573
Install intel.oneapi.win.mpi.runtime,v=2021.10.0-49372
Install intel.oneapi.win.compilers-common-runtime,v=2023.2.0-49496
Install intel.oneapi.win.cpp-base-pro-common-runtime,v=2023.2.0-49496
Install intel.oneapi.win.mkl.runtime,v=2023.2.0-49496
Install intel.oneapi.win.ipp.runtime,v=2021.9.0-49453
Install intel.oneapi.win.python3,v=2023.2.0-49421
Install intel.oneapi.win.python3.product,v=2023.2.0-49421
Finalizing. It may take up to 10 minutes or more to integrate with your system, please do not interrupt the install process...
08/06/2023 01:57:54:374 : 9932 : MESSAGE : Start install/modify sequence execution.
08/06/2023 01:57:54:466 : 9932 : MESSAGE : Starting execution of operation 'update_state.operation.intel.sessionmanifest.1691279874279358'.
08/06/2023 01:57:54:466 : 9932 : MESSAGE : Operation 'update_state.operation.intel.sessionmanifest.1691279874279358' execution is finished with status Success.
08/06/2023 01:57:54:466 : 9932 : MESSAGE : Starting execution of operation 'prepare.operation.intel.sessionmanifest.1691279874279358'.
08/06/2023 01:57:54:466 : 9932 : MESSAGE : Operation 'prepare.operation.intel.sessionmanifest.1691279874279358' execution is finished with status Success.
08/06/2023 01:57:54:466 : 9932 : MESSAGE : Starting execution of operation 'protect.operation.intel.sessionmanifest.1691279874279358'.
08/06/2023 01:58:03:652 : 9932 : MESSAGE : Operation 'protect.operation.intel.sessionmanifest.1691279874279358' execution is finished with status Success.
08/06/2023 01:58:03:652 : 9932 : MESSAGE : Starting execution of operation 'complete.operation.intel.sessionmanifest.1691279874279360'.
08/06/2023 01:58:03:652 : 9932 : MESSAGE : Operation 'complete.operation.intel.sessionmanifest.1691279874279360' execution is finished with status Success.
08/06/2023 01:58:03:653 : 9932 : MESSAGE : Starting execution of operation 'intel.oneapi.win.condaindex,v=2023.2.0-49398'.
08/06/2023 01:58:03:930 : 9932 : MESSAGE : Operation 'intel.oneapi.win.condaindex,v=2023.2.0-49398' execution is finished with status Success.
08/06/2023 01:58:03:930 : 9932 : MESSAGE : Starting execution of operation 'intel.oneapi.win.oneapi-common.vars,v=2023.2.0-49463'.
08/06/2023 01:58:04:217 : 9932 : MESSAGE : Operation 'intel.oneapi.win.oneapi-common.vars,v=2023.2.0-49463' execution is finished with status Success.
08/06/2023 01:58:04:217 : 9932 : MESSAGE : Starting execution of operation 'intel.oneapi.win.oneapi-common.licensing,v=2023.2.0-49463'.
08/06/2023 01:58:04:439 : 9932 : MESSAGE : Operation 'intel.oneapi.win.oneapi-common.licensing,v=2023.2.0-49463' execution is finished with status Success.
08/06/2023 01:58:04:439 : 9932 : MESSAGE : Starting execution of operation 'intel.oneapi.win.openmp,v=2023.2.0-49496'.
08/06/2023 01:58:04:669 : 9932 : MESSAGE : Operation 'intel.oneapi.win.openmp,v=2023.2.0-49496' execution is finished with status Success.
08/06/2023 01:59:34:181 : 9932 : MESSAGE : Starting execution of operation 'intel.oneapi.win.dal.daal4py,v=2023.2.0-49573'.
08/06/2023 01:59:45:610 : 9932 : MESSAGE : Operation 'intel.oneapi.win.dal.daal4py,v=2023.2.0-49573' execution is finished with status Success.
08/06/2023 01:59:45:610 : 9932 : MESSAGE : Starting execution of operation 'intel.oneapi.win.tbb.runtime,v=2021.10.0-49542'.
08/06/2023 01:59:45:860 : 9932 : MESSAGE : Operation 'intel.oneapi.win.tbb.runtime,v=2021.10.0-49542' execution is finished with status Success.
08/06/2023 01:59:45:860 : 9932 : MESSAGE : Starting execution of operation 'intel.oneapi.win.cpp-compiler.ide.vcperflib_vsix_vs2022,v=2023.2.0-49074'.
08/06/2023 01:59:46:074 : 9932 : MESSAGE : Operation 'intel.oneapi.win.cpp-compiler.ide.vcperflib_vsix_vs2022,v=2023.2.0-49074' execution is finished with status Success.
08/06/2023 01:59:46:074 : 9932 : MESSAGE : Starting execution of operation 'intel.oneapi.win.cpp-compiler.ide.vcperflib_bt_vs2022,v=2023.2.0-49074'.
08/06/2023 01:59:46:289 : 9932 : MESSAGE : Operation 'intel.oneapi.win.cpp-compiler.ide.vcperflib_bt_vs2022,v=2023.2.0-49074' execution is finished with status Success.
08/06/2023 01:59:46:289 : 9932 : MESSAGE : Starting execution of operation 'intel.oneapi.win.compilers-common.ide.regupdater,v=2023.2.0-49074'.
08/06/2023 01:59:46:479 : 9932 : MESSAGE : Operation 'intel.oneapi.win.compilers-common.ide.regupdater,v=2023.2.0-49074' execution is finished with status Success.
08/06/2023 01:59:46:479 : 9932 : MESSAGE : Starting execution of operation 'intel.oneapi.win.tbb.devel,v=2021.10.0-49542'.
08/06/2023 01:59:46:711 : 9932 : MESSAGE : Operation 'intel.oneapi.win.tbb.devel,v=2021.10.0-49542' execution is finished with status Success.
08/06/2023 01:59:46:711 : 9932 : MESSAGE : Starting execution of operation 'intel.oneapi.win.dal.runtime,v=2023.2.0-49573'.
08/06/2023 01:59:46:959 : 9932 : MESSAGE : Operation 'intel.oneapi.win.dal.runtime,v=2023.2.0-49573' execution is finished with status Success.
08/06/2023 01:59:46:959 : 9932 : MESSAGE : Starting execution of operation 'intel.oneapi.win.dal.skleranex,v=2023.2.0-49573'.
08/06/2023 01:59:52:104 : 9932 : MESSAGE : Operation 'intel.oneapi.win.dal.skleranex,v=2023.2.0-49573' execution is finished with status Success.
08/06/2023 01:59:52:104 : 9932 : MESSAGE : Starting execution of operation 'intel.oneapi.win.mpi.runtime,v=2021.10.0-49372'.
08/06/2023 02:00:00:298 : 9932 : MESSAGE : Operation 'intel.oneapi.win.mpi.runtime,v=2021.10.0-49372' execution is finished with status Success.
08/06/2023 02:00:00:298 : 9932 : MESSAGE : Starting execution of operation 'intel.oneapi.win.compilers-common-runtime,v=2023.2.0-49496'.
08/06/2023 02:00:00:614 : 9932 : MESSAGE : Operation 'intel.oneapi.win.compilers-common-runtime,v=2023.2.0-49496' execution is finished with status Success.
08/06/2023 02:00:00:614 : 9932 : MESSAGE : Starting execution of operation 'intel.oneapi.win.cpp-base-pro-common-runtime,v=2023.2.0-49496'.
08/06/2023 02:00:00:930 : 9932 : MESSAGE : Operation 'intel.oneapi.win.cpp-base-pro-common-runtime,v=2023.2.0-49496' execution is finished with status Success.
08/06/2023 02:00:00:930 : 9932 : MESSAGE : Starting execution of operation 'intel.oneapi.win.mkl.runtime,v=2023.2.0-49496'.
08/06/2023 02:00:01:227 : 9932 : MESSAGE : Operation 'intel.oneapi.win.mkl.runtime,v=2023.2.0-49496' execution is finished with status Success.
08/06/2023 02:00:01:227 : 9932 : MESSAGE : Starting execution of operation 'intel.oneapi.win.ipp.runtime,v=2021.9.0-49453'.
08/06/2023 02:00:01:523 : 9932 : MESSAGE : Operation 'intel.oneapi.win.ipp.runtime,v=2021.9.0-49453' execution is finished with status Success.
08/06/2023 02:00:48:025 : 9932 : MESSAGE : Starting execution of operation 'intel.oneapi.win.python3,v=2023.2.0-49421'.
08/06/2023 02:03:22:788 : 9932 : ERROR : Installation of component has failed.
Component id: intel.oneapi.win.python3, name: Intel® Distribution for Python*, version: 2023.2.0-49421.
Error: Sequence execution failed.
08/06/2023 02:03:22:788 : 9932 : MESSAGE : Operation 'intel.oneapi.win.python3,v=2023.2.0-49421' execution is finished with status Fail.
08/06/2023 02:03:22:788 : 9932 : MESSAGE : Starting rollback of operation 'intel.oneapi.win.ipp.runtime,v=2021.9.0-49453'.
08/06/2023 02:03:22:995 : 9932 : MESSAGE : Operation 'intel.oneapi.win.ipp.runtime,v=2021.9.0-49453' rollback is finished with status Success.
08/06/2023 02:03:22:995 : 9932 : MESSAGE : Starting rollback of operation 'intel.oneapi.win.mkl.runtime,v=2023.2.0-49496'.
08/06/2023 02:03:23:150 : 9932 : MESSAGE : Operation 'intel.oneapi.win.mkl.runtime,v=2023.2.0-49496' rollback is finished with status Success.
08/06/2023 02:03:23:150 : 9932 : MESSAGE : Starting rollback of operation 'intel.oneapi.win.cpp-base-pro-common-runtime,v=2023.2.0-49496'.
08/06/2023 02:03:23:305 : 9932 : MESSAGE : Operation 'intel.oneapi.win.cpp-base-pro-common-runtime,v=2023.2.0-49496' rollback is finished with status Success.
08/06/2023 02:03:23:305 : 9932 : MESSAGE : Starting rollback of operation 'intel.oneapi.win.compilers-common-runtime,v=2023.2.0-49496'.
08/06/2023 02:03:23:466 : 9932 : MESSAGE : Operation 'intel.oneapi.win.compilers-common-runtime,v=2023.2.0-49496' rollback is finished with status Success.
08/06/2023 02:03:23:466 : 9932 : MESSAGE : Starting rollback of operation 'intel.oneapi.win.mpi.runtime,v=2021.10.0-49372'.
08/06/2023 02:03:30:737 : 9932 : MESSAGE : Operation 'intel.oneapi.win.mpi.runtime,v=2021.10.0-49372' rollback is finished with status Success.
08/06/2023 02:03:30:737 : 9932 : MESSAGE : Starting rollback of operation 'intel.oneapi.win.dal.skleranex,v=2023.2.0-49573'.
08/06/2023 02:03:34:684 : 9932 : MESSAGE : Operation 'intel.oneapi.win.dal.skleranex,v=2023.2.0-49573' rollback is finished with status Success.
08/06/2023 02:03:34:684 : 9932 : MESSAGE : Starting rollback of operation 'intel.oneapi.win.dal.runtime,v=2023.2.0-49573'.
08/06/2023 02:03:34:846 : 9932 : MESSAGE : Operation 'intel.oneapi.win.dal.runtime,v=2023.2.0-49573' rollback is finished with status Success.
08/06/2023 02:03:34:846 : 9932 : MESSAGE : Starting rollback of operation 'intel.oneapi.win.tbb.devel,v=2021.10.0-49542'.
08/06/2023 02:03:35:009 : 9932 : MESSAGE : Operation 'intel.oneapi.win.tbb.devel,v=2021.10.0-49542' rollback is finished with status Success.
08/06/2023 02:03:35:009 : 9932 : MESSAGE : Starting rollback of operation 'intel.oneapi.win.compilers-common.ide.regupdater,v=2023.2.0-49074'.
08/06/2023 02:03:35:169 : 9932 : MESSAGE : Operation 'intel.oneapi.win.compilers-common.ide.regupdater,v=2023.2.0-49074' rollback is finished with status Success.
08/06/2023 02:03:35:169 : 9932 : MESSAGE : Starting rollback of operation 'intel.oneapi.win.cpp-compiler.ide.vcperflib_bt_vs2022,v=2023.2.0-49074'.
08/06/2023 02:03:35:332 : 9932 : MESSAGE : Operation 'intel.oneapi.win.cpp-compiler.ide.vcperflib_bt_vs2022,v=2023.2.0-49074' rollback is finished with status Success.
08/06/2023 02:03:35:332 : 9932 : MESSAGE : Starting rollback of operation 'intel.oneapi.win.cpp-compiler.ide.vcperflib_vsix_vs2022,v=2023.2.0-49074'.
08/06/2023 02:03:35:493 : 9932 : MESSAGE : Operation 'intel.oneapi.win.cpp-compiler.ide.vcperflib_vsix_vs2022,v=2023.2.0-49074' rollback is finished with status Success.
08/06/2023 02:03:35:493 : 9932 : MESSAGE : Starting rollback of operation 'intel.oneapi.win.tbb.runtime,v=2021.10.0-49542'.
08/06/2023 02:03:35:657 : 9932 : MESSAGE : Operation 'intel.oneapi.win.tbb.runtime,v=2021.10.0-49542' rollback is finished with status Success.
08/06/2023 02:03:35:657 : 9932 : MESSAGE : Starting rollback of operation 'intel.oneapi.win.dal.daal4py,v=2023.2.0-49573'.
08/06/2023 02:03:39:364 : 9932 : MESSAGE : Operation 'intel.oneapi.win.dal.daal4py,v=2023.2.0-49573' rollback is finished with status Success.
08/06/2023 02:03:39:364 : 9932 : MESSAGE : Starting rollback of operation 'intel.oneapi.win.openmp,v=2023.2.0-49496'.
08/06/2023 02:03:39:541 : 9932 : MESSAGE : Operation 'intel.oneapi.win.openmp,v=2023.2.0-49496' rollback is finished with status Success.
08/06/2023 02:03:39:541 : 9932 : MESSAGE : Starting rollback of operation 'intel.oneapi.win.oneapi-common.licensing,v=2023.2.0-49463'.
08/06/2023 02:03:39:720 : 9932 : MESSAGE : Operation 'intel.oneapi.win.oneapi-common.licensing,v=2023.2.0-49463' rollback is finished with status Success.
08/06/2023 02:03:39:720 : 9932 : MESSAGE : Starting rollback of operation 'intel.oneapi.win.oneapi-common.vars,v=2023.2.0-49463'.
08/06/2023 02:03:39:890 : 9932 : MESSAGE : Operation 'intel.oneapi.win.oneapi-common.vars,v=2023.2.0-49463' rollback is finished with status Success.
08/06/2023 02:03:39:890 : 9932 : MESSAGE : Starting rollback of operation 'intel.oneapi.win.condaindex,v=2023.2.0-49398'.
08/06/2023 02:03:40:063 : 9932 : MESSAGE : Operation 'intel.oneapi.win.condaindex,v=2023.2.0-49398' rollback is finished with status Success.
08/06/2023 02:03:40:063 : 9932 : MESSAGE : Starting rollback of operation 'complete.operation.intel.sessionmanifest.1691279874279360'.
08/06/2023 02:03:40:181 : 9932 : MESSAGE : Operation 'complete.operation.intel.sessionmanifest.1691279874279360' rollback is finished with status Success.
08/06/2023 02:03:40:181 : 9932 : MESSAGE : Starting rollback of operation 'protect.operation.intel.sessionmanifest.1691279874279358'.
08/06/2023 02:03:40:181 : 9932 : MESSAGE : Operation 'protect.operation.intel.sessionmanifest.1691279874279358' rollback is finished with status Success.
08/06/2023 02:03:40:181 : 9932 : MESSAGE : Starting rollback of operation 'prepare.operation.intel.sessionmanifest.1691279874279358'.
08/06/2023 02:03:40:181 : 9932 : MESSAGE : Operation 'prepare.operation.intel.sessionmanifest.1691279874279358' rollback is finished with status Success.
08/06/2023 02:03:40:181 : 9932 : MESSAGE : Starting rollback of operation 'update_state.operation.intel.sessionmanifest.1691279874279358'.
08/06/2023 02:03:40:181 : 9932 : MESSAGE : Operation 'update_state.operation.intel.sessionmanifest.1691279874279358' rollback is finished with status Success.
08/06/2023 02:03:40:181 : 9932 : ERROR : Install sequence execution status: Rollback
08/06/2023 02:03:40:211 : 32 : MESSAGE : ----------------------------------------------------------------------------------------------------
08/06/2023 02:03:40:211 : 32 : MESSAGE : Anonymous statistics fields:
08/06/2023 02:03:40:211 : 32 : MESSAGE : EventId = 'install-min'
08/06/2023 02:03:40:211 : 32 : MESSAGE : EventKey = 'S3UqiDQDs0egwqo7y1z17w=='
08/06/2023 02:03:40:211 : 32 : MESSAGE : EventTime = ''
08/06/2023 02:03:40:211 : 32 : MESSAGE : Id = 'intel.oneapi.win.python3.product,v=2023.2.0-49421'
08/06/2023 02:03:40:211 : 32 : MESSAGE : Message = '{ \"product_name\":\"[Windows] Intel® Distribution for Python* 2023.2.0\", \"lic_type\":\"\", \"support_code\":\"\", \"install_status\":\"4355\", \"product_tag\":\"\" }'
08/06/2023 02:03:40:211 : 32 : MESSAGE : ProductId = '[Windows] Intel® Distribution for Python* 2023.2.0'
08/06/2023 02:03:40:212 : 32 : MESSAGE : ----------------------------------------------------------------------------------------------------
Hi Jona, please share the below information with us:
- OS build on which you are installing the software
- Is the installer an online or an offline package?
- Version of Microsoft Visual Studio installed along with it's build version
- Other versions of Intel® Parallel Studio XE or Intel® oneAPI already installed on the system
- Screenshots of the error screen
- Installation Log files apart from the one you shared
The default path for a log file for a oneAPI installation is: C:\Program Files (x86)\Intel\oneAPI\logs
The default path for a log file for a Parallel Studio XE installation is: %temp%\pset_tmp_PSXE<version>_<username>
We would like to know.
-Windows 10 Pro
-online package
-Microsoft Visual Studio Community 2022 (64-bit) - Current
Version 17.5.1
-2023.2.0
Jona, thank you for sharing the information. We will check the files and share our findings soon.
Jona, please follow the below steps:
1. Close Intel® installers if any
2. Remove any & all Visual Studio installers for now.
3. Important: Check that C:\ProgramData\Microsoft\VisualStudio\Setup\x86\Microsoft.VisualStudio.Setup.Configuration.Native.dll does not exist anymore. If it was not removed with Microsoft Visual Studio uninstallation for some reason, please unregister the DLL using: REGSVR32 /U C:\ProgramData\Microsoft\VisualStudio\Setup\x86\Microsoft.VisualStudio.Setup.Configuration.Native.dll
4. In Command Prompt, as Administrator, rename the file to Backup_Microsoft.VisualStudio.Setup.Configuration.Native.dll so the Intel® Installer can't load it.
5. Try uninstalling older Intel® oneAPI toolkits now using the installer.
Install a compatible Visual Studio version after that and when done, repair the installed toolkits to integrate them. Please note, our engineering team has tested and documented the compatible Visual Studio versions and their build numbers for integration with the suite & toolkit versions. Therefore, we would recommend you to check & choose from them via the below link.
Intel® Compilers Compatibility with Microsoft Visual Studio* Link: https://www.intel.com/content/www/us/en/developer/articles/reference-implementation/intel-compilers-compatibility-with-microsoft-visual-studio-and-xcode.html
Jona, unfortunately we were unable to hear back from you.
If you have any further queries, please post a new question as this thread will no longer be monitored by Intel®.
