I want to install base toolkits on my centos7.9.2009 linux server
After wget l_BaseKit_p_2024.1.0.596_offline.sh and ran "sudo bash l_BaseKit_p_2024.1.0.596_offline.sh”, I got error:
Extract l_BaseKit_p_2024.1.0.596_offline completed!
Could not detect graphical display, installation will continue in console mode. If you aim to launch the installer graphical user interface under root try `xhost si:localuser:root` command and then restart the application.
Checking system requirements...
Done.
Wait while the installer is preparing...
Done.
Launching the installer...
*** Error in `/opt/intel/oneapi/installer/installer': munmap_chunk(): invalid pointer: 0x00007f70507f46eb ***
It seems like there is something wrong with libc or the installer.
What should I do to finish my installation?
Hi Qiji, please note that CentOS operating system is not compatible with Intel® oneAPI Base Toolkit. These OS distributions are tested by Intel or known to work; other distributions may or may not work and are not recommended.
Kindly refer to the below system requirement link.
Please find the below Intel® oneAPI Toolkits Installation Guide for Linux* OS
