dear sir:
i encountered the installation issues while i was tring install the l_BaseKit_p_2022.2.0.262_offline.sh version in CentOS Linux release 7.9.2009 release.
i used the normal command ( "sudo sh ./l_BaseKit_p_2022.2.0.262_offline.sh" ) to install , it stucked after the extracted packages forever.
Extract l_BaseKit_p_2022.2.0.262_offline to /usr/local/src/l_BaseKit_p_2022.2.0.262_offline...
Extract l_BaseKit_p_2022.2.0.262_offline completed!
i used the following command to install, it went throguh okay from beginning.
# sudo sh l_BaseKit_p_2022.2.0.262_offline.sh -a -c --eula accept --log-dir=.
somehow, it sucked in the following step :
Installation Complete | Intel® oneAPI
The following tools have been install
Intel® oneAPI Base Toolkit
Installation location: /opt/intel/one
the following is one of the installation logs :
# tail installer.2022.08.12.11.50.01.491646.log
08/12/2022 12:38:51:284 : 120491 : MESSAGE : Stop waiting Progress
08/12/2022 12:38:51:284 : 120491 : MESSAGE : Hide progress screen
08/12/2022 12:38:51:285 : 119387 : MESSAGE : CLI: Start new screen
08/12/2022 12:38:51:285 : 119387 : MESSAGE : Connect screen signals
08/12/2022 12:38:51:286 : 119387 : MESSAGE : Connect installation complete screen signals
08/12/2022 12:38:51:289 : 149227 : MESSAGE : CLI screen: run input processor
08/12/2022 12:38:52:445 : 119387 : MESSAGE : DownloadManager: Completed post request to 'https://ircws.intel.com/wsregcentertools/wsRegCenterISIP.asmx/RecordISIPData?deviceId=00000000-0000-0000-0000-000000000001'.
08/12/2022 12:38:52:445 : 119387 : MESSAGE : DM response code: [0]
08/12/2022 12:38:52:445 : 119387 : MESSAGE : SendStatistics: sending anonymous statistics finished with result 0
08/12/2022 12:38:52:445 : 119387 : MESSAGE : Application CLI : processing statistics is finished
it looks like i could use the one api without problems. just wounder which environment cuased the above problems.
if you know, please tell me. thank you in advance.
Hi Sam, could you share the installation log file with us. The default path would be:
opt/intel/oneapi/logs
Sam, unfortunately we were unable to hear back from you.
If you have any further queries, please post a new question as this thread will no longer be monitored by Intel®.
