oneAPI Registration, Download, Licensing and Installation
Support for Getting Started questions related to download, Installation and licensing for Intel oneAPI Toolkits and software development tools.
intel driver & support assistant
jura1
Este aplicativo  driver  atualizaçoes, "intel driver & support assistant",  Esta impedindo
que o USB seja ejetado com segurança , ja deixou dois hd externo no formato RAW,
desinstalei e reinstalei mas nao resolveu, agora deixo como esta na imagem, desativado.
Como  este problema pode ser resolvido ?
Victor_G_Intel
Hello jura1,
In order to better assist you please provide the following report and information so we can move forward.
-Intel® System Support Utility (Intel® SSU)
Download link: https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
•          Open the application and click on "Scan" to see the system and device information
•          By default, Intel® SSU will take you to the "Summary View".
•          Click on the menu where it says "Summary" to change to "Detailed View".
•          To save your scan, click on "Next", then "Save".
Use the option under the reply window to attach the report to the thread (Drag and drop here or browse files to attach).
- Can you please confirm how did you determine that the cause of the USB not been able to be removed safely was because the Intel® Driver & Support Assistant (Intel® DSA) was enabled in the background?
Important note: Our support is only provided in English. We may not be able to translate the screenshots attached to the thread. To better assist you, we use a translation tool.
 I look forward to hearing from you.
Victor G.
Intel Technical Support Technician
Victor_G_Intel
Hello jura1,
Please let me know if you need further assistance.
Victor G.
Victor_G_Intel
Hello jura1,
We have not heard back from you.
If you need any additional information, please submit a new question as this thread will no longer be monitored
Victor G.
