Hi PatrickE,
Thanks for posting your concern on the forum. Please provide the below information.
- The operating system's complete name, version and architecture.
- A copy of the error output.
- Are you trying to install using the online or offline package?
The above details would allow us to check further.
Have a pleasant day ahead!
Dilanjan
Hello Dilanjan,
Red Hat Enterprise Linux Workstation 7.7 with kernel version 3.10.0-1062.el7.x86_64
The entire log with errors is attached in the question I have.
We are using the offline package. We had no problems with the Base Kit.
Best regards
Hi PatrickE,
Thanks for the information. Please also share the version of the Intel® oneApi Base toolkit you have installed.
Have a pleasant day!
Dilanjan
Hello Dalinjan,
the Base Toolkit we installed is version 2021.2.0.2883
Best regards
Patrick
Hi PatrickE,
Thanks for the information. Version 2021.3 is the latest version of the Intel® oneAPI toolkit. Please try the latest version of both Intel® oneAPI BaseToolkit and the Intel® oneAPI HPC Toolkit and see if this resolves the issue.
Note - Make sure to download and install first the Intel® OneAPI Base Toolkit and then add Intel® OneAPI HPC Toolkit or the toolkit of your choice. You may use the below link to do so.
Link - https://software.intel.com/content/www/us/en/develop/tools/oneapi/all-toolkits.html#base-kit
Dilanjan
Hello Dilanjan,
I know that there is a newer version. The thing is:
I want the 2021.2 version to work and not a newer version.
Could you please provide any help with this version?
Best regards
Patrick
PatrickE,
It looks like you are missing some of the associated dependencies. Can you make sure as part of your install you have at least all the yellow highlighted components below installed?
List of Available Packages
Component Name |
Package Name |
Platform |
Dependencies |
Intel® MPI Library |
impi_rt impi-devel |
linux-x64 |
N/A |
Intel® Fortran Compiler (Beta) and Intel® Fortran Compiler Classic |
fortran_rt |
linux-x64 linux-x86 |
Intel® MPI Library Intel OpenMP* Runtime Library |
Intel® CPU Runtime for OpenCL™ Applications |
opencl_rt |
linux-x64 |
oneTBB |
Intel® oneAPI DPC++/C++ Compiler |
dpcpp_cpp_rt |
linux-x64 |
Intel® CPU Runtime for OpenCL™ Applications Intel OpenMP* Runtime Library |
intel-openmp |
N/A |
Intel® oneAPI Threading Building Blocks (oneTBB) |
tbb tbb-devel |
N/A |
tbb4py |
linux-x64 |
N/A |
Intel® oneAPI Data Analytics Library (oneDAL) |
dal dal-static dal-devel dal-include |
oneTBB |
daal4py |
linux-x64 |
oneDAL |
Intel® Extension for Scikit-learn |
scikit-learn-intelex |
linux-x64 |
oneDAL |
Intel® Integrated Performance Primitives (Intel® IPP) |
ipp ipp-static ipp-include |
N/A |
Intel® Integrated Performance Primitives Cryptography |
ipp_crypto ipp_crypto-static ipp_crypto-include |
N/A |
Intel® oneAPI Math Kernel Library (oneMKL) |
mkl mkl-devel mkl-static mkl-include |
Intel OpenMP* Runtime Library oneTBB |
Intel® oneAPI Deep Neural Network Library (oneDNN) |
onednn-cpu-gomp onednn-devel-cpu-gomp |
linux-x64 |
N/A |
onednn-cpu-iomp onednn-devel-cpu-iomp |
linux-x64 |
onednn-cpu-dpcpp-gpu-dpcpp onednn-devel-cpu-dpcpp-gpu-dpcpp |
linux-x64 |
Intel® CPU Runtime for OpenCL™ Applications Intel oneAPI DPC++/C++ Compiler Runtime |
Intel® oneAPI Collective Communications Library (oneCCL) |
oneccl-devel |
linux-x64 |
N/A |
Intel® Distribution of Modin* (via Anaconda distribution of the toolkit using the Conda package manager) |
intel-aikit-modin |
linux-x64 |
N/A |
Intel® Low Precision Optimization Tool |
lpot |
linux-x64 |
N/A |
Intel® Optimization for TensorFlow* |
intel-tensorflow intel-tensorflow-avx512 |
linux-x64 |
N/A |
All dependencies you listet are installed already.
We also tried the newer version you suggested:
l_BaseKit_p_2021.3.0.3219_offline.sh
l_HPCKit_p_2021.3.0.3230_offline.sh
We encounter an issue with installing the python package with the base toolkit, everything else works fine.
With the HPC Toolkit we receive the same error as with version 2021.2:
[root@***** 2021.08.13.15.10.19.340]# grep ERROR *
installer.2021.08.13.15.10.21.641049.log:08/13/2021 15:11:18:234 : 10385 : ERROR : <PreRequisiteProcessor> exception occured during unsupported file system check: ''nfs' is unknown file system type. Conversion to file system type is failed.'
installer.2021.08.13.15.10.21.641049.log:08/13/2021 15:12:36:801 : 10385 : ERROR : Installation of component has failed.
installer.2021.08.13.15.10.21.641049.log:08/13/2021 15:12:36:801 : 10385 : ERROR : <StandardSequenceExecutor>: 'intel.oneapi.lin.dpcpp-cpp-pro-fortran-compiler-common,v=2021.3.0-3350' execution is failed. Rolling back all previous operations.
installer.2021.08.13.15.10.21.641049.log:08/13/2021 15:12:50:195 : 10385 : ERROR : Install sequence execution status: Rollback
installer.install.intel.oneapi.lin.hpckit.product,v=2021.3.0-3230.2021.08.13.15.10.21.641030.log:08/13/2021 15:12:36:801 : 10385 : ERROR : Installation of component has failed.
installer.install.intel.oneapi.lin.hpckit.product,v=2021.3.0-3230.2021.08.13.15.10.21.641030.log:08/13/2021 15:12:50:195 : 10385 : ERROR : Install sequence execution status: Rollback
pm.intel.oneapi.lin.dpcpp-cpp-pro-fortran-compiler-common,v=2021.3.0-3350.2021.08.13.15.12.36.729205.log:08/13/2021 15:12:36:788 : 10887 : ERROR : extractWithFilter: exception caught: extract::archive_read_extract failed with: -20; . Please check that destination directory has appropriate permissions and quota limit is not reached for the user.
pm.intel.oneapi.lin.dpcpp-cpp-pro-fortran-compiler-common,v=2021.3.0-3350.2021.08.13.15.12.36.729205.log:08/13/2021 15:12:36:789 : 10887 : ERROR : Execution of step 5 failed with error: Failed to extract files from /var/intel/installercache/downloadcache/intel.oneapi.lin.dpcpp-cpp-pro-fortran-compiler-common,v=2021.3.0-3350/cupPayload.cup
pm.intel.oneapi.lin.dpcpp-cpp-pro-fortran-compiler-common,v=2021.3.0-3350.2021.08.13.15.12.36.729205.log:08/13/2021 15:12:36:800 : 10887 : ERROR : Error: Sequence execution failed.
Apologies for the delay, I missed your response. We are looking at this now.
Chris
Apologies for the delay. Engineering got back to me this morning. They want the full install log from both the 2021.2, which you have provided, and the 2021.3 install log. They are also asking how much disk space you have left on this system?
Chris
Hi PatrickE,
Since I have not heard from you. This thread will no longer be monitored by Intel®. If you need further assistance, please post a new question
Dilanjan
