oneAPI Registration, Download, Licensing and Installation
Support for Getting Started questions related to download, Installation and licensing for Intel oneAPI Toolkits and software development tools.
1639 Discussions
intel oneAPI HPC Toolkit 2021.2 linux installation problems
PatrickE
We already installed Base Toolkit on our Linux Toolbox but we have issues with HPC Toolkit.
We always encounter errors when trying to install.
The error log is attached.
Dilanjan_J_Intel
Hi PatrickE,
Thanks for posting your concern on the forum. Please provide the below information.
  • The operating system's complete name, version and architecture.
  • A copy of the error output.
  • Are you trying to install using the online or offline package?
The above details would allow us to check further.
Have a pleasant day ahead!
Dilanjan
PatrickE
Hello Dilanjan,
Red Hat Enterprise Linux Workstation 7.7 with kernel version 3.10.0-1062.el7.x86_64
The entire log with errors is attached in the question I have.
We are using the offline package. We had no problems with the Base Kit.
Best regards
Dilanjan_J_Intel
Hi PatrickE,
Thanks for the information. Please also share the version of the Intel® oneApi Base toolkit you have installed.
Have a pleasant day!
Dilanjan
PatrickE
Hello Dalinjan,
the Base Toolkit we installed is version 2021.2.0.2883
Best regards
Patrick
Dilanjan_J_Intel
Hi PatrickE,
Thanks for the information. Version 2021.3 is the latest version of the Intel® oneAPI toolkit. Please try the latest version of both Intel® oneAPI BaseToolkit and the Intel® oneAPI HPC Toolkit and see if this resolves the issue.
Note - Make sure to download and install first the Intel® OneAPI Base Toolkit and then add Intel® OneAPI HPC Toolkit or the toolkit of your choice. You may use the below link to do so.
Link - https://software.intel.com/content/www/us/en/develop/tools/oneapi/all-toolkits.html#base-kit
Dilanjan
PatrickE
Hello Dilanjan,
I know that there is a newer version. The thing is:
I want the 2021.2 version to work and not a newer version.
Could you please provide any help with this version?
Best regards
Patrick
ChrisB_Intel
PatrickE,
It looks like you are missing some of the associated dependencies. Can you make sure as part of your install you have at least all the yellow highlighted components below installed?
List of Available Packages
Component Name
Package Name
Platform
Dependencies
Intel® MPI Library
impi_rt
impi-devel
linux-x64
N/A
Intel® Fortran Compiler (Beta) and Intel® Fortran Compiler Classic
fortran_rt
linux-x64
linux-x86
Intel® MPI Library
Intel OpenMP* Runtime Library
Intel® CPU Runtime for OpenCL™ Applications
opencl_rt
linux-x64
oneTBB
dpcpp_cpp_rt
linux-x64
intel-openmp
linux-x64
linux-x86
N/A
Intel® oneAPI Threading Building Blocks (oneTBB)
tbb
tbb-devel
linux-x64
linux-x86
N/A
tbb4py
linux-x64
N/A
Intel® oneAPI Data Analytics Library (oneDAL)
dal
dal-static
dal-devel
dal-include
linux-x64
linux-x86
oneTBB
daal4py
linux-x64
oneDAL
Intel® Extension for Scikit-learn
scikit-learn-intelex
linux-x64
oneDAL
Intel® Integrated Performance Primitives (Intel® IPP)
ipp
ipp-static
ipp-include
linux-x64
linux-x86
N/A
Intel® Integrated Performance Primitives Cryptography
ipp_crypto
ipp_crypto-static
ipp_crypto-include
linux-x64
linux-x86
N/A
Intel® oneAPI Math Kernel Library (oneMKL)
mkl
mkl-devel
mkl-static
mkl-include
linux-x64
linux-x86
oneTBB
Intel® oneAPI Deep Neural Network Library (oneDNN)
onednn-cpu-gomp
onednn-devel-cpu-gomp
linux-x64
N/A
onednn-cpu-iomp
onednn-devel-cpu-iomp
linux-x64
onednn-cpu-dpcpp-gpu-dpcpp
onednn-devel-cpu-dpcpp-gpu-dpcpp
linux-x64
Intel oneAPI DPC++/C++ Compiler Runtime
Intel® oneAPI Collective Communications Library (oneCCL)
oneccl-devel
linux-x64
N/A
Intel® Distribution of Modin* (via Anaconda distribution of the toolkit using the Conda package manager)
intel-aikit-modin
linux-x64
N/A
Intel® Low Precision Optimization Tool
lpot
linux-x64
N/A
Intel® Optimization for TensorFlow*
intel-tensorflow
intel-tensorflow-avx512
linux-x64
N/A
PatrickE
All dependencies you listet are installed already.
We also tried the newer version you suggested:
l_BaseKit_p_2021.3.0.3219_offline.sh
l_HPCKit_p_2021.3.0.3230_offline.sh
We encounter an issue with installing the python package with the base toolkit, everything else works fine.
With the HPC Toolkit we receive the same error as with version 2021.2:
[root@***** 2021.08.13.15.10.19.340]# grep ERROR *
installer.2021.08.13.15.10.21.641049.log:08/13/2021 15:11:18:234 : 10385 : ERROR : <PreRequisiteProcessor> exception occured during unsupported file system check: ''nfs' is unknown file system type. Conversion to file system type is failed.'
installer.2021.08.13.15.10.21.641049.log:08/13/2021 15:12:36:801 : 10385 : ERROR : Installation of component has failed.
installer.2021.08.13.15.10.21.641049.log:08/13/2021 15:12:36:801 : 10385 : ERROR : <StandardSequenceExecutor>: 'intel.oneapi.lin.dpcpp-cpp-pro-fortran-compiler-common,v=2021.3.0-3350' execution is failed. Rolling back all previous operations.
installer.2021.08.13.15.10.21.641049.log:08/13/2021 15:12:50:195 : 10385 : ERROR : Install sequence execution status: Rollback
installer.install.intel.oneapi.lin.hpckit.product,v=2021.3.0-3230.2021.08.13.15.10.21.641030.log:08/13/2021 15:12:36:801 : 10385 : ERROR : Installation of component has failed.
installer.install.intel.oneapi.lin.hpckit.product,v=2021.3.0-3230.2021.08.13.15.10.21.641030.log:08/13/2021 15:12:50:195 : 10385 : ERROR : Install sequence execution status: Rollback
pm.intel.oneapi.lin.dpcpp-cpp-pro-fortran-compiler-common,v=2021.3.0-3350.2021.08.13.15.12.36.729205.log:08/13/2021 15:12:36:788 : 10887 : ERROR : extractWithFilter: exception caught: extract::archive_read_extract failed with: -20; . Please check that destination directory has appropriate permissions and quota limit is not reached for the user.
pm.intel.oneapi.lin.dpcpp-cpp-pro-fortran-compiler-common,v=2021.3.0-3350.2021.08.13.15.12.36.729205.log:08/13/2021 15:12:36:789 : 10887 : ERROR : Execution of step 5 failed with error: Failed to extract files from /var/intel/installercache/downloadcache/intel.oneapi.lin.dpcpp-cpp-pro-fortran-compiler-common,v=2021.3.0-3350/cupPayload.cup
pm.intel.oneapi.lin.dpcpp-cpp-pro-fortran-compiler-common,v=2021.3.0-3350.2021.08.13.15.12.36.729205.log:08/13/2021 15:12:36:800 : 10887 : ERROR : Error: Sequence execution failed.
ChrisB_Intel
Apologies for the delay, I missed your response. We are looking at this now.
Chris
ChrisB_Intel
Apologies for the delay. Engineering got back to me this morning. They want the full install log from both the 2021.2, which you have provided, and the 2021.3 install log. They are also asking how much disk space you have left on this system?
Chris
Dilanjan_J_Intel
Hi PatrickE,
Since I have not heard from you. This thread will no longer be monitored by Intel®. If you need further assistance, please post a new question
Dilanjan
