I am trying to install oneAPI tools on a fresh Ubuntu machine. When I try
sudo apt-get install -y intel-aikit
I get the error
After this operation, 2479 MB of additional disk space will be used.
Err:1 https://apt.repos.intel.com/oneapi all/main all intel-oneapi-pytorch amd64 1.13.10.1-47264
404 Not Found [IP: 69.192.80.228 443]
E: Failed to fetch https://apt.repos.intel.com/oneapi/pool/main/intel-oneapi-pytorch-1.13.10.1-47264_amd64.deb 404 Not Found [IP: 69.192.80.228 443]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
This procedure for installing was working about 1 week ago. Did something happen to break a single repo?
Thanks for your patience. It looks like Intel Python has a dependency on bzip2, which did not come preinstalled on the Ubuntu 22.04.x instances that we've been using. Please double check if your system has bzip2 installed.
If not, install bzip2 and try reinstalling the ai kit
sudo apt update
sudo apt -y install bzip2
then install ai kit as you normally would, following the instructions on:
Please try this and let us know of any issues
- « Previous
- 1
- 2
- Next »
Hi @kta_intel
I hadn't checked it on a fresh Ubuntu 22.04 machine. It was already having the older AI Analytics Toolkit. That might be the difference. Please open a ticket on this.
sudo apt update
Yes, by installing bzip2, the aikit meta-package proceeded without the earlier errors.
There were still some lines in the install_neural-compressor.sh script that did not succeed, but there was a success message in the end.
/opt/intel/oneapi/tensorflow/2.12.0/../../neural-compressor/latest/install_neural-compressor.sh: 53: /opt/intel/oneapi/intelpython/latest/envs/tensorflow/etc/conda/deactivate.d/mpivars.deactivate.sh: [[: not found
/opt/intel/oneapi/tensorflow/2.12.0/../../neural-compressor/latest/install_neural-compressor.sh: 3: /opt/intel/oneapi/intelpython/latest/envs/tensorflow/etc/conda/deactivate.d/deactivate-opencl-rt.sh: [[: not found
/opt/intel/oneapi/tensorflow/2.12.0/../../neural-compressor/latest/install_neural-compressor.sh: 10: /opt/intel/oneapi/intelpython/latest/envs/tensorflow/etc/conda/deactivate.d/deactivate-opencl-rt.sh: [[: not found
0
Success to install neural-compressor in tensorflow.
Hi @susie
Yes, the solution in this case was to install bzip2, which did not come installed on ubuntu 22.04. Please give that try, but also note that Fedora 35 is not among the listed supported Linux OS
![](/skins/images/D3C0B914909A6564BBB97F4AD1ED1973/responsive_peak/images/icon_anonymous_message.png)
- « Previous
- 1
- 2
- Next »
