when installing onAPI Base Toolkit, I got failed with GPU drivers in connection with OpenCL.
The warnings are :
Intel Graphics Compute Runtime for OpenCL not found.
You have no relevant GPU driver. If you are going to develop and run GPU-accelated applications on this system, please check ... . Otherwise, you can ignore ...
May I ask if anyone else meets the same issue. I have GPU installed:
Model: NVIDIA RTX A4000
IRQ: 177
GPU UUID: GPU-00bde51f-4256-9410-3567-bd4a5146a486
Video BIOS: 94.04.57.00.08
Bus Type: PCIe
DMA Size: 47 bits
DMA Mask: 0x7fffffffffff
Bus Location: 0000:01:00.0
Device Minor: 0
GPU Excluded: No
Any method to solve the problem?
Hi Yang, please share the below information with us:
- OS build on which you are installing the software
- Is the installer an online or an offline package?
- Version of Microsoft Visual Studio installed along with it's build version
- Other versions of Intel® Parallel Studio XE or Intel® oneAPI already installed on the system
- Screenshots of the error screen
- Installation Log files.
The default path for a log file for a oneAPI installation is: C:\Program Files (x86)\Intel\oneAPI\logs
The default path for a log file for a Parallel Studio XE installation is: %temp%\pset_tmp_PSXE<version>_<username>
We would like to know.
Yang, unfortunately we were unable to hear back from me.
If you have any further queries, please post a new question as this thread will no longer be monitored by Intel®.
