The server I use now has CentOS 6.1 and gcc4.4.7 installed.
When I install MKL (one API based Toolkit), I pop up a warning that MKL is not compatible with the existing system.
I checked the MKL support manual and found that my current system and compiler are not supported in its support list.
Where can I download the applicable MKL version?
You want a 9-year-old MKL release. Even if you had a paid license for it, I don't think that a download would have been available.
You can download the current OneAPI MKL 2021, but it would probably not work unless you are able to install a more recent GCC on your system. See the software prerequisites in the release notes.
HI Xu, we have contacted you privately for some information regarding your query. Please check your inbox and respond there as the information is non-public in nature.
