Hello.
I am using Intel 2018xe on my server.
The license is as follows and I purchased it around October 2017.
Today, the license was confirmed to have expired on the server, and when I tried to log in to the website to check the license key, it said that there was no registered key. How do I renew it?
error message :
Error : product support for your (Comp-FL) license has expired
ifort : error #10052 : could not checkout FLEXlm license.
License Term : Perpetual
Date of purchase : October 2017
Floating Commercial 5 seats (ESD) * 2 license.
I purchased a perpetual license, do I need to renew it?
I've attached the response I received from Intel.
Hi Byungil, thank you for letting us know about your concern. We have checked and found that the support for your license serial numbers: license1, and license2 had expired on 11/9/2018 and as such the data including information of the licenses has not been retained in our systems. Due to that the license did not migrate from Intel® Registration Center 1.0 to Intel® Registration Center 2.0.
Thank you in advance.
Hi Byungil, we have sent you a private message related to your query. Kindly check your inbox.
Thanks for your answer.
You said that your license expired in 2018, but doesn't that mean that if you buy a perpetual license, you can use the compiler forever?
If there is such an issue, wouldn’t it mean there’s no need to purchase a perpetual license?
I've been using the compiler without any problems until recently.
[bimin@ladas00 test_dir) $ifort
Error: Product support for your (Comp-FL) license has expired.
License file(s) used were (in this order):
** 1. /usr/local/intel/licenses/license.lic
** 2. /usr/local/intel/compilers_and_libraries_2018.0.128/linux/bin/int
** 3. /home/bimin/Licenses
..skip
** 11. /opt/intel/licenses/license.lic
** 12. /Users/Shared/Library/Application Support/Intel/Licenses
** 13. /usr/local/intel/compilers_and_libraries_2018.0.128/linux/bin/i
ifort: error #210052: could not checkout FLEXlm license
[bimin@ladas00 test_dir]$
About this error
Can I just update the license.lic file in Linux to use it? Or can I use it again if I reinstall it?
Please check this. Thank you.
Hi Byungil, we have sent you a private message. Kindly check your inbox.
Hi Byungil, If you have any further query, please post a new question as this thread will no longer be monitored by
Intel®.
