oneAPI Registration, Download, Licensing and Installation
Support for Getting Started questions related to download, Installation and licensing for Intel oneAPI Toolkits and software development tools.
1615 Discussions
oneAPI Base Toolkit 2025.1.0.650 VSIXI installation fails
arc_
I tried to install it twice, but it keeps failing at the same point:
04/09/2025 02:06:27:207 : 15604 : WARNING : Product configuration is not finished successfully. Integration in IDE(s) might be in incomplete state or custom post-install/remove actions might fail.
Details: Attempt 1 of 2 failed. Execution of C:\Program Files (x86)\Microsoft Visual Studio\Installer\resources\app\ServiceHub\Services\Microsoft.VisualStudio.Setup.Service\VSIXInstaller.exe failed with exit code 1021, output:
Cannot create a stable subkey under a volatile parent key.
Attempt 2 of 2 failed. Execution of C:\Program Files (x86)\Microsoft Visual Studio\Installer\resources\app\ServiceHub\Services\Microsoft.VisualStudio.Setup.Service\VSIXInstaller.exe failed with exit code 1021, output:
Error: Sequence execution failed.
04/09/2025 02:06:27:207 : 15604 : MESSAGE : Operation 'complete.operation.intel.sessionmanifest.1744134894800439' execution is finished with status SuccessWithFail.
Deeksha_S_Intel
Hi Sascha,
Could you please share the below details with us, so that we can assist you in a better way:
  • Exact version of Microsoft Visual Studio installed(For ex : Microsoft Visual Studio 2022 version 17.13.5).
  • Are there other versions of Intel® Parallel Studio XE or Intel® oneAPI already installed on the system?
  • Other versions of Microsoft Visual Studio installed, along with its build version?
  • Is the installer an online or offline package?
  • A screenshot of the error message.
Once we receive the details, we'll do our best to resolve the issue for you as quickly as possible.
arc_
  • The two versions of VS 2022 currently installed:
VisualStudio.17.Release/17.13.6+35931.197
VisualStudio.17.Preview/17.14.0-pre.2.0+35906.104
  • There are no other versions of Parallel Studio XE or oneAPI installed on the system and never have been.
  • I used the intel-oneapi-base-toolkit-2025.1.0.650 online installer.
Deeksha_S_Intel
Hi Sascha,
We have shared some information internally with you regarding the installation issue. Please check your community inbox for further updates.
Deeksha_S_Intel
Hi Sascha, we have sent you a private message. Kindly check your community inbox.
Deeksha_S_Intel
Hi Sascha, unfortunately, we were unable to hear back from you.
If you have any further queries, please post a new question, as this thread will no longer be monitored by Intel®.
