Please note that oneAPI HPC Version 2022.3.1 C++ & FORTRAN components do not integrate with Visual Studio 2019 Version 16.11.22, but installation fails and rolls back. Is there a work around ? See below.
Hi John, please share the below information with us:
- OS build on which you are installing the software
- Is the installer an online or an offline package?
- Other versions of Intel® Parallel Studio XE or Intel® oneAPI already installed on the system
- Installation Log files
The default path for a log file for a oneAPI installation is: C:\Program Files (x86)\Intel\oneAPI\logs
Good Morning ArPanB_Intel
I have tried installing Fortran without installing C++, as well as installing both, but without success
OS Name Microsoft Windows 10 Pro
Version 10.0.19043 Build 19043
- Is the installer an online or an offline package? : ... I have tried both online and offline with same result
Intel Libraries for oneAPI Package ID: w_oneAPI_2022.2.1.14974
Intel Libraries for oneAPI – toolkit version: 2022.3.1, extension version 22.0.0.16, Package ID: w_oneAPI_2022.2.1.14974, Copyright © 2019-2022 Intel Corporation. All rights reserved.
* Other names and brands may be claimed as the property of others.
Intel® C++ Compiler Package ID: w_oneAPI_2022.2.1.14974
Intel® C++ Compiler – toolkit version: 2022.3.1, extension version 22.0.16, Package ID: w_oneAPI_2022.2.1.14974, Copyright © 2002-2022 Intel Corporation. All rights reserved.
Intel® Inspector 2022.3.1 606307
Intel® Inspector 2022.3.1, (build 606307), Copyright © 2009-2022 Intel Corporation. All rights reserved.
Intel® oneAPI DPC++ Compiler Package ID: w_oneAPI_2022.2.1.14974
Intel® oneAPI DPC++ Compiler – toolkit version: 2022.3.1, extension version 22.0.0.16, Package ID: w_oneAPI_2022.2.1.14974, Copyright © 2019-2022 Intel Corporation. All rights reserved.
Intel® oneAPI Menu & Samples 10.10.392.9731
Intel® oneAPI Visual Studio Menu & Samples Extension
IntelliCode Extension 1.0
IntelliCode Visual Studio Extension Detailed Info
- Installation Log files Files (x86)\Intel\oneAPI\logs
Please see log files attached
Good Morning ArpanB_Intel,
I have tried both online and offline without success
See attached log files
Hi ArPanB_Intel
Not sure if my previous posts have gone through
Have tried both online and offline without success
Good Morning
I have the same installation failure problem with oneAPI HPC Version 2023 and Visual Studio 2019 Version 16.11.22
John, thank you for sharing the information.
We have contacted you privately with some information. Please check you inbox for further updates.
John, please follow the below workaround:
- Close Intel® installers if any.
- Uninstall all Microsoft Visual Studio instances and Visual Studio Installer.
Important: check that C:\ProgramData\Microsoft\VisualStudio\Setup\x86\Microsoft.VisualStudio.Setup.Configuration.Native.dll does not exist anymore. If it was not removed with Microsoft Visual Studio for some reason, please unregister the DLL using
REGSVR32 /U C:\ProgramData\Microsoft\VisualStudio\Setup\x86\Microsoft.VisualStudio.Setup.Configuration.Native.dll
command in Command Prompt as Administrator, and then rename the file to Backup_Microsoft.VisualStudio.Setup.Configuration.Native.dll so the Intel® Installer can't load it.
- Uninstall older Intel® Parallel Studio XE and Intel® oneAPI products.
- Install required versions of Microsoft Visual Studio supported by the Intel® Parallel Studio XE. See the full list by clicking here: https://www.intel.com/content/www/us/en/developer/articles/reference-implementation/intel-compilers-compatibility-with-microsoft-visual-studio-and-xcode.html. For the Intel® Parallel Studio XE 2020 Update 4, the supported versions are Visual Studio 2017 15.9 and Visual Studio 2019 16.7.2.
We await your findings.
John, unfortunately we were unable to hear back from you.
If you have any further queries, please post a new question as this thread will no longer be monitored by Intel®
