If I remove oneAPI 2022 from VS2022, the bellow error is popped up:
Removal of component has failed.
Component id: intel.oneapi.win.dpcpp_debugger.vsmi.vs2022, name: Intel Distribution for GDB*, version:2021.5.0-115.
Error: Sequence execution failed.
If I install oneAPI 2022.2 to VS2022, the bellow error is popped up:
Component id: intel.oneapi.win.compilers-common.ide.common_vs2022, name: IDE Common for visual Studio 2022, version:2022.0.0-161.
Hi Xu, please follow the below steps:
- Close Intel® installers if any.
- Uninstall all Microsoft Visual Studio instances and Visual Studio Installer.
- Important: check that C:\ProgramData\Microsoft\VisualStudio\Setup\x86\Microsoft.VisualStudio.Setup.Configuration.Native.dll does not exist anymore. If it was not removed with Microsoft Visual Studio for some reason, please unregister the DLL using REGSVR32 /U C:\ProgramData\Microsoft\VisualStudio\Setup\x86\Microsoft.VisualStudio.Setup.Configuration.Native.dll
command in Command Prompt as Administrator, and then rename the file to Backup_Microsoft.VisualStudio.Setup.Configuration.Native.dll so the Intel® Installer can't load it.
- Uninstall older Intel® Parallel Studio XE and Intel® oneAPI products.
- Install required versions of Microsoft Visual Studio supported by the Intel® Parallel Studio XE. See the full list here: https://www.intel.com/content/www/us/en/developer/articles/reference-implementation/intel-compilers-.... For the Intel® Parallel Studio XE 2020 Update 4, the supported versions are Visual Studio 2017 15.9 and Visual Studio 2019 16.7.2.
How can I update oneAPI?
The update button cannot be found in the oneAPI installer
Xu, once you have installed an Intel® oneAPI Base Toolkit, rerun the same installer again. It will automatically detect the presence of the existing version of the toolkit installed on your system and check and show you if a new version is available for update.
Sure Xu. Please visit here> https://www.intel.com/content/www/us/en/develop/documentation/get-started-with-intel-oneapi-base-hpc..., for complete guidance.
Xu, we have moved your post installation query to the relevant forum.
Your issue will be further addressed here> https://community.intel.com/t5/Intel-oneAPI-Data-Parallel-C/Failed-to-activate-the-quot-Environment-...
Xu, since the installation issue was addressed, we are going ahead and closing this thread.
If you have any further queries please post a new question as this thread will no longer be monitored by Intel®.
