Do you support a url for wget scraping, or an rsync service endpoint, for the oneAPI filetree?
I need to mirror the oneAPI upstream repo (https://yum.repos.intel.com/oneapi) locally for provisioning of clients which are not allowed to talk to the outside world. I can mirror via reposync like so...
https_proxy=<REDACTED> dnf reposync -c /var/repo/utils/IntelOneAPI.repo -p /var/repo/intel
but would very much prefer to use wget or rsync so that I don't combine the sync meta of repositories being mirrored with that of repositories being locally used (ie, in the local DNF cache and /var/lib/... locations).
Please note this is a preference, not a requirement.
Hi Owen, please share the below information with us:
- Full name of the Linux distribution on which you are installing the software
We would like to know.
This will be for a heterogeneous cluster, including but not limited to
- CentOS 7.9
- Rocky 8.8
- Rocky 9
- Ubuntu LTS 22.10
I'll be testing combinations of these as both clients, cluster admin node, and repository mirroring host.
Owen, we have contacted you internally with some information. Please check your inbox for further updates.
Owen, unfortunately we were unable to hear back from you.
If you have any further queries, please post a new question as this thread will no longer be monitored by Intel®.
