Hi Team,
I was trying to install oneApi Base Toolkit package using YUM from the link : YUM, DNF, Zypper (intel.com). followed the steps in the link.
However i was getting error as below.
sudo yum install intel-basekit
Intel® oneAPI repository 0.0 B/s | 0 B 02:00
Errors during downloading metadata for repository 'oneAPI':
- Curl error (28): Timeout was reached for https://yum.repos.intel.com/oneapi/repodata/repomd.xml [Connection timed out after 30000 milliseconds]
Error: Failed to download metadata for repo 'oneAPI': Cannot download repomd.xml: Cannot download repodata/repomd.xml: All mirrors were tried
Can anyone look into this issue and please suggest what could be the issue.
Sagar
Hi Sagar, could you confirm the below information with us>
- Do you have a stable internet connection during the installation?
- Are you using a VPN while installing the toolkit?
Also, please check your firewall settings to make sure it is not blocking the download.
Hi Aparna,
Thanks for your response.
Yes i have a stable internet connection during the installation. I was using vpn while installing the toolkit.
Sagar
Sagar, thank you for the confirmation. We would like to try and replicate this issue on our end.
Could you share the version of Linux you are using on your system? We would like to know.
Sagar, unfortunately we were unable to get a response from your end.
If you have any further queries, please post a new question as this thread will no longer be monitored by Intel®.
