oneAPI Registration, Download, Licensing and Installation
Support for Getting Started questions related to download, Installation and licensing for Intel oneAPI Toolkits and software development tools.
1285 Discussions
"Not enough disk space" on BaseKit 2021.2.0 installer
Sachs__Stephen
When installing OneAPI Basekit via the offline method onto a secondary file system I see an error saying there is not sufficient space left on the primary file system. The installation media as well as the "install-dir" are located on the secondary file system.
[root@ip-172-31-18-92 src]# bash l_BaseKit_p_2021.2.0.2883_offline.sh -s -a -s --eula accept --install-dir $CURDIR --components all
QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root'
Checking system requirements...
Done.
Wait while the installer is preparing...
Done.
Launching the installer...
Not enough disk space.
Drive / has 1.9 GB available. 64.1 GB is required.
Failed to check prerequisites
Installer has failed.
The application has encountered errors which caused failure. For more details, click on the log link at the bottom of the dialog.
Installer completed with code 1
Log file: /tmp/root/intel_oneapi_installer/2021.06.23.07.35.43.384/installer.install.intel.oneapi.lin.basekit.product,v=2021.2.0-2883.2021.06.23.07.35.45.404165.log
[root@ip-172-31-18-92 src]# cat /tmp/root/intel_oneapi_installer/2021.06.23.07.35.43.384/installer.install.intel.oneapi.lin.basekit.product,v=2021.2.0-2883.2021.06.23.07.35.45.404165.log
06/23/2021 07:35:45:635 : 44871 : MESSAGE : /opt/intel/oneapi/installer/installer is run with arguments: -s --eula accept --install-dir /shared/apps/compilers/intel --components all --download-dir /shared/apps/compilers/intel/tmp --log-dir /tmp/root/intel_oneapi_installer/2021.06.23.07.35.43.384 --product-id intel.oneapi.lin.basekit.product --product-ver 2021.2.0-2883 --package-path /shared/apps/compilers/intel/2021.2.0/src/l_BaseKit_p_2021.2.0.2883_offline/packages
06/23/2021 07:35:45:635 : 44871 : MESSAGE : Installer is started in silent mode
06/23/2021 07:35:45:635 : 44871 : MESSAGE : Installer executable location is /opt/intel/oneapi/installer/installer, version is 4.0.6.0-410
06/23/2021 07:35:45:635 : 44871 : MESSAGE : Package manager executable location is /opt/intel/packagemanager/1.0/packagemanager, version is 4.0.5-170
06/23/2021 07:35:45:635 : 44871 : MESSAGE : Product is set to intel.oneapi.lin.basekit.product,v=2021.2.0-2883. Mode is set to install.
06/23/2021 07:35:45:923 : 44875 : MESSAGE : PreRequisite for other install successfully checked
06/23/2021 07:35:45:924 : 44875 : MESSAGE : PreRequisite for other Intel install successfully checked
06/23/2021 07:35:45:924 : 44875 : MESSAGE : PreRequisite for check installer location successfully checked
06/23/2021 07:35:45:925 : 44875 : MESSAGE : PreRequisite for admin rights successfully checked
06/23/2021 07:35:45:926 : 44875 : MESSAGE : Error [This machine uses operating system "Amazon Linux Linux version 2". Compatibility issues may occur.]
06/23/2021 07:35:45:926 : 44875 : MESSAGE : Description [Installation can continue; however, product functionality may not meet expectations because this product is untested on this operating system. Suggestion: Check the Release Notes for a list of supported operating systems and install this product on a compliant system.]
06/23/2021 07:35:45:926 : 44875 : WARNING : This machine uses operating system "Amazon Linux Linux version 2". Compatibility issues may occur.
06/23/2021 07:35:45:926 : 44875 : MESSAGE : Checks for preRequisite for supported operation system are passed with warning
06/23/2021 07:35:45:928 : 44875 : MESSAGE : Error [This machine uses operating system "Amazon Linux Linux version 2". Compatibility issues may occur.]
06/23/2021 07:35:45:928 : 44875 : MESSAGE : Description [Installation can continue; however, product functionality may not meet expectations because this product is untested on this operating system. Suggestion: Check the Release Notes for a list of supported operating systems and install this product on a compliant system.]
06/23/2021 07:35:45:928 : 44875 : WARNING : This machine uses operating system "Amazon Linux Linux version 2". Compatibility issues may occur.
06/23/2021 07:35:45:928 : 44875 : MESSAGE : Checks for preRequisite for supported operation system are passed with warning
06/23/2021 07:35:45:929 : 44875 : MESSAGE : Error [This machine uses operating system "Amazon Linux Linux version 2". Compatibility issues may occur.]
06/23/2021 07:35:45:929 : 44875 : MESSAGE : Description [Installation can continue; however, product functionality may not meet expectations because this product is untested on this operating system. Suggestion: Check the Release Notes for a list of supported operating systems and install this product on a compliant system.]
06/23/2021 07:35:45:929 : 44875 : WARNING : This machine uses operating system "Amazon Linux Linux version 2". Compatibility issues may occur.
06/23/2021 07:35:45:929 : 44875 : MESSAGE : Checks for preRequisite for supported operation system are passed with warning
06/23/2021 07:35:45:929 : 44875 : MESSAGE : All checks for preRequisite for supported operation system are passed
06/23/2021 07:35:47:273 : 44873 : MESSAGE : PreRequisite for free disk space failed
06/23/2021 07:35:47:273 : 44873 : MESSAGE : Error [Not enough disk space.]
06/23/2021 07:35:47:273 : 44873 : MESSAGE : Description []
06/23/2021 07:35:47:273 : 44873 : MESSAGE : PreRequisite for permissions passed
06/23/2021 07:35:47:274 : 44873 : MESSAGE : PreRequisite for other install successfully checked
06/23/2021 07:35:47:274 : 44873 : MESSAGE : PreRequisite for other Intel install successfully checked
06/23/2021 07:35:47:274 : 44871 : MESSAGE : ----------------------------------------------------------------------------------------------------
06/23/2021 07:35:47:274 : 44871 : MESSAGE : Anonymous statistics fields:
06/23/2021 07:35:47:274 : 44871 : MESSAGE : EventId = 'install-min'
06/23/2021 07:35:47:274 : 44871 : MESSAGE : EventTime = ''
06/23/2021 07:35:47:274 : 44871 : MESSAGE : Id = 'intel.oneapi.lin.basekit.product,v=2021.2.0-2883'
06/23/2021 07:35:47:274 : 44871 : MESSAGE : Message = '{ \"product_name\":\"[Linux] Intel® oneAPI Base Toolkit 2021.2\", \"lic_type\":\"\", \"support_code\":\"\", \"install_status\":\"4626\", \"product_tag\":\"\" }'
06/23/2021 07:35:47:274 : 44871 : MESSAGE : ProductId = '[Linux] Intel® oneAPI Base Toolkit 2021.2'
It's true there is not space left on the primary file system "/", but the secondary "/shared" has plenty of space left.
[ec2-user@ip-172-31-18-92 InfosphereApplicationInstaller]$ df -h
Filesystem Size Used Avail Use% Mounted on
devtmpfs 94G 0 94G 0% /dev
tmpfs 94G 0 94G 0% /dev/shm
tmpfs 94G 796K 94G 1% /run
tmpfs 94G 0 94G 0% /sys/fs/cgroup
/dev/nvme0n1p1 25G 24G 1.9G 93% /
/dev/nvme1n1 985G 53G 882G 6% /shared
tmpfs 19G 0 19G 0% /run/user/1000
Soumya_M_Intel
Hi Sachs__Stephen,
Thanks for posting your concern in the forum. You may try using:
--download-cache
in the command to set a directory to store all downloaded and cached files.
You may visit the below link for a better understanding of the same.
Link: https://software.intel.com/content/www/us/en/develop/documentation/installation-guide-for-intel-oneapi-toolkits-linux/top/installation/install-with-command-line.html
Soumya
Sachs__Stephen
I realize that there is a install cache directory located in /var that needs to be of a certain size. I guess my question is if it possible to force this cache directory to a different location.
Soumya_M_Intel
Hi Sachs__Stephen,
--download-cache
Soumya
Sachs__Stephen
That's it! Thanks for tour help.
Soumya_M_Intel
Hi Sachs__Stephen,
Thanks for the update. Glad that we could help. As per your reply, I am proceeding to close this thread. However, feel free to create a new thread if there are any queries or concerns. Have a nice day!
Soumya
