Hi , i have a question about the licensing of oneApi, is a multi-node license equivalent to a floating license ? To be more clear, can a single node license be used on different computers(me and my colleagues) at the same time, or is a multi-node license required to do that?
sincerely,
Hi Anis, a single-node Named User license can be used on different computers. However, they cannot be used on different systems at the same time. If you require multiple systems to use the licenses simultaneously, we suggest you choose a multi-node Concurrent User license and register your colleagues to that license.
