I run the image which is built by singularity and based on Intel AI Toolkit.
When I run the command `conda env list`:
root@head:/home/hpcadmin# conda env list
# conda environments:
/home/hpcadmin/fy/test_ai/tensorflow2
base * /opt/intel/oneapi/intelpython/latest
2021.2.0 /opt/intel/oneapi/intelpython/latest/envs/2021.2.0
pytorch /opt/intel/oneapi/intelpython/latest/envs/pytorch
pytorch-1.7.0 /opt/intel/oneapi/intelpython/latest/envs/pytorch-1.7.0
tensorflow /opt/intel/oneapi/intelpython/latest/envs/tensorflow
tensorflow-2.3.0 /opt/intel/oneapi/intelpython/latest/envs/tensorflow-2.3.0
/tmp/hpcadmin/oneapi/pytorch/latest
And the error will happen after I run the clone command:
root@head:/home/hpcadmin/fy/test_ai# conda create -y -v --clone pytorch -p /home/hpcadmin/fy/test_ai/pytorch
Source: /opt/intel/oneapi/intelpython/latest/envs/pytorch-1.7.0
Destination: /home/hpcadmin/fy/test_ai/pytorch
The following packages cannot be cloned out of the root environment:
- defaults/linux-64::conda-4.10.1-py37h06a4308_1
Packages: 145
Files: 203
# >>>>>>>>>>>>>>>>>>>>>> ERROR REPORT <<<<<<<<<<<<<<<<<<<<<<
File "/opt/intel/oneapi/intelpython/latest/lib/python3.7/site-packages/conda/exceptions.py", line 1079, in __call__
return func(*args, **kwargs)
File "/opt/intel/oneapi/intelpython/latest/lib/python3.7/site-packages/conda/cli/main.py", line 84, in _main
exit_code = do_call(args, p)
File "/opt/intel/oneapi/intelpython/latest/lib/python3.7/site-packages/conda/cli/conda_argparse.py", line 83, in do_call
return getattr(module, func_name)(args, parser)
File "/opt/intel/oneapi/intelpython/latest/lib/python3.7/site-packages/conda/cli/main_create.py", line 41, in execute
install(args, parser, 'create')
File "/opt/intel/oneapi/intelpython/latest/lib/python3.7/site-packages/conda/cli/install.py", line 222, in install
clone(args.clone, prefix, json=context.json, quiet=context.quiet, index_args=index_args)
File "/opt/intel/oneapi/intelpython/latest/lib/python3.7/site-packages/conda/cli/install.py", line 74, in clone
File "/opt/intel/oneapi/intelpython/latest/lib/python3.7/site-packages/conda/misc.py", line 290, in clone_env
force_extract=False, index_args=index_args)
File "/opt/intel/oneapi/intelpython/latest/lib/python3.7/site-packages/conda/misc.py", line 90, in explicit
assert not any(spec_pcrec[1] is None for spec_pcrec in specs_pcrecs)
AssertionError
`$ /opt/intel/oneapi/intelpython/latest/bin/conda create -y -v --clone pytorch-1.7.0 -p /home/hpcadmin/fy/test_ai/pytorch`
environment variables:
ACL_BOARD_VENDOR_PATH=/opt/Intel/OpenCLFPGA/oneAPI/Boards
CIO_TEST=<not set>
CLASSPATH=/opt/intel/oneapi/mpi/2021.2.0//lib/mpi.jar:/opt/intel/oneapi/dal/2021
.2.0/lib/onedal.jar
CMAKE_PREFIX_PATH=/opt/intel/oneapi/vpl:/opt/intel/oneapi/tbb/2021.2.0/env/..:/opt/intel
/oneapi/dal/2021.2.0
CONDA_EXE=/opt/intel/oneapi/intelpython/latest/bin/conda
CONDA_PYTHON_EXE=/opt/intel/oneapi/intelpython/latest/bin/python
CONDA_ROOT=/opt/intel/oneapi/intelpython/latest
CONDA_SHLVL=0
CPATH=/opt/intel/oneapi/vpl/2021.2.2/include:/opt/intel/oneapi/tbb/2021.2.0/
env/../include:/opt/intel/oneapi/mpi/2021.2.0//include:/opt/intel/onea
pi/mkl/latest/include:/opt/intel/oneapi/ippcp/2021.2.0/include:/opt/in
tel/oneapi/ipp/2021.2.0/include:/opt/intel/oneapi/dpl/2021.2.0/linux/i
nclude:/opt/intel/oneapi/dnnl/2021.2.0/cpu_dpcpp_gpu_dpcpp/lib:/opt/in
tel/oneapi/dev-utilities/2021.2.0/include:/opt/intel/oneapi/dal/2021.2
.0/include:/opt/intel/oneapi/compiler/2021.2.0/linux/include:/opt/inte
l/oneapi/ccl/2021.2.0/include/cpu_gpu_dpcpp
CURL_CA_BUNDLE=<not set>
FI_PROVIDER_PATH=/opt/intel/oneapi/mpi/2021.2.0/libfabric/lib/prov:/usr/lib64/libfabric
INFOPATH=/opt/intel/oneapi/debugger/10.1.1/documentation/info/
LD_LIBRARY_PATH=/opt/ohpc/pub/mpi/libfabric/1.10.1/lib:/opt/ohpc/pub/mpi/ucx-ohpc/1.8.
0/lib:/opt/ohpc/pub/mpi/openmpi4-gnu9/4.0.4/lib:/opt/ohpc/pub/compiler
/gcc/9.3.0/lib64:/.singularity.d/libs
LIBRARY_PATH=/opt/intel/oneapi/vpl/2021.2.2/lib:/opt/intel/oneapi/tbb/2021.2.0/env/
../lib/intel64/gcc4.8:/opt/intel/oneapi/mpi/2021.2.0//libfabric/lib:/o
pt/intel/oneapi/mpi/2021.2.0//lib/release:/opt/intel/oneapi/mpi/2021.2
.0//lib:/opt/intel/oneapi/mkl/latest/lib/intel64:/opt/intel/oneapi/ipp
cp/2021.2.0/lib/intel64:/opt/intel/oneapi/ipp/2021.2.0/lib/intel64:/op
t/intel/oneapi/dnnl/2021.2.0/cpu_dpcpp_gpu_dpcpp/lib:/opt/intel/oneapi
/dal/2021.2.0/lib/intel64:/opt/intel/oneapi/compiler/2021.2.0/linux/co
mpiler/lib/intel64_lin:/opt/intel/oneapi/compiler/2021.2.0/linux/lib:/
opt/intel/oneapi/ccl/2021.2.0/lib/cpu_gpu_dpcpp
MANPATH=/opt/xcat/share/man:/opt/ohpc/pub/libs/singularity/3.4.2/share/man:/op
t/ohpc/pub/mpi/libfabric/1.10.1/share/man:/opt/ohpc/pub/mpi/openmpi4-g
nu9/4.0.4/share/man:/opt/ohpc/pub/compiler/gcc/9.3.0/share/man:/usr/lo
cal/share/man:/usr/share/man/overrides:/usr/share/man/en:/usr/share/ma
n:/opt/confluent/share/man::
MODULEPATH=/opt/ohpc/pub/moduledeps/gnu9-openmpi4:/opt/ohpc/pub/moduledeps/gnu9:/
opt/ohpc/admin/modulefiles:/opt/ohpc/pub/modulefiles:/opt/intel/oneapi
/modulefiles
NLSPATH=/opt/intel/oneapi/mkl/latest/lib/intel64/locale/%l_%t/%N
PATH=/opt/intel/oneapi/intelpython/latest/bin:/opt/intel/oneapi/intelpython
/latest/bin:/opt/intel/oneapi/vtune/2021.2.0/bin64:/opt/intel/oneapi/v
pl/2021.2.2/bin:/opt/intel/oneapi/mpi/2021.2.0/libfabric/bin:/opt/inte
l/oneapi/mpi/2021.2.0/bin:/opt/intel/oneapi/mkl/latest/bin/intel64:/op
t/intel/oneapi/intelpython/latest/bin:/opt/intel/oneapi/intelpython/la
test/condabin:/opt/intel/oneapi/dev-utilities/2021.2.0/bin:/opt/intel/
oneapi/debugger/10.1.1/gdb/intel64/bin:/opt/intel/oneapi/compiler/2021
.2.0/linux/lib/oclfpga/llvm/aocl-bin:/opt/intel/oneapi/compiler/2021.2
.0/linux/lib/oclfpga/bin:/opt/intel/oneapi/compiler/2021.2.0/linux/bin
/intel64:/opt/intel/oneapi/compiler/2021.2.0/linux/bin:/opt/intel/onea
pi/compiler/2021.2.0/linux/ioc/bin:/opt/intel/oneapi/advisor/2021.2.0/
bin64:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
PKG_CONFIG_PATH=/opt/ohpc/pub/mpi/libfabric/1.10.1/lib/pkgconfig:/opt/ohpc/pub/mpi/ucx
-ohpc/1.8.0/lib/pkgconfig:/opt/ohpc/pub/mpi/openmpi4-gnu9/4.0.4/lib/pk
gconfig
PYTHONPATH=/opt/intel/oneapi/advisor/2021.2.0/pythonapi
REQUESTS_CA_BUNDLE=<not set>
SETVARS_VARS_PATH=/opt/intel/oneapi/vtune/latest/env/vars.sh
SSL_CERT_FILE=<not set>
USER_PATH=/opt/xcat/bin:/opt/xcat/sbin:/opt/xcat/share/xcat/tools:/opt/ohpc/pub/
libs/singularity/3.4.2/bin:/opt/ohpc/pub/mpi/libfabric/1.10.1/bin:/opt
/ohpc/pub/mpi/ucx-ohpc/1.8.0/bin:/opt/ohpc/pub/mpi/openmpi4-gnu9/4.0.4
/bin:/opt/ohpc/pub/compiler/gcc/9.3.0/bin:/opt/ohpc/pub/utils/prun/2.0
:/opt/ohpc/pub/bin:/opt/confluent/bin:/usr/local/sbin:/usr/local/bin:/
usr/sbin:/usr/bin:/root/bin:/bin:/usr/bin:/sbin:/usr/sbin:/usr/local/b
in:/usr/local/sbin
__LMOD_REF_COUNT_LD_LIBRARY_PATH=/opt/ohpc/pub/mpi/libfabric/1.10.1/lib:1;/opt/ohpc/pub/mpi/ucx-ohpc/1.
8.0/lib:1;/opt/ohpc/pub/mpi/openmpi4-gnu9/4.0.4/lib:1;/opt/ohpc/pub/co
mpiler/gcc/9.3.0/lib64:1
__LMOD_REF_COUNT_MANPATH=/opt/ohpc/pub/libs/singularity/3.4.2/share/man:1;/opt/ohpc/pub/mpi/lib
fabric/1.10.1/share/man:1;/opt/ohpc/pub/mpi/openmpi4-gnu9/4.0.4/share/
man:1;/opt/ohpc/pub/compiler/gcc/9.3.0/share/man:1;/usr/local/share/ma
n:1;/usr/share/man/overrides:1;/usr/share/man/en:1;/usr/share/man:1;/o
pt/confluent/share/man:1
__LMOD_REF_COUNT_MODULEPATH=/opt/ohpc/pub/moduledeps/gnu9-openmpi4:1;/opt/ohpc/pub/moduledeps/gnu9
:1;/opt/ohpc/admin/modulefiles:1;/opt/ohpc/pub/modulefiles:1;/opt/inte
l/oneapi/modulefiles:1
__LMOD_REF_COUNT_PATH=/opt/ohpc/pub/libs/singularity/3.4.2/bin:1;/opt/ohpc/pub/mpi/libfabric
/1.10.1/bin:1;/opt/ohpc/pub/mpi/ucx-ohpc/1.8.0/bin:1;/opt/ohpc/pub/mpi
/openmpi4-gnu9/4.0.4/bin:1;/opt/ohpc/pub/compiler/gcc/9.3.0/bin:1;/opt
/ohpc/pub/utils/prun/2.0:1;/opt/ohpc/pub/bin:1;/opt/confluent/bin:1;/u
sr/local/sbin:1;/usr/local/bin:1;/usr/sbin:1;/usr/bin:1
__LMOD_REF_COUNT_PKG_CONFIG_PATH=/opt/ohpc/pub/mpi/libfabric/1.10.1/lib/pkgconfig:1;/opt/ohpc/pub/mpi/u
cx-ohpc/1.8.0/lib/pkgconfig:1;/opt/ohpc/pub/mpi/openmpi4-gnu9/4.0.4/li
b/pkgconfig:1
active environment : None
shell level : 0
user config file : /root/.condarc
populated config files : /opt/intel/oneapi/intelpython/latest/.condarc
conda version : 4.9.2
conda-build version : not installed
python version : 3.7.9.final.0
virtual packages : __glibc=2.27=0
__unix=0=0
__archspec=1=x86_64
base environment : /opt/intel/oneapi/intelpython/latest (read only)
channel URLs : file:///opt/intel/oneapi/conda_channel/linux-64
file:///opt/intel/oneapi/conda_channel/noarch
https://conda.anaconda.org/intel/linux-64
https://conda.anaconda.org/intel/noarch
https://repo.anaconda.com/pkgs/main/linux-64
https://repo.anaconda.com/pkgs/main/noarch
https://repo.anaconda.com/pkgs/r/linux-64
https://repo.anaconda.com/pkgs/r/noarch
package cache : /opt/intel/oneapi/intelpython/latest/pkgs
/root/.conda/pkgs
envs directories : /root/.conda/envs
platform : linux-64
user-agent : conda/4.9.2 requests/2.25.1 CPython/3.7.9 Linux/4.18.0-193.el8.x86_64 ubuntu/18.04.5 glibc/2.27
UID:GID : 0:0
netrc file : None
offline mode : False
An unexpected error has occurred. Conda has prepared the above report.
Upload successful.
But,it is successful when I clone the tensorflow environment.
initializing UnlinkLinkTransaction with
target_prefix: /home/hpcadmin/fy/test_ai/tensorflow
unlink_precs:
link_precs:
defaults/linux-64::ca-certificates-2021.4.13-h06a4308_1
file:///opt/intel/oneapi/conda_channel/linux-64::common_cmplr_lib_rt-2021.2.0-intel_610
file:///opt/intel/oneapi/conda_channel/linux-64::common_cmplr_lic_rt-2021.2.0-intel_610
file:///opt/intel/oneapi/conda_channel/linux-64::impi_rt-2021.2.0-intel_215
file:///opt/intel/oneapi/conda_channel/linux-64::intel-openmp-2021.2.0-intel_610
file:///opt/intel/oneapi/conda_channel/linux-64::intelpython-2021.1.1-1
file:///opt/intel/oneapi/conda_channel/linux-64::libgcc-ng-9.3.0-hdf63c60_101
file:///opt/intel/oneapi/conda_channel/linux-64::libstdcxx-ng-9.3.0-hdf63c60_101
defaults/linux-64::pandoc-2.12-h06a4308_0
file:///opt/intel/oneapi/conda_channel/linux-64::tbb-2021.2.0-intel_357
file:///opt/intel/oneapi/conda_channel/linux-64::tcl-8.6.10-0
file:///opt/intel/oneapi/conda_channel/linux-64::tensorflow-base-2.3.0-0
file:///opt/intel/oneapi/conda_channel/linux-64::bzip2-1.0.8-hb9a14ef_6
file:///opt/intel/oneapi/conda_channel/linux-64::c-ares-1.17.1-h14c3975_0
defaults/linux-64::expat-2.3.0-h2531618_2
file:///opt/intel/oneapi/conda_channel/linux-64::fortran_rt-2021.2.0-intel_610
defaults/linux-64::icu-58.2-he6710b0_3
defaults/linux-64::jpeg-9b-h024ee3a_2
file:///opt/intel/oneapi/conda_channel/linux-64::libffi-3.3-13
defaults/linux-64::libsodium-1.0.18-h7b6447c_0
defaults/linux-64::libuuid-1.0.3-h1bed415_2
defaults/linux-64::libxcb-1.14-h7b6447c_0
file:///opt/intel/oneapi/conda_channel/linux-64::lz4-c-1.9.2-h5c78bee_3
file:///opt/intel/oneapi/conda_channel/linux-64::lzo-2.10-hb9a14ef_6
file:///opt/intel/oneapi/conda_channel/linux-64::mkl-2021.2.0-intel_296
file:///opt/intel/oneapi/conda_channel/linux-64::opencl_rt-2021.2.0-intel_610
defaults/linux-64::openssl-1.1.1k-h27cfd23_0
defaults/linux-64::pcre-8.44-he6710b0_0
file:///opt/intel/oneapi/conda_channel/linux-64::sqlite-3.34.0-h2132df7_0
file:///opt/intel/oneapi/conda_channel/linux-64::xz-5.2.5-h85f8e93_2
file:///opt/intel/oneapi/conda_channel/linux-64::yaml-0.1.7-7
file:///opt/intel/oneapi/conda_channel/linux-64::zlib-1.2.11.1-h047b5d8_3
defaults/linux-64::glib-2.68.1-h36276a3_0
file:///opt/intel/oneapi/conda_channel/linux-64::hdf5-1.10.2-3
defaults/linux-64::libpng-1.6.37-hbc83047_0
file:///opt/intel/oneapi/conda_channel/linux-64::libprotobuf-3.14.0-hdfd0036_0
file:///opt/intel/oneapi/conda_channel/linux-64::libxml2-2.9.10-h58efa85_4
file:///opt/intel/oneapi/conda_channel/linux-64::tk-8.6.10-h8e2d9d6_2
defaults/linux-64::zeromq-4.3.4-h2531618_0
file:///opt/intel/oneapi/conda_channel/linux-64::zstd-1.4.5-ha6fa1a4_0
defaults/linux-64::dbus-1.13.18-hb2f20db_0
defaults/linux-64::freetype-2.10.4-h5ab3b9f_0
defaults/linux-64::gstreamer-1.14.0-h28cd5cc_2
file:///opt/intel/oneapi/conda_channel/linux-64::libarchive-3.4.2-hae7a978_7
file:///opt/intel/oneapi/conda_channel/linux-64::python-3.7.9-h86c8c07_7
file:///opt/intel/oneapi/conda_channel/linux-64::asn1crypto-1.4.0-py37_2
file:///opt/intel/oneapi/conda_channel/linux-64::async-timeout-3.0.1-py37h06a4308_0
defaults/linux-64::async_generator-1.10-py37h28b3542_0
file:///opt/intel/oneapi/conda_channel/linux-64::attrs-20.3.0-pyhd3eb1b0_0
defaults/noarch::backcall-0.2.0-pyhd3eb1b0_0
file:///opt/intel/oneapi/conda_channel/linux-64::blinker-1.4-py37_0
file:///opt/intel/oneapi/conda_channel/linux-64::cachetools-4.2.1-pyhd3eb1b0_0
defaults/linux-64::certifi-2020.12.5-py37h06a4308_0
file:///opt/intel/oneapi/conda_channel/linux-64::chardet-4.0.0-py37_0
file:///opt/intel/oneapi/conda_channel/linux-64::click-7.1.2-py_0
defaults/noarch::decorator-5.0.6-pyhd3eb1b0_0
defaults/noarch::defusedxml-0.7.1-pyhd3eb1b0_0
defaults/linux-64::entrypoints-0.3-py37_0
defaults/linux-64::fontconfig-2.13.1-h6c09931_0
file:///opt/intel/oneapi/conda_channel/linux-64::gast-0.3.3-py_0
defaults/linux-64::gst-plugins-base-1.14.0-h8213a91_2
file:///opt/intel/oneapi/conda_channel/linux-64::idna-3.1-py37_0
defaults/noarch::ipython_genutils-0.2.0-pyhd3eb1b0_1
defaults/noarch::jupyterlab_widgets-1.0.0-pyhd3eb1b0_1
defaults/linux-64::markupsafe-1.1.1-py37h14c3975_1
defaults/linux-64::mistune-0.8.4-py37h14c3975_1001
file:///opt/intel/oneapi/conda_channel/linux-64::multidict-4.7.6-py37h7b6447c_1
defaults/noarch::nest-asyncio-1.5.1-pyhd3eb1b0_0
defaults/linux-64::pandocfilters-1.4.3-py37h06a4308_1
defaults/noarch::parso-0.8.2-pyhd3eb1b0_0
defaults/noarch::pickleshare-0.7.5-pyhd3eb1b0_1003
defaults/noarch::prometheus_client-0.10.1-pyhd3eb1b0_0
defaults/noarch::ptyprocess-0.7.0-pyhd3eb1b0_2
file:///opt/intel/oneapi/conda_channel/linux-64::pyasn1-0.4.8-py_0
file:///opt/intel/oneapi/conda_channel/linux-64::pycosat-0.6.3-py37_6
file:///opt/intel/oneapi/conda_channel/linux-64::pycparser-2.20-py37_2
defaults/noarch::pyparsing-2.4.7-pyhd3eb1b0_0
defaults/linux-64::pyrsistent-0.17.3-py37h7b6447c_0
file:///opt/intel/oneapi/conda_channel/linux-64::pysocks-1.7.0-py37_2
file:///opt/intel/oneapi/conda_channel/linux-64::python-libarchive-c-2.8-py37_14
defaults/linux-64::pyzmq-20.0.0-py37h2531618_1
defaults/noarch::qtpy-1.9.0-py_0
file:///opt/intel/oneapi/conda_channel/linux-64::ruamel_yaml-0.15.99-py37h725dc98_6
defaults/noarch::send2trash-1.5.0-pyhd3eb1b0_1
defaults/linux-64::sip-4.19.8-py37hf484d3e_0
file:///opt/intel/oneapi/conda_channel/linux-64::six-1.15.0-py37_1
file:///opt/intel/oneapi/conda_channel/linux-64::tbb4py-2021.2.0-py37_intel_357
file:///opt/intel/oneapi/conda_channel/linux-64::tensorflow-estimator-2.3.0-pyheb71bc4_0
file:///opt/intel/oneapi/conda_channel/linux-64::termcolor-1.1.0-py37_1
defaults/noarch::testpath-0.4.4-pyhd3eb1b0_0
defaults/linux-64::tornado-6.1-py37h27cfd23_0
file:///opt/intel/oneapi/conda_channel/linux-64::tqdm-4.56.2-py37_0
defaults/noarch::wcwidth-0.2.5-py_0
defaults/linux-64::webencodings-0.5.1-py37_1
file:///opt/intel/oneapi/conda_channel/linux-64::werkzeug-1.0.1-py_0
file:///opt/intel/oneapi/conda_channel/linux-64::wrapt-1.12.1-py37h7b6447c_1
file:///opt/intel/oneapi/conda_channel/linux-64::zipp-3.4.0-pyhd3eb1b0_0
file:///opt/intel/oneapi/conda_channel/linux-64::absl-py-0.11.0-pyhd3eb1b0_1
file:///opt/intel/oneapi/conda_channel/linux-64::astunparse-1.6.3-py_0
file:///opt/intel/oneapi/conda_channel/linux-64::cffi-1.14.4-py37h14c3975_0
file:///opt/intel/oneapi/conda_channel/linux-64::conda-package-handling-1.4.1-py37_4
file:///opt/intel/oneapi/conda_channel/linux-64::google-pasta-0.2.0-py_0
file:///opt/intel/oneapi/conda_channel/linux-64::importlib-metadata-2.0.0-py_1
defaults/linux-64::jedi-0.17.0-py37_0
file:///opt/intel/oneapi/conda_channel/linux-64::mkl-service-2.3.0-py37hb9838c7_10
defaults/noarch::packaging-20.9-pyhd3eb1b0_0
defaults/noarch::pexpect-4.8.0-pyhd3eb1b0_3
defaults/noarch::prompt-toolkit-3.0.17-pyh06a4308_0
file:///opt/intel/oneapi/conda_channel/linux-64::pyasn1-modules-0.2.8-py_0
defaults/noarch::python-dateutil-2.8.1-pyhd3eb1b0_0
defaults/linux-64::qt-5.9.7-h5867ecd_1
file:///opt/intel/oneapi/conda_channel/linux-64::rsa-4.7-pyhd3eb1b0_1
file:///opt/intel/oneapi/conda_channel/linux-64::setuptools-51.1.2-py37_0
defaults/linux-64::terminado-0.9.4-py37h06a4308_0
defaults/noarch::traitlets-5.0.5-pyhd3eb1b0_0
file:///opt/intel/oneapi/conda_channel/linux-64::yarl-1.6.3-py37h27cfd23_0
file:///opt/intel/oneapi/conda_channel/linux-64::aiohttp-3.6.3-py37h7b6447c_0
defaults/linux-64::argon2-cffi-20.1.0-py37h27cfd23_1
defaults/noarch::bleach-3.3.0-pyhd3eb1b0_0
file:///opt/intel/oneapi/conda_channel/linux-64::cryptography-3.3.2-py37_0
file:///opt/intel/oneapi/conda_channel/linux-64::grpcio-1.31.0-py37hf8bcb03_0
defaults/noarch::jinja2-2.11.3-pyhd3eb1b0_0
defaults/linux-64::jsonschema-3.0.2-py37_0
defaults/linux-64::jupyter_core-4.7.1-py37h06a4308_0
file:///opt/intel/oneapi/conda_channel/linux-64::markdown-3.3.3-py37h06a4308_0
defaults/noarch::prompt_toolkit-3.0.17-hd3eb1b0_0
file:///opt/intel/oneapi/conda_channel/linux-64::protobuf-3.14.0-py37h2531618_1
defaults/noarch::pygments-2.8.1-pyhd3eb1b0_0
defaults/linux-64::pyqt-5.9.2-py37h05f1152_2
file:///opt/intel/oneapi/conda_channel/linux-64::tensorboard-plugin-wit-1.6.0-py_0
file:///opt/intel/oneapi/conda_channel/linux-64::wheel-0.36.2-py37_0
file:///opt/intel/oneapi/conda_channel/linux-64::google-auth-1.24.0-pyhd3eb1b0_0
defaults/linux-64::ipython-7.22.0-py37hb070fc8_0
defaults/noarch::jupyter_client-6.1.12-pyhd3eb1b0_0
defaults/noarch::jupyterlab_pygments-0.1.2-py_0
defaults/noarch::nbformat-5.1.3-pyhd3eb1b0_0
file:///opt/intel/oneapi/conda_channel/linux-64::pip-21.0.1-py37_0
file:///opt/intel/oneapi/conda_channel/linux-64::pyjwt-1.7.1-py37_0
file:///opt/intel/oneapi/conda_channel/linux-64::pyopenssl-20.0.1-py37_2
defaults/linux-64::ipykernel-5.3.4-py37h5ca1d4c_0
defaults/noarch::nbclient-0.5.3-pyhd3eb1b0_0
file:///opt/intel/oneapi/conda_channel/linux-64::oauthlib-3.1.0-py_0
file:///opt/intel/oneapi/conda_channel/linux-64::urllib3-1.26.3-py37_0
defaults/noarch::jupyter_console-6.4.0-pyhd3eb1b0_0
defaults/linux-64::nbconvert-6.0.7-py37_0
defaults/noarch::qtconsole-5.0.3-pyhd3eb1b0_0
file:///opt/intel/oneapi/conda_channel/linux-64::requests-2.25.1-py37_1
defaults/linux-64::notebook-6.3.0-py37h06a4308_0
file:///opt/intel/oneapi/conda_channel/linux-64::requests-oauthlib-1.3.0-py_0
file:///opt/intel/oneapi/conda_channel/linux-64::google-auth-oauthlib-0.4.2-pyhd3eb1b0_2
defaults/linux-64::widgetsnbextension-3.5.1-py37_0
defaults/noarch::ipywidgets-7.6.3-pyhd3eb1b0_1
defaults/linux-64::jupyter-1.0.0-py37_7
file:///opt/intel/oneapi/conda_channel/linux-64::dpcpp_cpp_rt-2021.2.0-intel_610
file:///opt/intel/oneapi/conda_channel/linux-64::icc_rt-2021.2.0-intel_610
file:///opt/intel/oneapi/conda_channel/linux-64::numpy-base-1.20.1-py37hffe281f_0
file:///opt/intel/oneapi/conda_channel/linux-64::mkl_fft-1.3.0-py37h9bd69cd_0
file:///opt/intel/oneapi/conda_channel/linux-64::mkl_random-1.2.1-py37h3617918_2
file:///opt/intel/oneapi/conda_channel/linux-64::mkl_umath-0.1.1-py37hc4b4d23_8
file:///opt/intel/oneapi/conda_channel/linux-64::numpy-1.20.1-py37h288f0c4_0
file:///opt/intel/oneapi/conda_channel/linux-64::h5py-2.8.0-py37h989c5e5_3
file:///opt/intel/oneapi/conda_channel/linux-64::opt_einsum-3.1.0-py_0
file:///opt/intel/oneapi/conda_channel/linux-64::scipy-1.6.1-py37haaffb16_2
file:///opt/intel/oneapi/conda_channel/linux-64::tensorboard-2.3.0-pyh4dce500_0
file:///opt/intel/oneapi/conda_channel/linux-64::keras-preprocessing-1.1.2-pyhd3eb1b0_0
file:///opt/intel/oneapi/conda_channel/linux-64::tensorflow-2.3.0-py37_0
Source: /opt/intel/oneapi/intelpython/latest/envs/tensorflow
Destination: /home/hpcadmin/fy/test_ai/tensorflow
Packages: 166
Files: 204
Preparing transaction: ...working... done
Verifying transaction: ...working... [ClobberError: This transaction has incompatible packages due to a shared path.
packages: file:///opt/intel/oneapi/conda_channel/linux-64::tensorboard-2.3.0-pyh4dce500_0, file:///opt/intel/oneapi/conda_channel/linux-64::tensorflow-2.3.0-py37_0
path: 'bin/tensorboard'
done
Executing transaction: ...working... ===> LINKING PACKAGE: defaults::ca-certificates-2021.4.13-h06a4308_1 <===
prefix=/home/hpcadmin/fy/test_ai/tensorflow
source=/root/.conda/pkgs/ca-certificates-2021.4.13-h06a4308_1
===> LINKING PACKAGE: file:///opt/intel/oneapi/conda_channel::common_cmplr_lib_rt-2021.2.0-intel_610 <===
source=/opt/intel/oneapi/intelpython/latest/pkgs/common_cmplr_lib_rt-2021.2.0-intel_610
Please let me know if I'm missing something.Thanks.
Thanks for posting in Intel forums.
We will check on this meanwhile could you share your steps followed for building AI toolkit image?
Janani Chandran
I found this error also occurred in the conda environment which is installed directly by Intel AI Toolkit.
Here is the info :
[root@head ~]# cd /opt/intel/oneapi/
[root@head oneapi]# cd pytorch/
[root@head pytorch]# ls
1.5.0 latest
[root@head pytorch]# cd latest/
[root@head latest]# ls
bin conda-meta etc install_pytorch.sh libexec pkgs shell sys_check x86_64-conda_cos6-linux-gnu
condabin env include lib licensing share ssl Untitled6.ipynb
[root@head latest]# cd bin
[root@head bin]#
[root@head bin]#
[root@head bin]# ls
2to3 fax2ps jupyter-run openssl sqlite3 wish8.6
2to3-3.7 fax2tiff jupyter-serverextension pal2rgb tclsh8.6 wrjpgcom
activate freetype-config jupyter-troubleshoot pip tiff2bw xml2-config
bsdcat idle3 jupyter-trust pngfix tiff2pdf xmlcatalog
bsdcpio idle3.7 libpng16-config png-fix-itxt tiff2ps xmllint
bsdtar iptest libpng-config ppm2tiff tiff2rgba xz
chardetect iptest3 lz4 pydoc tiffcmp xzcat
cjpeg ipython lz4c pydoc3 tiffcp xzcmp
conda ipython3 lz4cat pydoc3.7 tiffcrop xzdec
conda-env jpegtran lzcat pygmentize tiffdither xzdiff
convert-caffe2-to-onnx jsonschema lzcmp python tiffdump xzegrep
convert-onnx-to-caffe2 jupyter lzdiff python3 tiffinfo xzfgrep
cph jupyter-bundlerextension lzegrep python3.7 tiffmedian xzgrep
c_rehash jupyter-console lzfgrep python3.7-config tiffset xzless
deactivate jupyter-kernel lzgrep python3.7m tiffsplit xzmore
djpeg jupyter-kernelspec lzless python3.7m-config tqdm zstd
easy_install jupyter-migrate lzma python3-config unlz4 zstdcat
easy_install-3.7 jupyter-nbconvert lzmadec pyvenv unlzma zstdgrep
f2py jupyter-nbextension lzmainfo pyvenv-3.7 unxz zstdless
f2py3 jupyter-notebook lzmore raw2tiff unzstd zstdmt
f2py3.7 jupyter-qtconsole ninja rdjpgcom wheel
[root@head bin]#
[root@head bin]#
[root@head bin]#
[root@head bin]# source activate
(base) [root@head bin]#
(base) [root@head bin]# conda env list
/home/hpcadmin/conda
/home/hpcadmin/devtool_conda
/home/hpcadmin/jupyter_test
/home/hpcadmin/test_tensor/pytorch
/home/hpcadmin/test_tensor/tensorflow
base * /opt/intel/oneapi/pytorch/latest
/opt/miniconda
(base) [root@head bin]# conda create -y -v --clone base -p /opt/pytorch
Source: /opt/intel/oneapi/pytorch/latest
Destination: /opt/pytorch
- file:///opt/intel/oneapi/conda_channel/linux-64::conda-4.8.4-py37h926af72_10
Packages: 68
Files: 10673
File "/opt/intel/oneapi/pytorch/latest/lib/python3.7/site-packages/conda/exceptions.py", line 1079, in __call__
File "/opt/intel/oneapi/pytorch/latest/lib/python3.7/site-packages/conda/cli/main.py", line 84, in _main
File "/opt/intel/oneapi/pytorch/latest/lib/python3.7/site-packages/conda/cli/conda_argparse.py", line 83, in do_call
File "/opt/intel/oneapi/pytorch/latest/lib/python3.7/site-packages/conda/cli/main_create.py", line 41, in execute
File "/opt/intel/oneapi/pytorch/latest/lib/python3.7/site-packages/conda/cli/install.py", line 222, in install
File "/opt/intel/oneapi/pytorch/latest/lib/python3.7/site-packages/conda/cli/install.py", line 74, in clone
File "/opt/intel/oneapi/pytorch/latest/lib/python3.7/site-packages/conda/misc.py", line 286, in clone_env
File "/opt/intel/oneapi/pytorch/latest/lib/python3.7/site-packages/conda/misc.py", line 90, in explicit
AssertionError
`$ /opt/intel/oneapi/pytorch/latest/bin/conda create -y -v --clone base -p /opt/pytorch`
CIO_TEST=<not set>
CONDA_DEFAULT_ENV=base
CONDA_EXE=/opt/intel/oneapi/pytorch/latest/bin/conda
CONDA_PREFIX=/opt/intel/oneapi/pytorch/latest
CONDA_PROMPT_MODIFIER=(base)
CONDA_PYTHON_EXE=/opt/intel/oneapi/pytorch/latest/bin/python
CONDA_ROOT=/opt/intel/oneapi/pytorch/latest
CONDA_SHLVL=1
/gcc/9.3.0/lib64
/modulefiles
PATH=/opt/intel/oneapi/pytorch/latest/bin:/opt/intel/oneapi/pytorch/latest/
bin:/opt/miniconda/condabin:/opt/xcat/bin:/opt/xcat/sbin:/opt/xcat/sha
re/xcat/tools:/opt/ohpc/pub/libs/singularity/3.4.2/bin:/opt/ohpc/pub/m
pi/libfabric/1.10.1/bin:/opt/ohpc/pub/mpi/ucx-ohpc/1.8.0/bin:/opt/ohpc
/pub/mpi/openmpi4-gnu9/4.0.4/bin:/opt/ohpc/pub/compiler/gcc/9.3.0/bin:
/opt/ohpc/pub/utils/prun/2.0:/opt/ohpc/pub/bin:/opt/confluent/bin:/usr
/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/root/bin
gconfig
b/pkgconfig:1
active environment : base
active env location : /opt/intel/oneapi/pytorch/latest
shell level : 1
populated config files : /root/.condarc
conda version : 4.8.4
virtual packages : __glibc=2.28
base environment : /opt/intel/oneapi/pytorch/latest (writable)
channel URLs : https://repo.anaconda.com/pkgs/main/linux-64
package cache : /opt/intel/oneapi/pytorch/latest/pkgs
/root/.conda/pkgs
envs directories : /opt/intel/oneapi/pytorch/latest/envs
/root/.conda/envs
platform : linux-64
user-agent : conda/4.8.4 requests/2.24.0 CPython/3.7.9 Linux/4.18.0-193.el8.x86_64 centos/8.2.2004 glibc/2.28
UID:GID : 0:0
netrc file : None
Upload successful.
And I found an alternative :
conda env export -n pytorch > pytorch_environment.yml
conda env create -f pytorch_environment.yml -p /clone_path
I hope it can help to solve this problem。
This is a known issue and we are working on it.
There are other methods to use pytorch.You can use pytorch by creating AI toolkit pytorch environment with conda(https://software.intel.com/content/www/us/en/develop/articles/installing-ai-kit-with-conda.html#gs.0sd3qn) and by installing AI analytics toolkit(https://software.intel.com/content/www/us/en/develop/tools/oneapi/ai-analytics-toolkit/download.html?operatingsystem=linux).
Janani Chandran
Sorry for the late response. This issue is been fixed. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Janani Chandran
