Analyzers
Support for Analyzers (Intel VTune™ Profiler, Intel Advisor, Intel Inspector)
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
4679 Discussions
Exporting VTune ITT event durations?
msmart
Is it possible to export the duration values for ITT events? I'm currently trying to investigate an event that has high variance duration, so the average value reported via the VTune GUI isn't sufficient.
I know that I can zoom in on the timing graph, but that is manual. If the values can be exported, I could script it easily.
Thanks!
Rahila_T_Intel
Thank you for your feedback. We have provided your feedback to the relevant team.  At this moment there is no way to see any more about the duration values for ITT event as you mentioned, like maximum, minimum, or list of them.
Please let us know if we can go ahead and close this case.
Rahila_T_Intel
Thank you for posting in Intel communities.
Please let us know
1) The Operating System you are using.
2) The VTune version in which you are trying out.
so that we can investigate the issue from our end.
msmart
I am using Ubuntu 20.04 and VTune 2022.1.0.
Rahila_T_Intel
We are working on this. We will get back to you soon.
Rahila_T_Intel
It is not possible to export the duration values for ITT events. However, in the GUI bottom-up tab, you can right click on the timeline and sort by user tasks.
If this clarifies your query, make sure to accept this as a solution. This would help others with similar issue.
msmart
That sorting only gives the average duration of that user task. Is there any way to see any more about those values, such as the maximum, minimum, or even a list of them?
That would be a very helpful feature.
Rahila_T_Intel
Thanks for your suggestion. We will let the concerned team know about this.
Rahila_T_Intel
Rahila_T_Intel
We have not heard back from you. Is your issue resolved?
msmart
My apologies for the delay.
Yes you can close this case. I consider my question answered.
Rahila_T_Intel
Glad to know that your issue is resolved.
Thanks for accepting our solution. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
