Please take a look at this thread: https://software.intel.com/en-us/forums/intel-vtune-amplifier/topic/806896
If your system is running under a supervisor, you might have faced the same issue.
The link given in the answer is not working. Could you please fix it?
I'm using Windows
When I launch sep -version I see the following output:
I'm assuming PEBS OFF (by OS security) is the issue here?
sep -version Sampling Enabling Product version: 5.14 built on Nov 26 2019 11:44:09 SEP User Mode Version: 5.14 SEP Driver Version: 5.14 PAX Driver Version: 1.0 Platform type: 88 CPU name: Intel(R) Core(TM) Processor code named Haswell PMU: haswell Driver configs: Maskable Interrupt, PEBS OFF (by OS security), MULTI PEBS OFF (tracepoints not accessible) Copyright(C) 2007-2019 Intel Corporation. All rights reserved.
Jan,
The thread https://software.intel.com/en-us/forums/vtune/topic/827651 may be related. In particular post #8, where sep is redirected to a file. I asked for an update on my support ticket late on Friday.
Yes I seem to have the same issue. When outputting to a file I get this:
The cutoff point seems to be the same even.
I also ran into something else that may be related. When using User-Mode sampling I get the following error:
Cannot load data file 'C:\Users\Startklaar\Documents\Amplifier XE\Projects\Raytricca\r000hs\data.0\emon.0.emon' (Failed to read CPU topology information!).
yes. emon will be fixed in the next public release too.
sep/emon fixes will be available in oneApi beta update 4. Update will be released in the nearest days. I think you could subsrcribe on beta program and get fix.
Another way is update 1 for parallel studio. It should be available at the end of March.
If you have access to Intel® Premier Support (IPS) the fix could be provided for you directly.
Sorry for inconvenience, Kirill
Yes using sep_no_buf.exe it works now. Thanks!
