I encountered a problem when using Intel vtune profiler.
As shown in the figure below, I performed hot spot analysis on the program, but no results were displayed in the end. The error prompt is as shown in Figure 2.
Has anyone encountered a similar problem?
Could you share the VTune data with me? Let me check. The folder name should be r000hs, and can you provide the VTune version and platform information as well?
data file attached.
The version is VTune profiler 2024.2.1.
The platform is windows 11
Please specify a new working path and remove the special characters, like ® and ™. Try again.
D:\projects\PG_MHT\CAE-master\Code\main\Intel® VTune™ Profiler Results\PGThermoStr
problem solved. Thank you very much.
非常感谢!
Topic Options
