Big Ideas
See how hardware, software, and innovation come together.
65 Discussions
Validating Redis Enterprise Operator on Bare-Metal with Red Hat OpenShift
Ben_Han
Background
In the last 24 months, DB-Engines make it clear that the fastest-growing data models are key-value, search, document, graph and time series. Fewer developers are choosing to model their applications with relational databases. Popular applications that require user interaction generate multiple calls to the database, resulting in overhead and round trip latency between the end-user and application server, may cause an impact to the user experience, and may result in a loss of revenue for the service provider.
Figure 1 - Fastest Growing Data Models
Red Hat OpenShift is designed for automation, but scaling stateful applications may be challenging, typically requiring manual intervention. Removing a Pod means losing its data and disrupting the system. This is one of the key reasons why the Operator framework was developed. Operators were developed to handle stateful applications that the default Kubernetes controllers are not able to handle. With in-memory databases rising in popularity, it makes a lot of sense for Redis Labs to release a Redis Enterprise Operator.
In This Blog You Will Learn How To
  • Deploy a Red Hat OpenShift 3-node compact bare-metal cluster
  • Install Red Hat OpenShift Data Foundation & configure a Back Store
  • Install Redis Enterprise Operator
  • Optimize the Redis cluster & create a simple database
  • Setup memtier_benchmark and test functionality/performance
Deploy Red Hat OpenShift on Bare-Metal Servers
The following hardware was provided by Supermicro to setup the remote demo lab:
  • 1G Switch, SSE-G3648B
  • 100G Switch Supermicro, SSE-C3632S(R)
  • 2U 4-Node BigTwin, SYS-220BT-HNTR
Note: Nodes A, B and C were used for a 3-node compact cluster (each subsystem runs as a master + worker node)
Figure 2 - OCP 4.8 IPI Network Overview
1. Assign the network switches to each network:
  • BMC network (1G switch 172.24.121.0/24, Internet access)
  • 100G network (100G Supermicro SSE-C3632S(R) switch, 172.24.121.0/24, Internet access)
2. Assign IP addresses to the BMC LAN ports on an X12 BigTwin®:
  • Node A 172.24.121.51
  • Node B 172.24.121.52
  • Node C 172.24.121.53
  • Node D 172.24.121.54
3. Setup the DNS records for Red Hat OpenShift API VIP, Ingress VIP, and the nodes.
Domain name
IP address
bt01.mwc.openshift.smc
172.24.121.51
bt02.mwc.openshift.smc
172.24.121.52
bt03.mwc.openshift.smc
172.24.121.53
bt04.mwc.openshift.smc
172.24.121.54
*.apps.mwc.openshift.smc
172.24.121.66
api.mwc.openshift.smc
172.24.121.65
 Table 1-1. DNS Records
4. Reserve the DHCP IP addresses for the node BMC and OS LAN ports.
Node
OS IP address
BMC IP address
Note
Node A
172.24.121.61
172.24.121.51
Node B
172.24.121.62
172.24.121.52
Node C
172.24.121.63
172.24.121.53
Node D
172.24.121.64
172.24.121.54
Bastion node
Table 1-2. DHCP IP Addresses
Prepare Bastion Node with Red Hat Enterprise Linux 8
1. Install RHEL 8.3 to M.2 NVMe RAID VD on node D by BMC Virtual Media with ISO image via iKVM
2. Set up network 172.24.121.64/255.255.255.0,
Gateway 172.24.121.1
DNS 172.24.88.10, 8.8.8.8, 1.1.1.1
3. Use Red Hat Subscription Manager to register the provisioner node:
$ sudo subscription-manager register --username=<username> --password=<pass> --auto-attach
4. Add OCP/ODF 4.8 & ansible-2.9 into repolist, then check
$ sudo subscription-manager repos \
    --disable='*' \
    --enable=rhel-8-for-x86_64-appstream-rpms \
    --enable=rhel-8-for-x86_64-baseos-rpms \
    --enable=rhel-8-for-x86_64-highavailability-rpms \
    --enable=ansible-2.9-for-rhel-8-x86_64-rpms \
    --enable=rhocp-4.8-for-rhel-8-x86_64-rpms
Output:
Updating Subscription Management repositories.
repo id                                 repo name
ansible-2.9-for-rhel-8-x86_64-rpms      Red Hat Ansible Engine 2.9 for RHEL 8 x86_64 (RPMs)
rhel-8-for-x86_64-appstream-rpms        Red Hat Enterprise Linux 8 for x86_64 - AppStream (RPMs)
rhel-8-for-x86_64-baseos-rpms           Red Hat Enterprise Linux 8 for x86_64 - BaseOS (RPMs)
rhel-8-for-x86_64-highavailability-rpms Red Hat Enterprise Linux 8 for x86_64 - High Availability (RPMs)
rhocp-4.8-for-rhel-8-x86_64-rpms        Red Hat OpenShift Container Platform 4.8 for RHEL 8 x86_64 (RPMs)
5. Log in to the Bastion node (node D) via ssh
6. Run yum update -y for latest patches and update repos
$ sudo yum update -y
7. Enable Cockpit on RHEL8
$ sudo systemctl enable cockpit.socket
$ sudo systemctl start cockpit.socket
8. Add Virtual Machine, Container applications on RHEL Cockpit web UI
9. Upload the CentOS 8.3 LiveCD ISO image for the next step
10. Generate an SSH key pair and share the local SSH pub key to node D
11. Create a non-root user (kni) and provide that user with sudo privileges:
$ sudo su -
# useradd kni
# passwd kni
# echo "kni ALL=(root) NOPASSWD:ALL" | tee -a /etc/sudoers.d/kni
# chmod 0440 /etc/sudoers.d/kni
12. Create an ssh key for the new user and login as kni
# su - kni -c "ssh-keygen -t ed25519 -f /home/kni/.ssh/id_rsa -N ''"
# su - kni
13. Install the following packages:
$ sudo dnf install -y libvirt qemu-kvm mkisofs python3-devel jq ipmitool
14. Modify the user to add the libvirt group to the newly created user:
$ sudo usermod --append --groups libvirt kni
$ sudo usermod --append --groups libvirt twinuser
15. Restart firewalld and enable the http service:
$ sudo systemctl start firewalld
$ sudo firewall-cmd --zone=public --add-service=http --permanent
$ sudo firewall-cmd –reload
16. Start and enable the libvirtd service:
$ sudo systemctl enable libvirtd --now
$ sudo systemctl status libvirtd
Output:
libvirtd.service - Virtualization daemon
    Loaded: loaded (/usr/lib/systemd/system/libvirtd.service; enabled; vendor preset: enabled)
    Active: active (running) since Mon 2021-11-08 13:56:42 PST; 15s ago
Docs: man:libvirtd(8)
      https://libvirt.org
Main PID: 18184 (libvirtd)
    Tasks: 19 (limit: 32768)
  Memory: 61.1M
  CGroup: /system.slice/libvirtd.service
          ├─ 4169 /usr/sbin/dnsmasq --conf-file=/var/lib/libvirt/dnsmasq/default.conf --leasefile-ro --dhcp-script=/usr/libexec/libvirt_leaseshelper
          ├─ 4170 /usr/sbin/dnsmasq --conf-file=/var/lib/libvirt/dnsmasq/default.conf --leasefile-ro --dhcp-script=/usr/libexec/libvirt_leaseshelper
          └─18184 /usr/sbin/libvirtd --timeout 120
Nov 08 13:56:42 bastion1.openshift.smc systemd[1]: Starting Virtualization daemon...
Nov 08 13:56:42 bastion1.openshift.smc systemd[1]: Started Virtualization daemon.
Nov 08 13:56:42 bastion1.openshift.smc dnsmasq[4169]: read /etc/hosts - 2 addresses
Nov 08 13:56:42 bastion1.openshift.smc dnsmasq[4169]: read /var/lib/libvirt/dnsmasq/default.addnhosts - 0 addresses
Nov 08 13:56:42 bastion1.openshift.smc dnsmasq-dhcp[4169]: read /var/lib/libvirt/dnsmasq/default.hostsfile
17. Create the default storage pool and start it:
$ sudo virsh pool-define-as --name default --type dir --target /var/lib/libvirt/images
$ sudo virsh pool-start default
$ sudo virsh pool-autostart default
18. Install a DHCP serve
$ sudo yum install dhcp-server
$ sudo vi /etc/dhcp/dhcpd.conf  #### Copy etc-dhcp-dhcpd.conf to /etc/dhcp/dhcpd.conf
$sudo systemctl enable --now dhcpd
19. If you have the firewalld running, allow the service port to be accessible from your network.
$ sudo firewall-cmd --add-service=dhcp --permanent
$ sudo firewall-cmd --reload
Prepare Target Hardware
1. Update SYS-220BT-HNTR BMC and BIOS firmware
  • BMC version 1.02.04 (built on 10/27/2021)
  • BIOS version 1.2 (built on 2/12/2022)
2. Wipe the OS drive on the target node with CentOS 8.3 LiveCD by BMC VirtualMedia
$ sudo wipefs -a /dev/nvme0n1
/dev/nvme0n1
$ sudo wipefs -a /dev/nvme1n1
/dev/nvme1n1
$ sudo wipefs -a /dev/nvme2n1
/dev/nvme2n1
3. Collect MAC addresses for NIC1 (connect to 100G switch) and NIC2 (connect to 25G switch)
$ ip a
4. Reboot the system and enter BIOS
5. Switch Virtual Media -- "UEFI USB CD/DVD:UEFI: ATEN Virtual CDROM YS0J" as 2nd boot order
6. Set Boot mode as Dual (prefer UEFI)
7. Clean up PXE list
Prepare the Provisioning Environment
1. Configure network bridges for OpenShift Bootstrap VM.
2. Export the baremetal network NIC name:
$ export PUB_CONN=baremetal
3. Configure the baremetal network:
$ sudo nohup bash -c "
  nmcli con down \"$PUB_CONN\"
  nmcli con delete \"$PUB_CONN\"  # RHEL 8.1 appends the word \"System\" in
  front of the connection, delete in case it exists
  nmcli con down \"System $PUB_CONN\"
  nmcli con delete \"System $PUB_CONN\"
  nmcli connection add ifname baremetal type bridge con-name baremetal
  nmcli con add type bridge-slave ifname \"$PUB_CONN\" master baremetal
  pkill dhclient;dhclient baremetal
4. Export the provisioning network:
$ export PROV_CONN=provisioning
5. Configure the provisioning network:
  nmcli con down \"$PROV_CONN\"
  nmcli con delete \"$PROV_CONN\"
  nmcli connection add ifname provisioning type bridge con-name provisioning
  nmcli con add type bridge-slave ifname \"$PROV_CONN\" master provisioning
  nmcli connection modify provisioning ipv6.addresses fd00:1101::1/64 ipv6.method manual
  nmcli con down provisioning
  nmcli con up provisioning
6. Verify the connection bridges have been properly created.
$ sudo nmcli con show
NAME          UUID                                  TYPE      DEVICE
baremetal
7. Get pull-secret.txt from Red Hat Cloud console
8. Retrieve the Red Hat OpenShift Container Platform installer using the following steps:
$ export VERSION=4.8.27
$ export RELEASE_IMAGE=$(curl -s https://mirror.openshift.com/pub/openshift-v4/clients/ocp/$VERSION/release.txt | grep 'Pull From: quay.io' | awk -F ' ' '{print $3}')
9. Extract the Red Hat OpenShift Container Platform installer
10. After retrieving the installer, the next step is to extract it.
11. Set the environment variables:
$ export cmd=openshift-baremetal-install
$ export pullsecret_file=~/pull-secret.txt
$ export extract_dir=$(pwd)
12. Get oc binary
$ curl -s https://mirror.openshift.com/pub/openshift-v4/clients/ocp/$VERSION/openshift-client-linux.tar.gz | tar zxvf - oc
$ sudo cp oc /usr/local/bin
13. Get the installer
$ oc adm release extract --registry-config "${pullsecret_file}" --command=$cmd --to "${extract_dir}" ${RELEASE_IMAGE}
$ sudo cp openshift-baremetal-install /usr/local/bin
14. Create a Red Hat Enterprise Linux Core OS image cache
a. Install Podman
$ sudo dnf install -y podman
b. Open firewall port 8080 to be used for RHCOS image caching
$ sudo firewall-cmd --add-port=8080/tcp --zone=public –permanent
c. Create a directory to store the bootstraposimage and clusterosimage:
$ mkdir /home/kni/rhcos_image_cache
d. Check the storage devices’ capacity
$ df -h
Filesystem             Size  Used Avail Use% Mounted on
devtmpfs                87G     0   87G   0% /dev
tmpfs                   87G     0   87G   0% /dev/shm
tmpfs                   87G   19M   87G   1% /run
tmpfs                   87G     0   87G   0% /sys/fs/cgroup
/dev/mapper/rhel-root   70G  7.3G   63G  11% /
/dev/nvme1n1p1         3.1T   22G  3.1T   1% /var/lib/libvirt/images
/dev/sda1             1014M  326M  689M  33% /boot
/dev/mapper/rhel-home  149G  1.9G  147G   2% /home
tmpfs                   18G   20K   18G   1% /run/user/42
tmpfs                   18G  4.0K   18G   1% /run/user/1000
e. Set the appropriate SELinux context for the newly created directory:
$ sudo semanage fcontext -a -t httpd_sys_content_t "/home/kni/rhcos_image_cache(/.*)?"
$ sudo restorecon -Rv rhcos_image_cache/
f. Relabel /home/kni/rhcos_image_cache from unconfined_u:object_r:user_home_t:s0 to unconfined_u:object_r:httpd_sys_content_t:s0
g. Get the commit ID from the installer:
$ export COMMIT_ID=$(/usr/local/bin/openshift-baremetal-install version | grep '^built from commit' | awk '{print $4}')
The ID determines which images the installer needs to download.
h. Get the URI for the RHCOS image that the installer will deploy on the nodes:
$ export RHCOS_OPENSTACK_URI=$(curl -s -S https://raw.githubusercontent.com/openshift/installer/$COMMIT_ID/data/data/rhcos.json  | jq .images.openstack.path | sed 's/"//g')
i. Get the URI for the RHCOS image that the installer will deploy on the bootstrap VM:
$ export RHCOS_QEMU_URI=$(curl -s -S https://raw.githubusercontent.com/openshift/installer/$COMMIT_ID/data/data/rhcos.json  | jq .images.qemu.path | sed 's/"//g')
j. Get the path where the images are published:
$ export RHCOS_PATH=$(curl -s -S https://raw.githubusercontent.com/openshift/installer/$COMMIT_ID/data/data/rhcos.json | jq .baseURI | sed 's/"//g')
k. Get the SHA hash for the RHCOS image that will be deployed on the bootstrap VM:
$ export RHCOS_QEMU_SHA_UNCOMPRESSED=$(curl -s -S https://raw.githubusercontent.com/openshift/installer/$COMMIT_ID/data/data/rhcos.json  | jq -r '.images.qemu["uncompressed-sha256"]')
l. Get the SHA hash for the RHCOS image that will be deployed on the nodes
$ export RHCOS_OPENSTACK_SHA_COMPRESSED=$(curl -s -S https://raw.githubusercontent.com/openshift/installer/$COMMIT_ID/data/data/rhcos.json  | jq -r '.images.openstack.sha256')
m. Download the images and place them in the /home/kni/rhcos_image_cache directory:
$ curl -L ${RHCOS_PATH}${RHCOS_QEMU_URI} -o /home/kni/rhcos_image_cache/${RHCOS_QEMU_URI}
$ curl -L ${RHCOS_PATH}${RHCOS_OPENSTACK_URI} -o /home/kni/rhcos_image_cache/${RHCOS_OPENSTACK_URI}
n. Confirm SELinux type is of httpd_sys_content_t for the newly created files:
$ ls -Z /home/kni/rhcos_image_cache
o. Create the pod
$ podman run -d --name rhcos_image_cache -v /home/kni/rhcos_image_cache:/var/www/html -p 8080:8080/tcp registry.centos.org/centos/httpd-24-centos7:latest
The above command creates a caching webserver with the name rhcos_image_cache, which serves the images for deployment. The first image ${RHCOS_PATH}${RHCOS_QEMU_URI}?sha256=${RHCOS_QEMU_SHA_UNCOMPRESSED} is the bootstrapOSImage and the second image ${RHCOS_PATH}${RHCOS_OPENSTACK_URI}?sha256=${RHCOS_OPENSTACK_SHA_COMPRESSED} is the clusterOSImage in the install-config.yaml file.
p. Generate the bootstrapOSImage and clusterOSImage configuration:
$ export BAREMETAL_IP=$(ip addr show dev baremetal | awk '/inet /{print $2}' | cut -d"/" -f1)
$ export RHCOS_OPENSTACK_SHA256=$(zcat /home/kni/rhcos_image_cache/${RHCOS_OPENSTACK_URI} | sha256sum | awk '{print $1}')
$ export RHCOS_QEMU_SHA256=$(zcat /home/kni/rhcos_image_cache/${RHCOS_QEMU_URI} | sha256sum | awk '{print $1}')
$ export CLUSTER_OS_IMAGE="http://${BAREMETAL_IP}:8080/${RHCOS_OPENSTACK_URI}?sha256=${RHCOS_OPENSTACK_SHA256}"
$ export BOOTSTRAP_OS_IMAGE="http://${BAREMETAL_IP}:8080/${RHCOS_QEMU_URI}?sha256=${RHCOS_QEMU_SHA256}"
$ echo "${RHCOS_OPENSTACK_SHA256}  ${RHCOS_OPENSTACK_URI}" > /home/kni/rhcos_image_cache/rhcos-ootpa-latest.qcow2.md5sum
$ echo "    bootstrapOSImage: ${BOOTSTRAP_OS_IMAGE}"
  bootstrapOSImage: http://172.24.121.64:8080/rhcos-48.84.202109241901-0-qemu.x86_64.qcow2.gz?sha256=50377ba9c5cb92c649c7d9e31b508185241a3c204b34dd991fcb3cf0adc53983
$ echo "    clusterOSImage: ${CLUSTER_OS_IMAGE}"
  clusterOSImage: http://172.24.121.64:8080/rhcos-48.84.202109241901-0-openstack.x86_64.qcow2.gz?sha256=e0a1d8a99c5869150a56b8de475ea7952ca2fa3aacad7ca48533d1176df503ab
  1. Prepare the configuration files
    1. Prepare the config yaml file as install-config.yaml. In this deployment, Redfish Virtual Media was used on a baremetal network.
     Hence, the “ipmi” will be replaced by “redfish-virtualmedia”
b. Add the provisioningNetwork: "Disabled" below the ingressVIP attribute
c. Add “disableCertificateVerification: True” below the password attribute since our BMC uses self-signed SSL certificates
d. Put the NIC1 (connected to baremetal network) MAC address on the bootMACAddress attribute.
e. Put the worker’s replicas attribute to be 0 for the compact cluster as Figure 3.1
compute:
- name: worker
replicas: 0
Figure 3.1 – Worker Replica Values = 0
Figure 3.2 – 3-Node Configuration in yaml File
f. Create a directory to store the cluster configurations.
$ mkdir ~/clusterconfigs
$ cp install-config.yaml ~/clusterconfigs
16. Ensure all bare metal nodes are powered off prior to installing the OpenShift Container Platform cluster.
$ ipmitool -I lanplus -U <user> -P <password> -H <management-server-ip> power off
17. Remove old bootstrap resources if any are left over from a previous deployment attempt.
$ for i in $(sudo virsh list | tail -n +3 | grep bootstrap | awk {'print $2'});
do
  sudo virsh destroy $i;
  sudo virsh undefine $i;
  sudo virsh vol-delete $i --pool $i;
  sudo virsh vol-delete $i.ign --pool $i;
  sudo virsh pool-destroy $i;
  sudo virsh pool-undefine $i;
done
18. Clean up and prepare env.
$ openshift-baremetal-install --dir ~/clusterconfigs --log-level debug destroy cluster
$ cp install-config.yaml ./clusterconfigs/install-config.yaml
19. Create a cluster with openshift-baremetal-install
$ openshift-baremetal-install --dir ~/clusterconfigs  --log-level debug create  cluster
20. If the installer times out, use the following command to wait for bootstrap VM to complete jobs.
Suggest to use iKVM to run the command to avoid the SSH session timeout.
$ openshift-baremetal-install --dir ~/clusterconfigs wait-for  bootstrap-complete
21. Once the installer completes, it will show a message like the following;
DEBUG Cluster is initialized
INFO Waiting up to 10m0s for the openshift-console route to be created...
DEBUG Route found in openshift-console namespace: console
DEBUG OpenShift console route is admitted
INFO Install complete!
INFO To access the cluster as the system:admin user when using 'oc', run 'export KUBECONFIG=/home/kni/clusterconfigs/auth/kubeconfig'
INFO Access the OpenShift web-console here: https://console-openshift-console.apps.compact.openshift.smc
INFO Login to the console with user: "kubeadmin", and password: "XXXXX-yyyyy-ZZZZZ-aaaaa"
DEBUG Time elapsed per stage:
DEBUG Cluster Operators: 18m0s
INFO Time elapsed: 18m0s
Figure 3.3 – Red Hat OpenShift 4.8 IPI Network Overview
Post-Installation Configuration
  1. Login to the Red Hat OpenShift web console with the kubeadmin credential
Figure 4.1 - Red Hat OpenShift Web Console View
Figure 4.2 - Node Roles of Red Hat OpenShift Cluster
Figure 4.3 - Red Hat OpenShift Administrator Overview
Figure 4.4 - Red Hat OpenShift Cluster Inventory
2. Install httpd-tools for creating an htpasswd-ocp file for a cluster OAuth configuration as the identity provider
$ sudo dnf -y install httpd-tools
$ htpasswd -c ~/installer/htpasswd-ocp  twinuser
3. Add Identity Provider – HTPasswd
Figure 4.5 - Add Identity Provider
4. Upload htpasswd-ocp
Figure 4.6 - Upload Password File
5. Add role-binding to the users
$ oc adm policy add-cluster-role-to-user cluster-admin twinuser
$ oc adm policy add-cluster-role-to-user cluster-admin redisuser
6. Install Red Hat OpenShift Container Storage Operator*:
*Note: Test configuration used OpenShift Container Storage version 4.8.9
Figure 4.7 - Installing Container Storage Operator
Figure 4.8 - Installing Hyperconverged Storage
Figure 4.9 - Create Storage Cluster
7. Install LocalStorage Operator for Local Storage
Figure 4.10 - Create Storage Cluster
8. Create StorageCluster with the ”Internal – Attached Devices”
Figure 4.11 - Choosing Internal – Attached Devices
Figure 4.12 - Choosing Disks on Selected Nodes
Figure 4.13 - Choosing Disks on Selected Nodes Continued
9. Red Hat OpenShift Data Foundation 4.8.3 operator creates Block Pools
Figure 4.14 - Block Pools Creation
10. Red Hat OpenShift Data Foundation 4.8.3 operator creates Backing Store for Object Storage service
Figure 4.15 - Backing Store Creation
11. Check Red Hat OpenShift Data Foundation Overview
Figure 4.16 - Red Hat OpenShift Data Foundation: Block and File View
12. Check Object Service
Figure 4.17 - Red Hat OpenShift Data Foundation: Object View
Redis Cluster Topology
1. Red Hat OpenShift Compact Cluster Topology
Figure 5.1 -  Redis Cluster Topology on Supermicro Compact Cluster
Figure 5.2 -  Kubernetes Abstraction for Test Cluster
2. Redis Enterprise Operator and Redis Enterprise Cluster objects/entities:
[redisuser@redisbench ~]$ oc get all -l name=redis-enterprise-operator
NAME                                             READY   STATUS    RESTARTS   AGE
pod/redis-enterprise-operator-7c4fdb7987-4drvv   2/2     Running   0          43h
NAME                                                   DESIRED   CURRENT   READY   AGE
replicaset.apps/redis-enterprise-operator-7c4fdb7987   1         1         1       2d1h
[redisuser@redisbench ~]$ oc get all -l app=redis-enterprise
pod/rec-0                                  2/2     Running   0          21h
pod/rec-1                                  2/2     Running   0          21h
pod/rec-2                                  2/2     Running   0          21h
pod/rec-services-rigger-7bfc6bb7f8-szqd5   1/1     Running   0          21h
NAME                         TYPE           CLUSTER-IP       EXTERNAL-IP   PORT(S)                      AGE
service/rec                  ClusterIP      None             <none>        9443/TCP,8001/TCP,8070/TCP   21h
service/rec-ui               ClusterIP      172.30.190.185   <none>        8443/TCP                     21h
service/redb-headless        ClusterIP      None             <none>        13062/TCP                    21h
service/redb-load-balancer   LoadBalancer   172.30.54.186    <pending>     13062:30056/TCP              21h
NAME                                  READY   UP-TO-DATE   AVAILABLE   AGE
deployment.apps/rec-services-rigger   1/1     1            1           21h
replicaset.apps/rec-services-rigger-7bfc6bb7f8   1         1         1       21h
NAME                   READY   AGE
statefulset.apps/rec   3/3     21h
NAME                                      HOST/PORT                                               PATH   SERVICES   PORT         TERMINATION            WILDCARD
route.route.openshift.io/rec-ui           rec-ui-redis-ent3.apps.mwc.openshift.smc                  rec-ui     ui           passthrough/Redirect   None
Install Redis Enterprise Operator and Configure Redis Cluster
1. Install Redis Enterprise Operator from OperatorHub Marketplace
  1. Select or create a new project (namespace) e.g.
$ oc create namespace redis-enterprise
      b. If the name of Redis Enterprise Cluster in the spec will be changed from default one – please issue
$ oc adm policy add-scc-to-group redis-enterprise-scc system:serviceaccounts:redis-enterprise
 Figure 6.1 -  Install Redis Enterprise Operator
NOTE:  <redis-enterprise> here is the actual name of the project/namespace.
  • In RH OCP UI go to Operator 🡪 OperatorHub and search for “Redis Enterprise”, select Redis Enterprise Operator  and click on “Install” button
Figure 6.2 -  OperatorHub
  • Select install mode and updates related options:
Figure 6.3 -  Install Operator
2. Setup Redis Enterprise Cluster
a) Prepare Red Hat OpenShift secret with Redis Enterprise License
    license.yml:
Figure 6.4 -  Redis Enterprise License
b) oc apply -f license.yml
c) Prepare yaml file for RedisEnterpriseCluster  (cluster.yml )
For Example, Redis Enterprise Operator may look like below:
Figure 6.5 -  RedisEnterpriseCluster yaml file
Note:
 redisEnterpriseNodeResources: limits: memory is contributing to the calculation of the total possible dataset (Redis single DB size)
d) Create RedisEnterpriseCluster
$ oc apply -f cluster.yml
e) Create rec-ui route to have browser access to Redis Enterprise UI
$ oc create route passthrough <name e.g. rec-ui> --service=rec-ui --insecure-policy=redirect --
Output:
route.route.openshift.io/rec-ui created
To get url – issue ‘oc get routes’ and look for rec-ui entry
Make sure to prepend https:// to address/string in the HOST/PORT column
Note:  Credentials – user and password are kept within ‘rec’ secret
Optimize Redis Enterprise Cluster and Create Database
  1. Tune the cluster – Use rladmin commands from one of the pods, e.g rec-0 (oc rsh po/rec-0):
a. Increase proxy threads count (rladmin) to better deal with expected load
$ rladmin tune proxy all max_threads 32
Configuring proxies:
- proxy:1,2,3: ok
$ rladmin tune proxy all threads 32
- proxy:1,2,3: ok
b. Change default shard placement policy from dense to sparse
$ rladmin tune cluster default_shards_placement sparse
Finished successfully
c. Set default Redis version to 6.2
$ rladmin tune cluster redis_upgrade_policy latest; rladmin tune cluster default_redis_version 6.2
  1. Setup Redis Enterprise Database (REDB)
a) Create db.yml
Figure 7 -  Setup Redis Enterprise Database yaml file
Note:
memorySize when replication is set to true – one has to remember that this is the limit for the sum of both primary shards and replica shards – so the total size across all master shards will be memorySize/2 (the maximum dataset size you can store in the database is 50% of memorySize).
b) Apply created manifest for the RedisEnterpriseDatabase
$ oc apply -f db.yml
Note: One can leverage OpenShift UI to create Redis Enterprise resources via Redis Enterprise Operator or use oc and use as templates yaml files provided here
c) If in db.yml there is lack of entry “ossCluster: true” -> Tune the database - set OSS mode. To enable the OSS Cluster API for the database, run:
$ rladmin tune db <database name or ID> oss_cluster enabled
Tuning database: BDB oss_cluster set to enabled.
Setup memtier_benchmark Jobs
  1. Setup environment for tests
Redis database population and load tests are being executed from one of the OCP cluster nodes using k8s jobs leveraging docker image redislabs/memtier_benchmark:edge
Jobs for DB population and benchmark tests are using yaml templates processed by kustomize plugin (oc create -k <directory with templates> )
To pin a benchmark job to a given node,  the node needs to labelled:
$ oc label node bt03.mwc.openshift.smc node=redis-client
node/bt03.mwc.openshift.smc labeled
2. Setup Docker and   on the bastion host to leverage playbooks running and parsing results of memtier_benchmark
Make sure there is and Docker available on the bastion host. Install it if it’s not yet there.
Before execution of provided ansible-playbooks:
  • Prepare Inventory file
To create an `inventory` file, copy the content of `inventory.example` file and replace the example hostnames for `[computes]`, `[utility]` and `[clients]` groups with own hostnames or IPs. Utility host is corresponding to bastion host/Ansible controller VM.
* The `[computes]` group specifies k8s nodes, where redis-cluster(s) instances are deployed.
* The `[utility]` group specifies a node, which runs the playbooks (Ansible controller). The node can reside outside of the k8s cluster, but it needs to be able to communicate with the cluster.
* The `[clients]` group specifies k8s nodes, which run memtier_benchmark instances.
  • Change default values of environment variables
There are two ways to change default values of environment variables:
Note: by passing new values as command-line arguments when invoking playbooks:
$ <variable1>=<value1> <variable2>=<value2> ansible-playbook -i inventory <playbook_name>.yml
* by modifying content of `vars/*` files. To change the value, find corresponding variable name (named according to convention: `<variable name>_default`) in `vars/vars.yml` and overwrite its value. A share of the environment variables is described in [Environment variables (selection)](#environment-variables-selection) paragraph.
e.g. below is section for memtier_benchmark specific params:
threads_default: 7
clients_default: 7
datasize_default: 100
pipeline_default: 4
requests_default: 500000000
run_count_default: 3
test_time_default: 300
ratio_default: "1:4"
key_pattern_default: "G:G"
  • Prepare the bastion host (Install required python packages & required Ansible collections)
$ ansible-playbook -i inventory setup.yml
from the directory with ansible-playbook’s
3. Populate Redis database
$ run_id=<run_identifier> ansible-playbook -i inventory populate_ocp.yml
4. Run benchmarks
$ run_id=<run_identifier> ansible-playbook -i inventory run_benchmark_ocp.yml
5. Clean (flush) Redis database
$ ansible-playbook -i inventory flushdb.yml
Telemetry – Prometheus and Grafana
  1. Navigate to OperatorHub and install community Prometheus Operator
  2. Setup Prometheus service monitor to collect data exported by redis-exporter included in redis enterprise cluster
Figure 8.1 -  Setup Redis Monitor
3.  Set up Prometheus instance, e.g.
Figure 8.2 -  Setup Prometheus Instance
4. Navigate to OperatorHub and install community-powered Grafana operator.
5. Create Grafana instance
Figure 8.3 -  Setup Grafana Instance
6. Add data sources
a) Add Prometheus from step 2
 Figure 8.4 -  Add Data Source from Prometheus Instance
b) Add built-in Prometheus
Grant cluster-monitoring-view cluster role for service account used by custom Grafana instance
$ oc adm policy add-cluster-role-to-user cluster-monitoring-view -z grafana-serviceaccount
c) Create the GrafanaDataSource object.
Figure 8.5 -  Create GrafanaDataSource Object
Substitute ${BEARER_TOKEN} with token retrieved by this command:
$ oc serviceaccounts get-token grafana-serviceaccount -n redis-enterprise
7. You can add Grafana dashboards either from Grafana-operator CDR or with Grafana GUI exposed by default grafana-route, after login to  with credentials in ‘grafana-admin-credentials’ secret.
Figure 8.6 -  Add Grafana Dashboard
8. Add Grafana apikey to post annotations.
a) Create with command line
$ grafana_cred=`oc get secret grafana-admin-credentials -o go-template --template="{{.data.GF_SECURITY_ADMIN_PASSWORD|base64decode}}"`
curl --insecure -X POST -H "Content-Type: application/json" -d '{"name":"annotation_apikey", "role": "Editor"}' https://admin:$grafana_cred@grafana-route-redis-ent.apps.mwc.openshift.smc/api/auth/keys
Output:
{"id":2,"name":"annotation_apikey","key":"eyJrIjoiaFJRU2s4TDJTdVZJSkUwb1o1dDJNQTlrM1VVaTU3THIiLCJuIjoiYW5ub3RhdGlvbl9hcGlrZXkyIiwiaWQiOjF9"}
b) Add the key to the secret
Figure 8.7 -  Add Grafana apikey to Post Annotations
Memtier Benchmark Results
Benchmark logs and run metadata are stored `{{ logdir_default }}/{{ log_dir_structure }}` directory on bastion host (variables values are set in `vars/vars.yml`)
The benchmark results are also stored in the Red Hat OpenShift cluster as long as the kubernetes jobs are not cleaned up. The playbook exports them to local files on the bastion host VM and combine the parsed results with additional metadata like Grafana urls to Redis and OS level metrics dashboards.
Exemplary results:
cat def-vars15-benchmark_results_core_metrics.txt
Run_id: def-vars15, timestamp: 1641390131
Total throughput of single redis-cluster [AGGREGATED AVERAGE RESULTS]:
1187561.27
p99 latency (SETs and GETs) of single redis-cluster [AGGREGATED AVERAGE RESULTS]:
0.94
Total throughput of single redis-cluster [BEST RUN RESULTS]:
1219660.06
p99 latency (SETs and GETs) of single redis-cluster [BEST RUN RESULTS]:
0.95
#Cluster Overview:
https://grafana-route-redis-ent3.apps.mwc.openshift.smc/d/viroIzSGz/cluster-overview?orgId=1&from=1641390142066&to=1641391056597&var-cluster=Redis%20Enterprise%20Software&var-interval=5min
#Cluster Databases
https://grafana-route-redis-ent3.apps.mwc.openshift.smc/d/k_A8MjtMk/cluster-databases?orgId=1&from=1641390142066&to=1641391056597&var-cluster=Redis%20Enterprise%20Software&var-interval=5min&var-node=All
#Cluster Nodes
https://grafana-route-redis-ent3.apps.mwc.openshift.smc/d/hqze6rtGz/cluster-nodes?orgId=1&from=1641390142066&to=1641391056597&var-cluster=Redis%20Enterprise%20Software&var-interval=5min&var-node=All
#Redis
https://grafana-route-redis-ent3.apps.mwc.openshift.smc/d/RpSjVqWMz/redis?orgId=1&from=1641390142066&to=1641391056597&var-cluster=Redis%20Enterprise%20Software&var-interval=5min&var-node=All
#OCP (k8s) cluster nodes
https://grafana-openshift-monitoring.apps.mwc.openshift.smc/d/JMnL9O57z/use-method-node?orgId=1&var-datasource=prometheus&var-instance=nodec&from=1641390142066&to=1641391056597
Storing results on S3 MinIO:
The benchmark will be executed with “--extra-vars "@vars/s3_vars.yml"
After setting up MinIO deployment (e.g. via Bitnami helm chart) and populating S3 variables in vars/s3_vars.yml file one can access MinIO UI console and get to memtier_benchmark results via web browser
Steps:
  1. Install helm on ansible-host
Source: https://helm.sh/docs/intro/install/#from-script
2. Setup helm repo
Source:  https://bitnami.com/stack/minio/helm
3. Install MinIO
helm install  minio-via-helm --set persistence.storageClass=ocs-storagecluster-cephfs --set service.type=NodePort  bitnami/minio
To get your credentials run:
export ROOT_USER=$(kubectl get secret --namespace redis-enterprise minio-via-helm -o jsonpath="{.data.root-user}" | base64 --decode)
export ROOT_PASSWORD=$(kubectl get secret --namespace redis-enterprise minio-via-helm -o jsonpath="{.data.root-password}" | base64 --decode)
To access the MinIOweb UI:
- Get the MinIO&reg; URL:
export NODE_PORT=$(kubectl get --namespace redis-enterprise -o jsonpath="{.spec.ports[0].nodePort}" services minio-via-helm)
export NODE_IP=$(kubectl get nodes --namespace redis-enterprise -o jsonpath="{.items[0].status.addresses[0].address}")
echo "minio&reg; web URL: http://$NODE_IP:$NODE_PORT/minio"
Example of MinIO Console:  http://172.24.121.61:32645/buckets
Figure 9 -  Storing Results on S3 MinIO
Appendix
List of Hardware Used in Compact Cluster
Base configuration for Red Hat OpenShift & Redis Enterprise Cluster:
System: SYS-220BT-HNTR
CPU: Dual Intel Gold Xeon Scalable Processors 8352V
Network Controller Cards: Intel E810 series
Data Drive: 2x Intel P5510 3.84TB NVMe PCI-E Gen4 Drives
Boot Drives: 2x M.2 NVMe Drives with HW RAID 1 support via AOC-SMG3-2M2-B
SSE-C3632S(R): 100GbE QSFP28 Cumulus-interfaced switch (Bare-Metal Network)
SSE-G3648B(R): 1/10GbE Base-T Cumulus-interfaced switch (BMC Management Switch)
Test Plan for Red Hat OpenShift & Redis Enterprise
Utilize Red Hat OpenShift for orchestration and container technologies to package & support more memory capacity and multi-tenancy (additional shards, more databases) with Intel PMem 200 Series on a 3-node X12 Supermicro BigTwin Compact Cluster.
For systems with 20 DIMMs, 1DPC is typically recommended for optimal memory performance across 8-memory channels per socket. Configuration 1 was used as a baseline to measure the optimal memory performance with memtier_benchmark 1.3.0 (edge). Configuration 2 was used to measure the memory performance with twice the capacity by using DDR4 on 4-memory channels and PMem on the other 4-memory channels per socket to double the memory capacity.
Config
Memory Configuration
PMem Mode
Usable Memory (GB)
Container Type
1
512GB
16x 32GB DDR4
N/A
1.5TB across 3 nodes
Bare-Metal on Red Hat OpenShift
2
1024GB
8x 32GB DDR4-3200
8x 128GB PMem-3200
PMem to DRAM: 4:1
Memory Mode
3TB across 3 nodes
Table 2. Config Info
References
Supermicro BigTwin Multi-Node Servers:  https://www.supermicro.com/en/products/bigtwin/
Supermicro Redis Solutions: https://www.supermicro.com/en/solutions/redis
Written by Mayur Shetty, Principle Solution Architect, Red Hat
