Ethernet Products
4946 Discussions
How can I get VLAN working in Windows 10?
SVerd1
It's Windows 10 2016 LTSB 1607, build 14393 using PRO Set version 22.4
The VLAN configuration tab tells me to update Windows 10, I'm using the version specified here: https://www.intel.nl/content/www/nl/nl/support/network-and-i-o/000022282.html
This is for embedded devices that won't have an internet connection, so if I need a Windows update I'd like to know which update(s).
Hi RH_SV,
Thank you for posting at Wired Communities. I will check for you, for the meantime, can you also share what is the network adapter used?
sharon
Hi RH_SV,
Further checking and here are the updates after running the Windows* updates:
KB4022715
KB3186568
Security Update for Adobe Flash player
KB4023834
KB4022632
I am attaching the screen shot here for your reference. Hope this helps.
sharon
SVerd1
Thank you for your reply sharon
I will check later if these updates do the trick.
The adapters in question are 82574L and 82579LM
Hi RH_SV,
Thank you for the information. Please feel free to update me, hope to hear good news from you.
sharon
HI RH_SV,
Please feel free to update me if you have ran the Windows update and if you still further assistance.
sharon
SVerd1
Hi sharon,
Sorry for the late answer.
KB4022715 is enough to get VLAN on the 82579LM, The 82574L is not supported in Win10 it seems
Hi RH_SV,
Thank you for the update and glad it work for you on 82579LM. 82574L does not have the driver for Windows 10. For the meantime, any other inquiries? Thank you.
regards,
sharon
