PowerShell cmdlets not available. Intel ANS also not available for Windows 11. What should i do for successfully VLAN configuration?
This NIC is on a HP Z2G4 mini (2018) mainboard.
Hi videobit,
We apologize for the inconvenience caused.
We would be grateful if you could provide us some information as per below if available.
- I219-LM LAN driver version:
- Windows 11 build version:
- CPU:
We will cross check with engineering team for your inquiry if there is any suggestion that they could share with us and give you an update accordingly.
However in the meantime, we believe that it will be worth for you to check on the other similar case post in the Intel Communities as per link below:
Fariz_Intel
Thank you very much for your support. I will test this with the Hyper-V switch (will probably also work).
The answer to the OS and hardware:
I219-LM LAN driver version: 12.19.2.45
Windows 11 build version: 22H2
CPU: i7-8700 CPU @ 3.20GHz
Hi videobit,
We apologize for the inconvenience caused. Unfortunately, Hyper-V is the only available option at the moment however Intel still continue working towards to keep improving the driver. We deeply appreciate your comprehension regarding this matter.
Fariz_Intel
