Ethernet Products
4939 Discussions
Intel I340-F4 use only TX Channel
Hi @ all,
I want to use an Intel I340-F4 Card in an enviroment, where there is only TX comminucations and no RX. (unidirectional communication)
I'am using the Linux igb driver on an 64-Bit Ubuntu.
Is it possible to use only one channel? And how?
Chris
Mark_H_Intel
Hi Chris,
You will need both transmit and receive to establish the Ethernet link even if the data is only being sent in one direction.
Mark H
ARoma15
Chris,
We are facing the same problem, have you found a way to do it? Thanks!
SYeo3
Valued Contributor I
Hi Hold,
Please refer to my post below. Thanks.
/message/290134# 290134 1. /message/290134# 290134 Re: i350-f2 unidirectional transfer
Apr 8, 2015 3:56 AM (/message/289888# 289888 in response to Hold)
Hi Hold,
Thank you for contacting Intel.
The Intel® Ethernet Server Adapters with fiber optic connector requires that RX and TX ports be connected. The network adapter won't connect when only 1 port (RX or TX) is connected.
Sincerely,
Sandy
