Both onboard Ethernets on the DQ77MK seem to have the same type instance number. This seems to cause problems with Linux biosdevname making it think there are duplicate bios names for the ethernet devices and fails to return a valid name. Anyone else run into this problem? I'm trying to qualify a new board for production with BIOS 054 and did not see any reference in release notes for subsequent BIOS updates that changes this data.
# dmidecode 2.11
# SMBIOS entry point at 0x000f04c0
SMBIOS 2.7 present.
79 structures occupying 3274 bytes.
Table at 0x000EC420.
Handle 0x0000, DMI type 0, 24 bytes
BIOS Information
Vendor: Intel Corp.
Version: MKQ7710H.86A.0054.2012.1120.1444
Release Date: 11/20/2012
Address: 0xF0000
Runtime Size: 64 kB
ROM Size: 12288 kB
Characteristics:
PCI is supported
BIOS is upgradeable
BIOS shadowing is allowed
Boot from CD is supported
Selectable boot is supported
EDD is supported
5.25"/1.2 MB floppy services are supported (int 13h)
3.5"/720 kB floppy services are supported (int 13h)
3.5"/2.88 MB floppy services are supported (int 13h)
Print screen service is supported (int 5h)
8042 keyboard services are supported (int 9h)
Serial services are supported (int 14h)
Printer services are supported (int 17h)
ACPI is supported
USB legacy is supported
BIOS boot specification is supported
Targeted content distribution is supported
UEFI is supported
BIOS Revision: 4.6
Handle 0x0039, DMI type 41, 11 bytes
Onboard Device
Reference Designation: L1U1
Type: Ethernet
Status: Enabled
Type Instance: 1
Bus Address: 0000:00:19.0
Handle 0x003A, DMI type 41, 11 bytes
Onboard Device
Reference Designation: AU1
Type: Sound
Status: Enabled
Type Instance: 1
Bus Address: 0000:00:1b.0
Handle 0x003B, DMI type 41, 11 bytes
Onboard Device
Reference Designation: L2U1
Type: Ethernet
Status: Enabled
Type Instance: 1
Bus Address: 0000:02:00.0
- Tags:
- Desktop Boards
Please note that the official operating systems supported are Windows* 7 and Windows* 8. We recommend posting your inquiry in Linux* Communities.
Supported operating systems
http://www.intel.com/support/motherboards/desktop/sb/cs-008326.htm http://www.intel.com/support/motherboards/desktop/sb/cs-008326.htm
KS,
If you go by the formal definition for this parameter, you are absolutely correct; the type 41 record for the second NIC should have Device Type Instance (DTI) set to 2 (second device of this type). If you go by the example that they include in the SMBIOS spec, however, there's a problem -- the example states that the NICs need to be "identical" before the DTI is required to be set to 2. It could be argued that the 82579LM and 82574L NICs are not "identical". Still, I agree with you; the wording of the example is just unfortunate. I am having a defect report opened...
![](/skins/images/C4F7392A5C68ACA60290C9576F107044/responsive_peak/images/icon_anonymous_message.png)
