I have a network X722 card that would not work with Ubuntu 22.04.5 OS.
I configured netplan to use the 2 ethernet ports:
# This file is generated from information provided by the datasource. Changes
# to it will not persist across an instance reboot. To disable cloud-init's
# network configuration capabilities, write a file
# /etc/cloud/cloud.cfg.d/99-disable-network-config.cfg with the following:
# network: {config: disabled}
network:
version: 2
renderer: networkd
ethernets:
enp181s0f0:
dhcp4: false
dhcp6: false
link-local: []
addresses:
- 192.168.0.4/24
enp181s0f1:
dhcp4: false
dhcp6: false
link-local: []
addresses:
- 192.168.0.5/24
A cable is plugged on first ethernet port, I checked it and there is no issue with it. But "ip a" reports a "no carrier".
144: enp181s0f0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
link/ether 08:00:38:ce:02:1e brd ff:ff:ff:ff:ff:ff
inet 192.168.0.4/24 scope global enp181s0f0
valid_lft forever preferred_lft forever
145: enp181s0f1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
link/ether 08:00:38:ce:02:1f brd ff:ff:ff:ff:ff:ff
inet 192.168.0.5/24 scope global enp181s0f1
146: enp181s0f2: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/ether 08:00:38:ce:02:20 brd ff:ff:ff:ff:ff:ff
147: enp181s0f3: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/ether 08:00:38:ce:02:21 brd ff:ff:ff:ff:ff:ff
I'm not able to ping another device on 192.168.0.0/24 network from server, nor able to ping it from other device.
And IP(s) have been set by myself (ip a add...), not netplan
I did:
- install/update i40e driver (2.26.8 - Intel® Network Adapter Driver for PCIe* 40 Gigabit Ethernet Network Connections under Linux*)
- install/update irdma driver (1.15.11- Linux* RDMA Driver for the E810 and X722 Intel® Ethernet Controllers)
- install/update (optionally ?) iavf driver (4.12.5 - Intel® Network Adapter Linux* Virtual Function Driver for Intel® Ethernet Controller 700 and E810 Series)
- Tried to update firmware (4.10 with 9.52 package - Non-Volatile Memory (NVM) Update Utility for Intel® Ethernet Adapters 700 Series—Linux*) with NO SUCCESS
- NVM Inventory (attached)
And problem remains
I attached a "lshw -C network" output if it may help...
I'm pretty sure I'm missing something, but what...
Your help would be greatly appreciated, don't hesitate to ask me more information ^^
Thanks per advance
Always trying to solve my issue, do you have any suggestion to help me update the firmware of my X722 card ?
Thanks for your help ans best regards
I forgot to share some information about the "nvmupdate" process not working with my hardware...
Here are the output of "nvmupdate64e" run:
local_adm@server01:~/nvmupdate/700Series/Linux_x64$ sudo ./nvmupdate64e
Intel(R) Ethernet NVM Update Tool
NVMUpdate version 1.42.8.0
Copyright(C) 2013 - 2024 Intel Corporation.
WARNING: To avoid damage to your device, do not stop the update or reboot or power off the system during this update.
Inventory in progress. Please wait [|.........]
Num Description Ver.(hex) DevId S:B Status
01) Intel(R) Ethernet Connection X722 N/A(N/A) 37D0 00:181 Update not
for 10GbE SFP+ available
Tool execution completed with the following status: Device not found.
Press any key to exit.
Don't hesitate to ask me some more information, your help would be greatly appreciated ^^
As I found a compatibility matrix document (Intel® Ethernet Connection X722 / Feature Support Matrix) I tried to update:
- irdma to v1.9.30 (Linux* RDMA Driver for the E810 and X722 Intel® Ethernet Controllers)
- rdma-core to v35.12 (rdma-core-35.12)
- i40e to v2.20.12 (Intel® Network Adapter Driver for PCIe* 40 Gigabit Ethernet Network Connections under Linux*)
I had no trouble doing this, everything seems to install well.
Then I tried to update NVM with package: Non-Volatile Memory (NVM) Update Utility for Intel® Ethernet Network Adapter 700 Series.
But it won't work:
local_adm@server01:~/phase4/700Series/Linux_x64$ sudo ./nvmupdate64e
NVMUpdate version 1.39.5.5
Copyright(C) 2013 - 2022 Intel Corporation.
01) Intel(R) Ethernet Connection X722 4.16(4.10) 37D1 00:181 Update not
for 1GbE available
local_adm@server01:~/phase4/700Series/Linux_x64$ sudo ./nvmupdate64e -v
Version:
QV SDK - 2.39.05.05
igb - unknown
ixgbe - unknown
i40e - 2.20.12
ice - unknown
local_adm@server01:~/phase4/700Series/Linux_x64$ sudo ethtool -i enp181s0f0
driver: i40e
version: 2.20.12
firmware-version: 4.10 0x80001ac7 255.65535.255
expansion-rom-version:
bus-info: 0000:b5:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
And I am a bit lost with this "4.10 (hexa) <=> 4.16 (dec)" version of NVM, not found in compatibility list !?
Any suggestion, idea, fix... would be greatly appreciated ^^
Issue using Ethernet ports still remains...
