Community
cancel
Showing results for
Search instead for
Did you mean:
local_dd
darknet yolov4
hello!
I'm converting Darknet yolov4 model into IR, which has been converted into tensorflow2*
Includes three files: assets, variables, saved_model.pb
But when I execute the command to convert to IR
python3 mo.py --saved_model_dir /home/ubuntu/yolov4 --output_dir models/IRs --input_shape [1,608,608,3] --model_name yolov4
[ ERROR ] Exception occurred during running replacer "REPLACEMENT_ID" (<class 'extensions.load.tf.loader.TFLoader'>): Unexpected exception happened during extracting attributes for node Const.
Original exception message: 'ascii' codec can't decode byte 0x92 in position 1: ordinal not in range(128)
Please tell me how to solve it
CrisselleF_C_Intel
Hello local_dd,
To check which support would be best to assist you, kindly provide the Intel Ethernet model or Intel product involved on this request. Please also share if your are into designing your own board.
We also noticed that you posted on our thread without subject or description. Please be informed that we will be closing this thread to avoid duplicates and confusion. Feel free to let us know if you have questions or clarifications on your posts below so we can check on it as well.
https://community.intel.com/t5/Ethernet-Products/unreadable-title/m-p/1321562#M26921
https://community.intel.com/t5/Ethernet-Products/unreadable-title/m-p/1321563#M26922
Hoping to hear from you soon.
Should there be no reply, we will follow up after 3 business days.
Crisselle C.
Intel® Customer Support
CrisselleF_C_Intel
Hello local_dd,
Good day!
This is just a follow up to check if you received our initial response. If yes, please confirm and provide the information requested for us to proceed checking your query.
Crisselle C.
CrisselleF_C_Intel
Hello local_dd,
How are you doing?
Please be informed that we will now close this request since we haven't received any response from our previous follow ups. Just feel free to post a new question if you may have any other inquiry in the future as this thread will no longer be monitored.
May you have an amazing weekend ahead and stay safe!
Crisselle C.
