Hi All
I try to run linnxptp with i210 NIC card, by tutorial, I already modify igb Linux driver source code to generate 1PPS at SDP 0 pin, however, when I run it for IEEE 1588 test, the i210 as master of IEEE 1588, by Scope, we can find the PPS is stable at every 1 second. But if it be the slave of IEEE 1588, the PPS disappear and never show again
After much test and check the driver code, we sure the PPS can't generate when it's become the slave of IEEE 1588, we don' understand why?
System information
OS: Ubuntu 20.04 with kernel 5.4.0-26
Linuxptp(The Linux PTP Project )
igb source version: 5.4.16
*figure show we modify part
If have any information need us provide, we will post it later
Thanks every one who give us help
BR
Hi waleslai,
Regarding your issue, we are currently checking on it and give get back to you shortly.
Sazzy_Intel
Hi waleswai,
Good day.
Regarding your enquiries above, we have a documentation related to your enquiries that is available in Intel Research & Documentation Center (https://www.intel.com/content/www/us/en/resources-documentation/developer.html#gs.8l8k06)
You may want to refer to below link :
However, this document is confidential and requires NDA to access. You may use your own NDA to access it, or if you dont have it, we may need to create one. Please provide below details:
Company Name:
Country:
Main Contact (Name of the person who is asking for confidential information):
Contact Position or Job Title:
Main Contact Phone Number:
Main Contact Email:
Physical Address:
NDA Number (if customer has signed an NDA previously).
Sazzy_Intel
Hi Sazirah,
Good day.
Thank you for the information. I will discuss the NDA requirement with my team member.
Additionally, if we decide to sign the NDA, could you provide contact person or an email address for us to know the NDA apply progress?
Waleslai
Hi waleswai,
Thank you for your reply.
If you are interested with the NDA creation, you may provide those required details and I will initiate the creation from my end.
Additionally, you may want to refer to link below related to this,
Sazzy_Intel
Hello waleslai,
We have sent follow up email if you'd like to proceed NDA
Irwan_Intel
Hi Sazirah and Irwan_Intel
It's been a great help
We already received the mail from Intel Customer Support,
when we ready, we will send the mail to start the sign the NDA
Walealai
Hello waleslai,
Thanks. Just reach out to us and provides the details as requested. We're here to assist you every step of the way
Irwan_Intel
Hello waleslai,
Greetings!
We have checked your concern related to PPS alignment edge with our Internal team and these are their suggestions.
Kindly confirm if this is a LOM I210 or if it is I210-T1 ethernet adapter? also, If it is a LOM design, it’s ok to add an inverter for your applications.
Please contact us back if you have any other queries.
Thank you for using Intel products and services.
Sachin KS
We use the I210-T1 ethernet adapter.
Our members already add inverter on I210-T1 ethernet adapter, seems it can meet our requirement.
But we have a question that can we change the PPS edge by config the E1000 register? without inverter
The figure show the our PPS result
i210 PPS(Yellow line)
our DUT PPS(pink line)
We want the Yellow line can use raise edge alignment with us edge
Waleslai
Hi waleslai,
Thank you for your response. Please allow us some time to review the details and we will get back with an update shortly.
Dinesh
