The R-TIle Intel FPGA IP for Compute Express Link (CXL) Example Design in Quartus 24.2 does not provide an option for DK-DEV-AGI027-RA as a development board.
How can the ED be generated for this board?
Thank you,
Ricardo
Hi there,
Yes, they only support DK-DEV-AGI027RBES and DK-DEV-AGI027R1BES now. I recommend u use AGI027RBES to generate the ed and change the device after the generation, due to they use the same power solution and configuration details.
WZ
Hi WZ,
Thank you for your feedback.
Does it mean that the PCBs DK-DEV-AGI027RBES and DK-DEV-AGI027-RA are identical to each other, and the revision of the FPGA is the only difference between them?
Thank you,
Ricardo
Hi there,
Yeah, that is right~
WZ
Topic Options
