The Intel sign-in experience is changing in February to support enhanced security controls. If you sign in, click here for more information.
5422 Discussions
ALTERA MAX 10 How to write custom ADC interface verilog code
Hello guys,
I am new to FPGA though I have experience with verilog coding.
I am working on a Project where I need to use the ADC of Max 10 at 1MSPS to measure an analog signal and send the binary data to the PC.
I saw a few examples out there like using QSYS and the ADC tool kit. Though I was able to implement the example I havent understood how that works at all.
I needed some guidance regarding some documentation/lessons where I can read directly how to interface with the on board ADC.
Even a pinout of the ADC and what each of those pin do would be a good starter.
You don't say which MAX 10 development board you are using. Is it this one: https://www.altera.com/products/boards_and_kits/dev-kits/altera/max-10-fpga-development-kit.html
The MAX 10 part on this board has an integrated ADC, it is not a separate part. The above page has pointers to the full board level schematic.
If so, have you looked here and read these documents: https://www.altera.com/documentation/sam1393576011848.html
PS If you are going to ask questions, you need to be REALLY specific about what boards/chips/software/etc you are using. We are not mind readers.
--- Quote Start ---
--- Quote End ---
The full description of the board is: Max 10M50DAF484C6GES
Its the same one you have given in the link.
Yes I went through the schematic and the User guide for ADC.
The schematic doesnt really show the ADC chips output pins only the analog input pins are mentioned. I guess its because its integrated by I dont understand that how will I send e.g. clock to the ADC without knowing the PIN.
The user guide gives description about the ADC modular IP but doesnt provide much detail to understand the full working of the IP core to manipulate it.
--- Quote Start ---
--- Quote End ---
The documentation here would appear to provide all the info you need to use the ADC: https://www.altera.com/documentation/sam1393576011848.html#sam1393996851885
The ADC is a hard IP macro block, so Altera is not going to give you much low level detail of the innards of the block, but just describe the input and output pins of the block, and what you need to provide from your FPGA code.
