5975 Discussions
Agilex I-series devkit: examples not working...
alexislms
Valued Contributor I
I'm trying to compile pcie_ed from agilex_agib027r29a1e2vr0_fpga_reva_v21.2b072_v1.0/examples/pcie_ed
using Quartus Pro 21.
Opening the project, running the compilation:
Could you provide working example with at least no error when compiling...
1. Download here
it says "21.2 or higher"
2. I untar pcie_ed, pcie_ed.qpf has QUARTUS_VERSION = "21.1"
3. Open the qpf with Quartus 21.1, compile, errors
Please update the link ASAP with working examples.
alexislms
From the same tar, I tried to compile "qsfpdd_xcvr" on 21.1 (on 22.1 the Avalon Data Test Generator IP core doesn't exist...)
I don't find this error message very useful, any help would be very much appreciated.
Opening the "Support-Logic Generation" 's report, Quartus ends up crashing:
Problem Details
Error:
*** Fatal Error: Segment Violation: faulting address=0x10, PC=0x7f1a2607a6bd : 0x7f1a2607a6bd: db_tileip!TILEIP_WRITER::initialize_default_profile() + 0xc1
Module: quartus
Stack Trace:
  Err Handler      0x111ab: ERR_UNWINDER_BACKTRACE::get_stack_trace(void const**, int, int, void*) + 0xf3 (ccl_err)
  Err Handler      0x7429a: msg_ie_get_call_stack(void*) + 0xa3 (ccl_msg)
  Err Handler      0x7588e: MSG_INTERNAL_ERROR::report_fatal(char const*, void*) + 0x3c (ccl_msg)
  Err Handler      0x12b2d: err_report_fatal_exception(char const*, void*) + 0x68 (ccl_err)
  Err Handler      0x135e6: err_sigaction_handler + 0x12f (ccl_err)
  System           0x12ce0: (pthread)
  Quartus         0x3d16bd: TILEIP_WRITER::initialize_default_profile() + 0xc1 (db_tileip)
  Quartus         0x4093d8: TILEIP_WRITER::solve_tile(std::vector<std::pair<std::string, std::string>, std::allocator<std::pair<std::string, std::string> > >*, TILEIP_TILE*, std::string const&, bool, bool) + 0x4a (db_tileip)
  Quartus         0x40973f: TILEIP_SOLVER_IF_IMPL::validate_placement(std::vector<TILEIP_SOLVER_IF::TILEIP_BB_PLACEMENT, std::allocator<TILEIP_SOLVER_IF::TILEIP_BB_PLACEMENT> >*, std::string const&, bool) + 0x133 (db_tileip)
  Quartus          0x40094: TPL_FACADE::load_ip_json(std::string, nlohmann::basic_json<std::map, std::vector, std::string, bool, long, unsigned long, double, std::allocator, nlohmann::adl_serializer, std::vector<unsigned char, std::allocator<unsigned char> > >) + 0x104 (sys_tpl)
  Quartus          0x7b78c: BPPS_MANAGER::load_design() + 0x440 (sys_bpps)
  Quartus          0x7d90e: BPPS_MANAGER::initialize() + 0x32 (sys_bpps)
  Quartus          0x60688: bpps_initialize_blueprint + 0x2e7 (sys_bpps)
  Quartus          0x4c942: TclNRRunCallbacks + 0x42 (tcl8.6)
  Quartus          0x4de7b: TclEvalEx + 0x68b (tcl8.6)
  Quartus          0x4e496: Tcl_EvalEx + 0x16 (tcl8.6)
  Quartus          0x1e3d9: atcl_tcl_eval(Tcl_Interp*, std::string const&, bool) + 0xe3 (ccl_atcl)
  Quartus          0x6d718: ITC2_BPPS_CHANNEL_IMPL::doWork() + 0x598 (resr_itc2)
  Quartus          0x6bdd1: ITC2_BPPS_CHANNEL_IMPL::qt_static_metacall(QObject*, QMetaObject::Call, int, void**) + 0xf1 (resr_itc2)
  Quartus         0x2db023: QObject::event(QEvent*) + 0xd3 (Qt5Core)
  Quartus         0x15b7ac: QApplicationPrivate::notify_helper(QObject*, QEvent*) + 0x9c (Qt5Widgets)
  Quartus         0x162290: QApplication::notify(QObject*, QEvent*) + 0x1e0 (Qt5Widgets)
  Quartus         0x2aba18: QCoreApplication::notifyInternal2(QObject*, QEvent*) + 0x108 (Qt5Core)
  Quartus         0x2aea92: QCoreApplicationPrivate::sendPostedEvents(QObject*, int, QThreadData*) + 0x222 (Qt5Core)
  Quartus         0x304851: QEventDispatcherUNIX::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 0x41 (Qt5Core)
  Quartus         0x2aa42a: QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 0x10a (Qt5Core)
  Quartus          0xb52b4: QThread::exec() + 0x84 (Qt5Core)
  Quartus         0x1b41cc: AFCQ_THREAD::thread_wrapper(void*) + 0xe (gcl_afcq)
  Quartus          0x40ed6: msg_thread_wrapper(void* (*)(void*), void*) + 0x64 (ccl_msg)
  Quartus          0x1528e: mem_thread_wrapper(void* (*)(void*), void*) + 0x5e (ccl_mem)
  Quartus           0xcdc0: err_thread_wrapper(void* (*)(void*), void*) + 0x1e (ccl_err)
  Quartus           0x6ba5: thr_thread_wrapper + 0x15 (ccl_thr)
  Quartus         0x1b3855: AFCQ_THREAD::run() + 0x13 (gcl_afcq)
  Quartus          0xb65a5: QThreadPrivate::start(void*) + 0x135 (Qt5Core)
  System            0x81ca: start_thread + 0xea (pthread)
  System           0x39d83: clone + 0x43 (c)
End-trace
Quartus Prime Version 21.1.0 Build 169 03/24/2021 SC Pro Edition
AR_A_Intel
Hello
Welcome to INTEL forum. Can you give me a little background/elaborate on your setup proses and step? provide error messages?
For privacy, reply/attach your file in private message.
alexislms
No need for privacy, I'm just trying to work with Intel's public projects.
1. https://www.intel.com/content/www/us/en/products/details/fpga/development-kits/agilex/i-series.html
2. Download the tar ES (21.2 or higher)
3.
alexislms
3. untar
4. open with quartus pro 21.1 or 22.1
5. agilex_agib027r29a1e2vr0_fpga_reva_v21.2b072_v1.0/examples/pcie_ed or any other example designs
alexislms
6. try to compile the project
the website is really broken, it doesn't stop to move the view down, it's pretty annoying and impossible to write a simple message...
AR_A_Intel
Hi
Could you provide the error message screenshot and the .log file
AR_A_Intel
Hi
Upon checking, the case is still in pending investigation by engineering. The fix will take some time. As suggested in community forum https://community.intel.com/t5/Intel-Quartus-Prime-Software/Avalon-Data-Pattern-Checker-IP-missing-in-Quartus-Pro-22-1/m-p/1390003#M73987
that is the best you could use back the older Quartus version which has the IP for now as a workaround.
AR_A_Intel
We have not heard from you and I hope that my last note clears up this matter. I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
